Auburn Pro Series LSD
Discussion in 'Performance and Tuning' started by Stevie442, Sep 22, 2018.
  1. Sep 22, 2018 at 8:45 AM
    Stevie442
    Stevie442 [OP] New Member
    2016 Tundra 1794
    Stock
    For those that have done this swap/upgrade what parts besides the differential were needed?
    Thanks in advance
    Mountun Goat likes this.
  2. Sep 22, 2018 at 9:23 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    I would seriously consider new gears. 4.88 are fun even with only one size bigger tires.
    But if you don’t want new gears you will need to get new bearings either way. Even if they aren’t destroyed taking them off the old carrier, I wouldn’t run the old bearings.
  3. Sep 22, 2018 at 12:09 PM
    Stevie442
    2016 Tundra 1794
    Stock
    Did you change the gears in the front too?
    So differential,bearings and fluid is all that’s needed to do the job?
  4. Sep 22, 2018 at 12:11 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  5. Sep 22, 2018 at 12:12 PM
    Yes, you need to match the gear sets.
    Yes sir. Master rebuild kits
    1UPPER likes this.
  6. Sep 22, 2018 at 12:18 PM
    Grumpy Uncle
    Pat
    CO
    dirty deeds has everything you need, that's where I got mine.
  7. Sep 22, 2018 at 12:26 PM
    Stevie442
    2016 Tundra 1794
    Stock
    Thanks
    Grumpy Uncle likes this.
  8. Sep 22, 2018 at 12:37 PM
    Another easy one....
  9. Sep 26, 2018 at 8:43 PM
    captainnemojr
    captainnemojr New Member
    2024 Tundra Platinum HV 4x4 TRD OR
    This is probably my next mod. I’ll skip the gears though because I’m running stock size tires. I just changed them to KO2s. I enjoy wrenching but this one I’m getting a pro.
    Rex Kramer and Mountun Goat like this.
  10. Dec 5, 2018 at 11:12 PM
    Liferider98
    Liferider98 New Member
    2018 tundra DC magnetic grey
  11. Dec 6, 2018 at 5:23 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    upload_2018-12-6_8-14-15.jpg 3 oz of additive for every quart of gear oil. You will need to buy an extra bottle of additive, the lsd Pro comes with a 6 oz bottle upload_2018-12-6_8-13-26.jpg
    Bearing/shim kit.
    You can reuse the ring gear bolts, but if you want to swap out for new ones, you will need 12 of them.
    Good luck. I really like knowing I have the extra traction and it helps a lot when off roading. Also, it works seemlessly with out traction control.
    Mountun Goat and RitcheyRch like this.
  12. Feb 6, 2019 at 5:22 PM
    fishmando
    fishmando New Member
    I have one, but I'm curious about what you mean. It works seamlessly without traction control?
  13. Feb 6, 2019 at 5:47 PM
    War Machine
    War Machine SSEM # 5 3MW
    one4x4dad and Mountun Goat like this.
  14. Feb 7, 2019 at 8:15 AM
    swank501
    swank501 New Member
    2007 single cab 4x4
    TRD S/C Crewmax window conversion Auburn LSD Custom interior
    Think he means you can light up both tires when you turn TC off.
    Also second getting new bearings. Mine got trashed when i did the swap. The cage is unsupported on the bottom of the tapered bearing, so it tends to deform whenver you try to remove.
    Mountun Goat and NjPro like this.
  15. Feb 7, 2019 at 6:03 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    @swank501 is correct. That is what I meant. I have had this installed for a few months now and I’m really glad I did. I do some mild off-roading and in spots where 4wd was needed in the past, I can make it either up or through the obstacles without 4wd now. One thing I have notice is, when the roads are wet and I’m making a hard turn I will get a bit of a shutter in the rear because one wheel is trying to catch up to the other. The shutter is mild, doesn’t happen all the time when the roads are wet and never happens when the roads are dry. With all the nannies off, you can absolutely leave two nice marks.
    Mountun Goat and TXTundra2722 like this.
  16. Feb 8, 2019 at 11:58 AM
    fishmando
    Well mine did work as you described, with the nannies off. But not anymore. I can just sit and spin one tire now, 10 month in to ownership, and I only drive this thing on the weekends.
  17. Feb 9, 2019 at 5:36 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    @fishmando
    Only 10 months, that sucks. Mine is less then 5 months old. What kind of gear oil did you use ?
  18. Feb 9, 2019 at 5:48 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Before I ordered my Auburn LSD I’d asked them which model and the oil they recommended. They did not recommend a synthetic oil because it can lead to faster wear. I was surprised to hear that but I followed their suggestions and all had been great so far.
    Auburn rear differential
    High performance differential limited slip
    10 1/2 12bolt
    Part number:
    5420134
    36 spline axial
    Non synthetic oil
    80-90 Weight oil with additive
    You can see the full bearing replacement set by G2 on top of the Auburn LSD box.
  19. Feb 9, 2019 at 5:55 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    This it exactly what I was told to use by Auburn when I spoke with them. I’m wondering if he used synthetic oil.
    1UPPER likes this.
  20. Feb 9, 2019 at 5:59 AM
    1UPPER
    TEXAS
    Flux capacitor!
    NjPro likes this.
  21. Feb 9, 2019 at 6:28 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Good to know about this mod thanks @1UPPER an @dirtydeeds. An @ColoradoTJ
    1UPPER[QUOTED] likes this.
  22. Feb 9, 2019 at 6:47 AM
    fishmando
    I had a mechanic install it, so I just left him a message. TBD if the correct oil was used, thanks for the input family. This forum has been great!
    Edit, the shop used the correct oil. No clue why this thing failed so fast, but hoping Auburn will answer that.
  23. Apr 23, 2019 at 5:08 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    @fishmando Did you ever get a response from Auburn.
  24. Jun 11, 2019 at 7:45 PM
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    Any update on this?
  25. Jun 11, 2019 at 8:27 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
  26. Sep 27, 2019 at 3:05 PM
    Klappy803
    Klappy803 New Member
    Andrew
    Wisconsin
    Where did you get the bearing/shim kit from?
  27. Sep 30, 2019 at 2:56 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I remember reading a thread here about a year ago where alot of guys with Auburns had them wear out very quickly. I was all set to buy one until I read that thread.
    RitcheyRch likes this.
  28. Sep 30, 2019 at 3:27 PM
    TXTundra2722
    2015 Black Tundra
    Yes and I don't understand that either. It cost an arm and a leg just for installation.
  29. Sep 30, 2019 at 3:37 PM
    Grumpy Uncle
    Pat
    CO
    No problems with mine, been in almost 2 years.
  30. Sep 30, 2019 at 4:42 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    There is now another option on the way from powertrax
