ATF overflow bolt
Discussion in '1st Gen Tundras (2000-2006)' started by Seepick1, Mar 29, 2025.
  1. Mar 29, 2025 at 2:59 PM
    Seepick1
    Seepick1 [OP] New Member
    VA
    2006 SR5 Double Cab 4.7L
    I am positive it is somewhere in here, but have found part #'s for every bolt other than the transmission fluid check/overflow bolt.
    Even tried several oem or dealer suppliers, I keep getting redirected to other bolts.
    For the love of God, can someone confirm the part number or a link to this bolt.
    Toyotapartsdeals will sell them in a pack of 10 only.
    Thanks
  2. Mar 29, 2025 at 8:00 PM
    Never order from ToyotaPartsDeal. Toure gonna get screwed.
    Those are the only two you need? You strip your old ones or something?
  3. Mar 29, 2025 at 11:11 PM
    Seepick1
    VA
    Not stripped. The drain bolt was able to be removed and reinserted, but it is corroded.Not sure about the overflow bolt. It is badly corroded and I'm 90% the hex will strip if I try to turn it. Would rather have a replacement before I try.
    Side note, dealership parts dept was closed on a Saturday before I could call them.
  4. Mar 30, 2025 at 8:42 AM
    That's OK, they'd probably give you the wrong parts anyway. And I say that for a couple of reasons.
    One, I checked the EPC, and frankly, what the EPC is spitting out doesn't make a damn bit of sense, it doesn't appear to be the correct part to me
    Two, the parts numbers EPC spits out as 'actual' and 'substitute' appear to be 100% different from one another for the same part.
    Ultimately this was a tough one, I had to dig on the 5AT that's in our 2005-2006 trucks specifically, and found 90341-10021 appears to be the correct CHECK plug specifically. Drain plug matched between EPC and transmission parts breakdown, both show drain plug as 90341-10011 and its gasket/washer is 35178-30010.
    Those links take you to the Toyota Parts system so you can order at a discount for in-dealership pickup at participating dealerships. For me, that was $2/bolt versus $5/bolt. YMMV.
    ALWAYS verify part fitment before buying anything. @shifty` is not a dealership parts department.
    Seepick1[QUOTED][OP] likes this.
  5. Mar 30, 2025 at 11:00 AM
    Seepick1
    VA
    Thanks so much! Weird that it's so hard to narrow down
