Auburn limited slip
Discussion in '2nd Gen Tundra Parts Marketplace (2007-2013)' started by Hbjeff, Oct 2, 2022.
Thread Status:
Not open for further replies.
  1. Oct 2, 2022 at 7:40 PM
    Hbjeff
    Hbjeff [OP] New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I bought this a while ago from this forum, got so busy during covid from work I never got around to installing it. Now life just has other priorities. This thing is new in box
    located in orange county, preferably local sale
    $350
    C0E7100C-FF38-4C12-B501-8AD2BB8FA578.jpg 6BC9E927-896A-4151-9BE6-854B0E7C4854.jpg
  2. Oct 6, 2022 at 9:36 AM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    Bump
  3. Oct 7, 2022 at 8:58 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    any idea on how complicated the install is or how much it would cost to install?
  4. Oct 7, 2022 at 11:03 AM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    Not sure. To install you need the tools to reshim the ring gear properly
  5. Oct 7, 2022 at 11:56 AM
    blenton
    blenton New Member
    The installer got lucky installing mine; he was able to reuse the factory bearings and shims to get it in spec. That was 100k ago and no issues.
    But what I’ve seen install run i these is $300-700 depending on where you are at. You can DIY, but if you have never been in to a differential before you might want to get some help or have it done by a shop. I paid a friend to “help” me do it so we could use his lift and his tools; he’s a driveline specialist so I saw little point in tackling it myself.
    Install requires you to lift the truck or put it up on Jack stands, remove the rear tires, brakes, rotors, parking brake cables, and speed sensors. Drain the diff fluid then unbolt the axle retainer and pop the axle shafts put with the bearing attached. You can slide them out a few inches instead of completely removing them. Unbolt the differential housing and heft out the nearly 100 lb chunk of center section.
    The you get to the hard part of disassembling the actual differential, ring gear, and pinion. Luckily you can pattern and test lash on the bench, but that requires some precision tools and know how. Voodoo, really, but know how is a polite way to say it. Then reassemble.
    Terndrerrr, Luckydog and Hbjeff[OP] like this.
  6. Oct 7, 2022 at 4:06 PM
    blenton
    blenton New Member
    The Auburn LSD is one of the best mods I’ve done to my truck, BTW. If you are thinking about getting it, this is a steal of a deal. I’m resisting the temptation to buy it off @Hbjeff for just in case my Auburn wears out. I’m outside the Drex program or whatever Auburn calls their replacement program. Zero regrets buying and installing it for everyday driving including inclement weather and light trail use.
    k0diak8o8 and SavageTrd like this.
  7. Oct 13, 2022 at 6:06 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    k0diak8o8 and Terndrerrr like this.
  8. Oct 13, 2022 at 7:07 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    A good compromise would be pulling the third yourself and having a shop do the the gear setup.
    I did one on a Ford 8.8 once. I had a shop press new bearings and the ring gear on for me. I bought a HF dial setup to check the lash - it was a dead match to the stock measurement with the original shims. I didn't worry about the pattern because the pinion didn't move and the Torsen I installed was a factory upgrade. Probably not best practice, but it worked for me.
  9. Oct 21, 2022 at 9:06 PM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
  10. Nov 4, 2022 at 10:08 PM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
  11. Nov 5, 2022 at 1:48 PM
    SavageTrd
    SavageTrd Trd Savage
    GEORGE
    San Diego
    2012 tundra
    Supercharge, 6in lift, 37x12.50x18 on method wheels mr301, wilco tire carrier,
    Still available
  12. Nov 5, 2022 at 1:55 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'm interested, researching if it's usable in a '13 Sequoia.
  13. Nov 5, 2022 at 1:56 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    I will take it if savage dosen't, if you don't mind shipping it.
  14. Nov 5, 2022 at 2:43 PM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    Yup
  15. Nov 5, 2022 at 3:30 PM
    blenton
    blenton New Member
    It’s not, unfortunately, else I would already have one in mine… The sequoia uses a 10” ring gear instead of the 9.5” (4.6L) and 10.5”(5.7L) of the tundra. There is one option available, but it’s a locker and pretty spendy. It’s an Auburn Select-A-Lock available from Tandem Off-road. You can follow the development thread here.
    https://forum.ih8mud.com/threads/its-finally-happening-2nd-gen-sequoia-locker.1235988/
    e30cabrio[QUOTED] and Terndrerrr like this.
  16. Nov 5, 2022 at 4:24 PM
    e30cabrio
    Thanks, That is who I asked (Tandem) :p
  17. Nov 7, 2022 at 9:02 PM
    TundySauce
    TundySauce New Member
    Josh
    2020 Quicksand Toyota Tundra SR5 Off Road
    Accutune Fox 2.5’s coilovers and shocks ARE Camper Shell Nitro Ridge Graplers Fuel Wheels
    I am interested. Could you text me tmrw at 951-551-7313?
  18. Jan 23, 2023 at 5:15 PM
    Somemedic
    Somemedic New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    I would have thought the SR5 would have come with a LSD with the electronic traction control that's on it.
    I had a Powertrax installed on my 2000 and it was like it wasn't even there. There were no ABS parts on it however.... how do I co firm this fits my axle?
  19. Jan 23, 2023 at 7:26 PM
    Hbjeff
    Huntington Beach
    2010 DC 5.7 2wd
    If you have the 10.5 axle it fits
  20. Jan 26, 2023 at 7:52 PM
    blenton
    blenton New Member
    If you have the 5.7L motor, it fits. If you have the 4.7, 4.6, or 4.0, it does not fit.
    Somemedic likes this.
Thread Status:
