"Auto" Headlights feature
Discussion in '2.5 Gen Tundras (2014-2021)' started by AlexJet, Nov 21, 2020.
  1. Nov 21, 2020 at 1:54 PM
    AlexJet
    AlexJet [OP] New Member
    2021 TRD Offroad CrewMax
    On 2021 and probably even earlier, Toyota decided to implement an "Auto" headlight feature and completely remove "0" position on the left stalk. Why did the do it?
    Now I can't have manually turn the lights off and turn them ON when they are really needed, as they tend to turn on every time I pass the bridge or turns ON 1.5 hr before it becoming slightly dark outside.
    Another disadvantage of this feature as when you come to someone home to pick someone up and shut down the engine, the lights are staying on till you open the door. Just today I was picking up a person and decided not to open the door and see when the shuts down. I came 20 min earlier and course was running late and person walked out 40 minutes after I arrived. Guess what, my headlights were still ON for those 40 min. This is a flaw in the system...
    Does anyone know how to disable this "Auto" feature and have it normal way On/Off?
  2. Nov 21, 2020 at 1:58 PM
    Wallygator
    AbunaiTaco likes this.
  3. Nov 21, 2020 at 1:59 PM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Depress the below button to disable the auto headlights
    vokeydawg, rebmo and Wallygator like this.
  4. Nov 21, 2020 at 2:00 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    the “drl off” position on the stalk turns the headlight off, and then you can rotate it all the way to on manually when they need to be on.
    Hit the lock button on the fob twice after getting out to turn the lights off. There’s also a setting on the head unit to change how long they stay on after shutting the engine off (I think it goes down to zero seconds/off).
  5. Nov 21, 2020 at 2:03 PM
    AlexJet
    In the location circled, there a Rear Window down switch.
    "AUTO LIGHTS" just beside it is for Auto High Beam
    Cpl_Punishment likes this.
  6. Nov 21, 2020 at 2:05 PM
    Clemsonman14
    My bad thought you were talking about the auto dim feature
  7. Nov 21, 2020 at 2:08 PM
    AlexJet
    The stalk on 2021 has only 3 positions:
    Auto - Parking Light - Low Beam
    There is no DRL Off
    I was referring to turn the engine Off, but not opening the door. Here is the situation when the headlights will stay On for as long as battery would not discharge... I can't imagine someone arrive somewhere and sit in the car for a day, but technically speaking it possible.
    On my 4Runner as soon as the engine is Off, the headlights goes Off as well.
    I turn the Light delay Off on the head unit, so they never On when I lock the car.
  8. Nov 21, 2020 at 2:16 PM
    Squatting Pigeon
    Holden
    North Texas
    Interesting, my 2019 has the drl off on the stalk. Seems odd they took away the ability to turn the lights off completely. :monocle:
    CavalryCrew602 and Durania like this.
  9. Nov 21, 2020 at 2:20 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Mine is the same. I think it's a Canadian thing. When I shut my truck off, if it's dark and my lights stay on, I can just rotate the selector to park lights then back to auto and they'll switch off. (Sometimes have to do it twice if I do it too quickly or if I don't wait long enough after turning off the truck to do it.)
  10. Nov 21, 2020 at 2:22 PM
    CaptainGrumpus likes this.
  11. Nov 21, 2020 at 2:28 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Mine 21 has got DRL off...
    Aldudley5 likes this.
  12. Nov 21, 2020 at 2:33 PM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    I'm gonna have to look to be sure but I thought mine does too :monocle:
  13. Nov 21, 2020 at 2:36 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    People are too stupid to remember when to manually turn them on and off, so they make them idiot proof.
    It is to stop dummies from driving at 4am or 11pm with no lights on.
  14. Nov 21, 2020 at 3:32 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Now if only every other manufacturer also did this. Though 2nd gen Tundras are notorious for driving around here at night with just their park lights on.
  15. Nov 21, 2020 at 3:35 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Mine does too
  16. Nov 21, 2020 at 3:44 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Staggering that as a people we have "advanced" to where we can't have a simple on/off for the headlights. Goodness.
    stuckinohio likes this.
  17. Nov 21, 2020 at 4:11 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    My biggest pet peev is OEM's that allow DRL to provide enough light that people are capable of using to drive at night and them not realizing they can't bee seen by others.
    Most drivers have no idea they forgot and think you are flashing your lights just to be a prick.
    If your gauge cluster is lit and DRL/fogs are on then the rear lights should be on as well. I get people what the ability to turn off all lighting manually,
    OP, I would be curious if you can replace your combi meter stalk with one that has the feature. I would be surprised if they modified the harness.
    The only downside is you will have to pull your steering wheel to swap out.
    I looked at adding the Auto feature to my dads 2016, since all he needed was the sensor and stalk.
  18. Nov 21, 2020 at 4:17 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    I see that every night.Endless morons driving these days. Totally clueless behind the wheel
  19. Nov 21, 2020 at 4:22 PM
    stuckinohio
    Mark
    oHIo
    2018 SR5 Crewmax
    From a safety standpoint, i think the OEM should be held accountable for creating a scenario or allowing a combination of settings that allows the vehicle to become a hazard to occupants and surrounding motorists.
    Toyota locks out GPS map searches while driving. Honda does too, this is no different.
  20. Nov 21, 2020 at 4:23 PM
    Wallygator
    My 2016 4Runner had this and I loved it. People on that forum would complain about it. No one ever seems to be happy anymore. First world problems suck!
  21. Nov 21, 2020 at 7:36 PM
    Wallygator
    Right! Cuz being responsible and/or personally accountable while you are behind the wheel of an automobile is just ridiculous!
  22. Nov 21, 2020 at 7:45 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    That happened to me once. I was shocked that my lights we're not on, now I just leave the lights on all the time.
  23. Nov 21, 2020 at 7:48 PM
    4WDWalrus
    4WDWalrus New Member
    The Silver Walrus
    TRD shift knob OEM Fender Flares Truxedo Pro X15
    Come on now, driving is a hazard on its own.
    What happen to personal responsibility and thinking :bikewhoops:
  24. Nov 21, 2020 at 8:18 PM
    TaquitoBandito
    Joel (AKA Bif)
    It's because you guys only get like 3 minutes of daylight a week up there - Toyota loves it's Canadian owners. :canada:
  25. Nov 21, 2020 at 8:31 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Is there any way to run the fog lights without the head lights on? Just like the Tacoma
  26. Nov 21, 2020 at 8:52 PM
    Lagerstout82
    Lagerstout82 New Member
    2021 Tundra SR5 TRD Sport
    On my 2021 TRD Sport, the AUTO on the second row is to enable/disable Auto High-Beams when the head light stalk is pushed forward to enable high beams.
    Then here DRL OFF turns off all forward lighting.
    Aldudley5 and Wallygator like this.
  27. Nov 22, 2020 at 4:57 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Why would you want to? If it's foggy, I'd definitely want the back of my truck lit.
    TaquitoBandito likes this.
  28. Nov 22, 2020 at 5:09 AM
    4WDWalrus
    The Silver Walrus
    This may be mandatory Canadian feature. But, in the center display vehicle settings, you can adjust the duration the headlights remaining on after turning off the car. As well as change the sensitivity of when the headlights turn on when dark and also turn off the DRLs.
  29. Nov 22, 2020 at 5:43 AM
    Funnyguy713
    Houston TX
    I dont care about the back of the truck. I am talking about being able to have just the fog lights on without the front headlights. I was able to do that on my Tacoma, sometimes all you need are the fog lights before it gets dark.
  30. Nov 22, 2020 at 7:36 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Wouldn't DRLs or park lights serve the same purpose?
    Lagerstout82 likes this.
