ATF Check With ATF Cooler. How?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TravisH, Jul 31, 2023.
  1. Jul 31, 2023 at 5:11 PM
    TravisH
    TravisH [OP] New Member
    Travis
    2019 Tundra TRD Off Road Double Cab
    None
    Hi,
    I installed an aftermarket ATF cooler with genuine Toyota parts last year.
    I can't recall how to check the ATF level......Do I pin the thermostat or remove?
    Thanks!
  2. Jul 31, 2023 at 5:16 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    No... You only pin it for drain and fill. You will need to look for the check level PDF or youtube video on how to the procedure has to go. Temp and OBD pin jump.
  3. Jul 31, 2023 at 6:45 PM
    TravisH
    Travis
    None
    Cool!
    I know about ODB and temp or the other tricky temp procedure too.
    So leave unpinned and proceed as usual!
    Thanks!
    blackdemon_tt[QUOTED] likes this.
  4. Jul 31, 2023 at 7:58 PM
    blackdemon_tt
    yeah, otherwise it will dump that additional quart of fluid, just ask me how I know. lol
    Mike59 likes this.
  5. Jul 31, 2023 at 9:48 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    @blackdemon_tt is mistaken, you need to pin the thermostat in order to check the level, that's actual why that pin exists. This is the video from @Genuine Cooling Systems I started it at the check procedure for you.
    https://youtu.be/Ep5CNhdMnhE?t=2808
  6. Aug 1, 2023 at 5:31 AM
    blackdemon_tt
    I stand corrected.
    Pig Rig and Joe333x like this.
  7. Aug 14, 2023 at 11:12 AM
    TravisH
    Travis
    None
    Joe333x[QUOTED] likes this.
  8. Aug 14, 2023 at 1:13 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    An even easier way is, drain the pan and re-fill with 4 quarts. That's pretty much what come out. At the end of the day no one really knows what a trickle is on the check plug and +/- a few ounces won't hurt anything.
  9. Aug 14, 2023 at 2:05 PM
    Joe333x
    Joe333x Member
    Boston
    If you have added a cooler its actually closer to 4.5 quarts.
  10. Aug 14, 2023 at 5:42 PM
    pursuit2550
    Only when adding it. After that, only what's in the pan will come out. The OP already has the cooler installed. So about 4 quarts is all that will come out. I have did the whole level the truck out, temp and trickle thing. After I read about the 4 quart oil change, no more. You would think Toyota would have made it a bit easier to do an oil change.
    Mike59 likes this.
  11. Aug 14, 2023 at 6:07 PM
    Joe333x
    Joe333x Member
    Boston
    Not true. I just did my first drain and fill since installing the 20 row Setrab last year and I had done drain and fills before adding the cooler which were about 4qts now with the cooler I drained out about 4.3qts and then put 4.5 back in and did the check process and about .2 came back out. When you pin open the thermostat that extra fluid drains down into the pain from the cooler. This is why I always do the check process, it takes maybe an extra 15 minutes to do and Im only swapping fluid once a year so I can spare the extra time to make sure its correct.
    nobodyintexas likes this.
  12. Aug 14, 2023 at 6:15 PM
    pursuit2550
    Here is how I do it. Truck cold and on level ground. Remove drain plug. Let it drain. Install drain plug. Remove fill plug. Add 4 quarts. Install fill plug. Done. No need to warm up the tuck, check temp or pin the t-stat. Simple and sweet.
  13. Aug 14, 2023 at 6:26 PM
    Joe333x
    Joe333x Member
    Boston
    Gutcha, I was just replying to the OPs question on how to properly do the level check. I've done it your way in the past as well but then I got proficient with doing the level check so now I do it every time. Makes me feel more confident knowing that I checked it and that its correct.
  14. Aug 14, 2023 at 6:29 PM
    pursuit2550
    Yeah my think is the whole trickle thing with Toyota. If you leave it, it will trickle forever. Since I found the post about the 4 quarts I said, I am done messing with the trickle. I did it to my wife's Lexus and 2 quarts came out so that what went back in.
  15. Aug 14, 2023 at 6:37 PM
    Joe333x
    Joe333x Member
    Boston
    Yeah it will trickle forever but thats why you're supposed to put the check bolt back it when it starts to trickle. I let it come out until the flow is too weak to go straight down and starts to flow down the pan, thats what I have deemed a trickle anyway.
  16. Aug 16, 2023 at 7:17 AM
    TravisH
    Travis
    None
    So...
    Does the pan hold 4 qts? Doesn't look like it would....Seems like you'd have to have the truck running to circulate. If you crack the filler with engine off and cold it will be fuller than hot and running right?
  17. Aug 16, 2023 at 7:58 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    this. I too have a trans cooler.
    overfill it a bit*...do the check process. stop at a trickle. then you know you have it right.
    3.8 come out of mine or thereabouts....I put back in 4-ish quarts. warm it up....do the check process. I'm done.
    *put in a bit more than came out...us a catch can that has measurements on it.
  18. Aug 16, 2023 at 8:14 AM
    TravisH
    Travis
    None
  19. Aug 16, 2023 at 8:16 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    same stuff, maybe better.
    I've used it for years.
  20. Aug 16, 2023 at 8:21 AM
    TravisH
    Travis
    None
    Can you mix with older Toyota ATF? Don't like fooling with tranny's (haha!) and like it stock (haha!)
  21. Aug 16, 2023 at 8:21 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yup.
    I have 3 Toyotas.
  22. Aug 16, 2023 at 9:00 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    No, you need the Toyota WS ATF.
    I personally use non-OEM fluids on my vehicles, Mobil 1, Valvoline, Castrol, etc., EXCEPT of the ATF fluid. ATFs are paired with fluids that have specific friction modifiers. I use the OEM WS.
    https://www.amazon.com/Genuine-Toyo...t=&hvlocphy=9027630&hvtargid=pla-525199342009
  23. Aug 16, 2023 at 11:46 AM
    pursuit2550
    More or less. It doesn't matter if you're over or under by a bit, it won't hurt anything. Think of it like a normal engine oil change. Pull the plug, drain it and put back what came out. Simple. Toyota could have made it simple to check the trans oil but why do that. Let's make it so that we confuse people and they have to come to the dealer.
    Mike59 likes this.
  24. Aug 16, 2023 at 1:10 PM
    march
    march New Member
    Maybe - I just did drain & fill. Drained 3.5 qts. - added 4 qts., brought trans. to correct temperature to check level according to proper procedure and nothing came out of the excess fluid drain plug. Added another quart (now 5 total) and about 1/2 quart came out. Transmission was approx. one and one half quarts low from factory. Way better to check level according to correct procedure. Check video above.
    Mike59 and nobodyintexas like this.
  25. Aug 16, 2023 at 1:11 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    This is the way
    and the only way to confirm if you are at proper level
  26. Aug 16, 2023 at 1:41 PM
    yamasaki450
    yamasaki450 New Member
    15 Tundra 4x4 limited
    Mine was the same way. I added 4 quarts, set truck in maintenance mode and waited until trans got up to correct temp and nothing came out. Mine held about 5 quarts before any fluid came out
  27. Aug 16, 2023 at 2:22 PM
    pursuit2550
    That's fine, but once you have varied that it's at the right level, put back what came out. It's to rocket science. The trans holds 12 quarts I believe, if you drain 3.5-4 quarts and put back 3.5-4 quarts, it will have 12 quarts in the end.
  28. Aug 16, 2023 at 2:23 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    not quite.
    what if it was low before you started?
    Pig Rig likes this.
  29. Aug 16, 2023 at 2:31 PM
    yakeng
    Given a new transmission may put you out of service for months and cost you over $7K, I think it is worth an additional 15 minutes to do the procedure by the book. Just my 2 cents.
  30. Aug 16, 2023 at 2:35 PM
    pursuit2550
    Texas, read what I wrote again. Once you do the temp and trickle level check and you know it's at the correct level, then after that every time you do an oil change, just put back what came out. Unless you have a leak, the level should stay the same. So, like it been said before on here, about 4 quarts is what normally comes out, so just put 4 quart back. +/- isn't going to hurt anything. Now if you're doing a flush every 5k till you have flushed out all 12 quarts, I just find the 4 quart method easier. If you doing just a drain and fill every 30-60k then the temp and trickle works just fine since its once in a blue moon.
    Pig Rig likes this.
