ATF Change Now 2nd, 3rd Gear Slippage
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ironhead80, Nov 7, 2022.
  1. Nov 7, 2022 at 8:29 AM
    Ironhead80
    Ironhead80 [OP] New Member
    2011 Tundra TRD
    Hey All - I recently changed the ATF on my 2011 TRD. It was the correct fluid (WS) and amount (2.1 quarts). Now, it takes a few miles for everything to "warm up" otherwise the trans appears to slip a bit in 2nd or 3rd gear. Is there anything electronically that should be done when changing the ATF? Any reprogramming? All I have done is change the fluids so not sure what would be needed...seems odd it would require anything like this?
  2. Nov 7, 2022 at 9:06 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    2.1 quarts? How did you do it? Ive never had a change that small
    AZBoatHauler likes this.
  3. Nov 7, 2022 at 9:08 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Did you check the level with it at the correct temperature?
  4. Nov 7, 2022 at 10:45 AM
    Ironhead80
    2011 Tundra TRD
    Hey all - thanks for the replies. I did check when fully warmed up and it was slowly coming out the overflow plug. From the manual it said 2.1 quarts and they confirmed at the dealership. As far as procedure, I have a hand pump that I use to pump it into the overflow hole. So is everyone thinking it’s just not enough fluid?
  5. Nov 7, 2022 at 10:57 AM
    Ironhead80
    2011 Tundra TRD
    Not a lot. It was more like weeping out.
  6. Nov 7, 2022 at 11:01 AM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Where are you getting 2.1 quarts from as it relates to the transmission?
    The entire trans holds about 12 quarts and the pan holds about 4.
    99.9% certain you have a fluid level(either too much or too little) problem.
    TXTundra2722 likes this.
  7. Nov 7, 2022 at 11:12 AM
    Ironhead80
    2011 Tundra TRD
    2.1 for the pan was from the manual and the dealership confirmed when I went to purchase the WS fluid. I guess they were wrong…???
  8. Nov 7, 2022 at 11:14 AM
    TXTundra2722
    2015 Black Tundra
    I second the above statement..... where did you get 2.1 quarts from? Did you collect what drained out for measurement? Edit..I was slow on the response..I second @Larly5000
  9. Nov 7, 2022 at 11:16 AM
    AZBoatHauler
    So.Arizona
    I’m confused when you say “overflow”. There is a drain plug, a check plug, and a fill plug. They should have all been utilized at different stages of the process. Agree with everyone there is no circumstance where 2 qts would be the proper amount to refill anything. If you were trying to fill the trans through the check plug, I could see where that would be a disaster.
    snivilous likes this.
  10. Nov 7, 2022 at 11:17 AM
    AZBoatHauler
    So.Arizona
    I get 4 every time I drained the pan.
  11. Nov 7, 2022 at 11:17 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Do you have a V6?
  12. Nov 7, 2022 at 11:34 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    whats the total mileage on the truck and is this the first time you are doing a drain and fill on the tranny?
  13. Nov 7, 2022 at 11:34 AM
    Ironhead80
    2011 Tundra TRD
    This is for a 5.7 liter V8. There is only a drain plug and the check/fill plug.
  14. Nov 7, 2022 at 11:38 AM
    MadMaxCanon
    There is also a fill plug further up. What everyone here is saying is correct, you should have gotten almost 4 quarts out. Its possible you have a leak, or it was underfilled to begin with.
  15. Nov 7, 2022 at 11:52 AM
    AZBoatHauler
    So.Arizona
    Look on the driver’s side towards the front above the pan. The bolt head has “WS” stamped on it.
  16. Nov 7, 2022 at 11:54 AM
    snivilous
    SW UT
    You must have the 6 speed? The fill plug is up on the drivers side of the transmission. With that said, if you filled it through the check the tube I guess I don't see why that wouldn't work as long as the level was properly checked still. And you went through the whole shifting procedure and everything and pinned the thermostat open?
    Your symptoms and experience just really sound like the fluid level is wrong, and hopefully that's all it is since the alternative is far worse. I would check the fluid again, maybe start off with an extra few ounces of fluid in it first so it's slightly overfilled and then check the level again.
    ColoradoTJ likes this.
  17. Nov 7, 2022 at 1:56 PM
    Ironhead80
    2011 Tundra TRD
    Hey All - I made a trip to the local Toyota dealership and bought two more quarts of ATF WS. I used the actual filler plug this time (haha) and took it for a test drive. No slippage! All is well.
    Thanks to everyone for their advice and input(s)!!! Kind of concerning, though, that the Hanes manual said it would take 2.1 quarts and the dealership agreed (maybe don't use this dealership anymore?).
  18. Nov 7, 2022 at 2:39 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Here's a bit of a primer for the OP on how the process should be done.
    agrestic1 and Black Wolf like this.
  19. Nov 7, 2022 at 3:26 PM
    MadMaxCanon
    very strange seeing as how even the differentials take more than that amount.
  20. Nov 8, 2022 at 7:04 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    In the manuals, Toyota even had the ATF amount wrong for the first gen Tundras. So, I honestly don't trust what Toyota says anymore with regards to exact ATF amounts, and its not surprising that its published incorrectly for the 2007+ Tundras. I don't remember the numbers, but it was a similar in that the book showed half the fluid that the transmission actually needed.
    Do the published drain, refill, and fluid level check procedure and you'll be ok.
