Audio install nightmare...
Discussion in 'Audio & Video' started by Darkindustries, Sep 5, 2019.
  1. Sep 5, 2019 at 8:03 PM
    Darkindustries
    Darkindustries [OP] New Member
    Tundra Limited Crewmax
    2016 tundra limited crewmax with some bells and whistles.
    I am having an audio install nightmare on my 2016 Tundra Limited crewmax. I was reading about another forum member here having a similar issue.
    I disliked the paper-ish sound of my Tundra's stock system. I did not get the JBL anything upgrade. I went to a shop and the installer recommended only to add subs to the stock head unit. He says the mids and highs on this truck are "a pain to get right" and several times leans towards "I just don't want to do a mid's and high's install". He installs a Precision power black ice amp and 3x MTX 8'' (parallel(?)) subs behind the seats. It hits hard and clean but the bass easily drowns out the very lacking mids and highs.
    I call around for shops that had specifically worked on Tundras, specifically installs for the mids and highs. I get a shop that sounds like they might know what they are doing. They have a decent online reviews. I drop my truck off. Mid day the shop calls and tries to upsell me on speakers, saying that I should spend another $450 to get "the top of the line components". I decline. They install an Alpine MRV f300 4 channel amp and replace the door speakers in the front and rear with Pioneers. When I pick up my truck it sounds absolutely terrible. I mean utter rubbish. The subwoofers now sounds as if they are loudspeakers and adjusting anything on the Precision power amp has little effect on improving the quality. The mids and highs just sound louder but they sound like just utter poo poo. The shop was closing as I picked the truck up. I called the shop the following day and they were closed early for a holiday. I called mid week after the holiday and the installer who worked on my system isn't available to help me with my system. After two weeks of calling for the guy simply to get advice, I finally get: "you paid for speakers and we installed speakers, you should have taken the upgraded speakers we recommended".
    I go to another shop that "focuses on high end cars". The super seemuh trophy carshow winning guy says that I need a $1500 DSP (and "only this DSP will work") and that the second installer must have incorrectly split the signal coming from the headunit. He recommends a $5500 foCAL component system if I want it to sound "decent" but says I should go higher...and shows me a webpage with car speakers that literally cost more than my truck. So $7k just to get mids and highs sounding "decent" didn't really sell me. Needless to say I didn't pull the trigger on it.
    I am guessing the second installer had to (obviously) split the RCA red/white cables somewhere in order to provide a signal to the (new) Alpine 4 channel amp. Doing this somehow trashed my sub signal. I could use some audio upgrade advice and help.
    I am in the Northwest US, you can PM me for exact coordinates. Any help is much appreciated.
    GNTundra likes this.
  2. Sep 5, 2019 at 8:35 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    Any particular reason you didn't try a plug n play system? They make some specifically for this truck.
    Sas likes this.
  3. Sep 5, 2019 at 9:21 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Upgraded speakers has absolutely nothing to do with a shit install. Maybe it would be better to redo it yourself. Youtube and browsing the audio section here.
    Rica25 likes this.
  4. Sep 5, 2019 at 9:58 PM
    Darkindustries
    While they are an upgrade from the stock system, I wasn't satisfied with the intensity at high volumes from the JBL system and the ********* systems that I’ve heard.
  5. Sep 5, 2019 at 10:00 PM
    Darkindustries
    Totally able to, and it is headed in that direction. Would love recommendations on signal splitting from the stock head unit and mids/highs speakers.
  6. Sep 5, 2019 at 10:00 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    Built my first system w/ an Aftermarket Radio, 4ch amp, 1 mono amp for my sub and rewired the entire system. The second time around I went with a plug n play system, which I have to do again.
  7. Sep 5, 2019 at 10:13 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
  8. Sep 5, 2019 at 10:20 PM
    ZE_TRUCK
    ZE_TRUCK Never ending build Always ending money
    2018 Tundra SR5 Sky Metallic
    king shock 3.0 Lift SS built bumper and third brake light 35" Toyo Open Country MT Black Rhino Arsenal Matte black 18” Nfab Side Steps Venom 250 Black widow muffler blacked out exhaust tip grabbinasshandles shifter LED Headlights LED interior lights LED Blinkers AFE Intake AFE Throttle spacer 32" Light bar Cali raised GG lighting Ditch lights 2 12” subwoofer box rear seat Upgraded all speakers 1200 watt kicker amp Locked off-road bump stops Kc hilites 3rd brake light
    I replaced all my speakers and tweeters and added 2 12” subs along with 2 1000 watt amps .... did the trick. Kept my stock head unit.
  9. Sep 5, 2019 at 10:21 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    I have had nothing but compliments on my ********* setup, I used everything except their speakers. I went with aftermarket JBL's 2-12 (300w RMS 500w max) subs and component front and rear. When i turned system near max and the bass all the way up, at Idle you could see the volts dip. Wouldn't do it at cruising speeds or above 1000 rpm. The bass never overpowered the sound of the door speakers but complimented it.
    There is a lot of information on the internet on how to build almost any type of system, just have to find what you like and what your budget allows.
  10. Sep 6, 2019 at 2:39 AM
    Adam New Member
    Yes, unless you have a DSP the thing will sound like shit. The problem is now, you have to go back and figure out the rats nest of how those guys installed the stuff. James can probably help you get a DSR1 for a few hundred and at least get it done correctly.
    Darkness likes this.
  11. Sep 6, 2019 at 2:58 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Had jls all around installed and kept the hu.
    Install was another 500 but sounds perfect
  12. Sep 6, 2019 at 3:11 AM
    Welcome from NY.
    Darkindustries[OP] and GNTundra like this.
  13. Sep 6, 2019 at 3:20 AM
    GNTundra
    Gino
    2013 White
    So you dont have the JBL system correct? If not the easiest would be upgrade the deck. :thumbsup:
    nvrgvup444 and (deleted member) like this.
  14. Sep 6, 2019 at 3:43 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    You're very rarely gonna get good adjustable sound levels if you only replace speakers, add subs, and add amps to a crap headunit. All sound and levels originate from the headunit. If it's shit to begin with (which the JBL is IMO) it's gonna be at the other end, no matter how many filters and crossovers you put the signal through. Upgrade your headunit to something that has infinitely adjustable levels for each speaker. Sound is very subjective, so you need the ability to adjust it yourself. I like the Kenwood headunits. They're a bit cumbersome to get the levels right, but once you do, you'll be rockin. You've got the speaker and amp setup. Now you need the brains of the operation. Good luck. I've been there. :frusty:
  15. Sep 6, 2019 at 3:59 AM
    Rubberdown
    Sounds as if you should spend time researching and find a stereo shop you can trust to redo your install.
  16. Sep 6, 2019 at 4:22 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    damn, dude.... that sucks.
    I installed a plug-and-play system for about $1500. checkout my install thread:
    https://www.tundras.com/threads/*********-system-1b-detailed-installation-and-reviews.29358/
  17. Sep 6, 2019 at 5:08 AM
    neirbot
    neirbot New Member
    I installed the OEM Audio system. Couldn't be happier.
    Sas likes this.
  18. Sep 6, 2019 at 5:25 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    this sucks OP. Unfortunately, at this point you might be better off starting over and re-installing everything yourself. As mentioned by another poster above, I would look into an Audiocontrol LC7i. They are cheap (between $150-$200) and make a world of difference when installing aftermarket amps/speakers while utilizing the factory HU.
    What others are saying about getting an aftermarket HU is correct; however, I have zero issues running my system with factory HU. It sounds perfectly good to me. Others are quite surprised when I turn it up. I went for 2x JL 10" subs and Alpine Type R components.
    Darkindustries[OP] likes this.
  19. Sep 6, 2019 at 6:11 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Only way to do it right, is to do it yourself. Everyone thinks they know what they are doing, but just like your reality, they don't.
    You can do this yourself, it is not rocket science. There is a ton of help here too.
  20. Sep 6, 2019 at 7:15 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's the sad truth these days and I've seen it so often with stereo shops.
    Toyotoholic[QUOTED] likes this.
  21. Sep 6, 2019 at 7:24 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
  22. Sep 6, 2019 at 8:00 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    The problem is the people that use them don't know how to do the install themselves and they get taken advantage of. I have done several including my Tundra. It is not that difficult especially in today's world. Crutchfield and other sources are your friends.
    Darkness[QUOTED] likes this.
  23. Sep 6, 2019 at 8:05 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Lc7i is a good, i went with the JL Fix86 for my dsp. Its a little more money (i think around $300), but it will automatically flatten out your sound curve that comes from the factory head unit (which is what you want to do). Another option (and may be a better one at this point), is ditch the factory head unit, and put in an aftermarket kenwood or pioneer. The factory head unit applies a sound curve to make the speakers they used sound best, you dont want that, you want flat. You would be able to accomplish that with a an aftermarket head unit, a JL Fix86, or a Rockford Fosgate Dsr1 (if you go with this, get it from tech12volt, he sets it up for you before it leaves the shop).
    Like some others have said, i highly recommend talking with James Taylor at Tech12Volt (he's in Alma GA if you are close to him, just make an appt and go there). He specializes in tundra stereos, and has some killer prices too (not just for stuff on his website, he can get anything you want). I bought about 90% of my stereo from him, great guy to work with. He's a busy guy, so dont expect a novel in response or him to spend 2 hours on the phone with you, he's to the point and knows tundra stereos! His email is: tech12volt@gmail.com
    It sucks that this happened. It sounds like its a little more common, shops just upsell you stuff that you gear that you've never heard of but they swear buy it (probably because its cheap shit, and they are making a killing). The best thing to do is buy your equipment and install yourself. I did my entire install in 1 day. Its not very difficult. Here's a link to my stereo build https://www.tundras.com/threads/the-stereo-slow-build-begins.17397/
    couldn't be happier with the stereo.
    Darkindustries[OP] and Kerch71 like this.
  24. Sep 6, 2019 at 12:06 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Agree it isn't hard, especially now with youtube. It was harder before the internet, I remember putting Solo Barrics in my baja bug in '99 with no sort of plug in harnesses lol. I recently gave my 21 year old cousin a sub and amp, he went ahead and got door speakers and a 4 channel while he was at it. We installed all that together with me teaching him along the way. During the whole job he kept saying maybe we I'll just pay a shop, it's a lot of work. By the end he had it figured out. Now hes getting ready to uninstall that and move it to his new truck by himself. He isn't the handy type but he has the one thing it takes and that's the will to learn.
    That doesn't mean when you go to one and pay for "professional install" you should accept a shit job. The trade, if we can call it that, of car audio is just so filled with hacks and that is upsetting.
    OP, drop some honest yelp or google reviews on those shops for how they left you, hopefully prevent others from getting burned. Do some studying and dive in yourself, that's the best plan. You may snap a door fastener or two but your stereo will work right when you're done and you'll appreciate it more.
  25. Sep 6, 2019 at 12:26 PM
    Danimal86
    Daniel
    Sacramento, CA
    the fucking truth right there!!!!!!!!!!!!!!!!!!
    Watt maker and Darkness[QUOTED] like this.
  26. Sep 6, 2019 at 2:05 PM
    Darkindustries
  27. Sep 6, 2019 at 2:06 PM
    Darkindustries
    Order extra door fasteners* noted lol.
    Yes I am going to leave a review on Yelp.
  28. Sep 6, 2019 at 2:14 PM
    Darkindustries
    The JL fix86 seems like it is exactly what I need. Looking at it online closely, (the outputs I understand go to each individual amp) I can see it has some custom adapters to plug the inputs in, where do these come from?
    I am in (either) NV or CA unfortunately so tech12volt is a little out of reach.
    I almost set an appointment with the Youtuber "5starCarstereo" in clearwater FL but my wife shut that ish down quickly.... but I appreciate the reply and advice.
  29. Sep 6, 2019 at 2:15 PM
    Darkindustries
  30. Sep 6, 2019 at 2:16 PM
    Darkindustries
    Thank you :)
