ATF Burned!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Sep 20, 2020.
Thread Status:
Not open for further replies.
  1. Sep 20, 2020 at 1:42 PM
    Greg Marmalard
    Greg Marmalard [OP] New Member
    2019 Tundra TRD Off Road Double Cab
    Howdy!
    So I installed Nick's ATF cooler kit today! Attached is my ATF and some fresh for reference...
    I towed a 25' Airstream ~7000 payload throughout desert southwest this summer. I was in temps as high as 105°++ and hit plenty of passes...
    When I did monitor temps I was hitting almost 260° on long 4% up hill grades at 90°... I was hitting longer 6% grades on hotter days but didn't monitor temps those days..
    I had topped off the ATF earlier this year before towing and it was almost as new...
    What do you think? It has a cloudy appearance when poured...
    betotundra likes this.
  2. Sep 20, 2020 at 1:42 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Send it for analysis
    Cpl_Punishment likes this.
  3. Sep 20, 2020 at 2:21 PM
    slongo
    slongo New Member
    2017 Tundra in Barcelona red
    Side Steps - bed cover - matte black splash graphics
    It is burned thats for sure - How was the filter ? Any metal in the pan ?
  4. Sep 20, 2020 at 2:33 PM
    Cfincke
    San Antonio
    To confirm, were you only seeing 160 on the trans temp? Or did you mean 260 degrees?
    I have an Edge obd2 gauge display, and I see 180-185 during normal daily driving after 20 minutes on the highway. When towing a 26 foot, 6k camper, i see around 200. I am regeared with 5.29s. Before gears I would see 210-220 when towing.
  5. Sep 20, 2020 at 2:35 PM
    Greg Marmalard
    260°. Sorry fixed that...
  6. Sep 20, 2020 at 2:42 PM
    Cfincke
    San Antonio
    You are lucky to only have seen 260 with a 2019. I am sure you have seen the 2 or 3 large threads about the 2019 and up not having a trans fluid cooler which leads to overheating of the fluid when towing. There is a member here in San Antonio that has had the trans temp warning light come on multiple times. I beleave the temp setting for that warning is at 300 degrees, which is very hot for an oil. I have not followed those threads in a few weeks, but last descussion I recall was the trans oil starts to break down above 250.
  7. Sep 20, 2020 at 2:46 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    That does not look good! How did the install go?
  8. Sep 20, 2020 at 2:47 PM
    timsp8
    NY
    Yeah send it for analysis. That’ll be one way to know if the fluid can handle the temps that Toyota says it can.
    Txexplorer23 likes this.
  9. Sep 20, 2020 at 2:55 PM
    I'll pay for your analysis to be sent to Blackstone labs.
  10. Sep 20, 2020 at 3:32 PM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    This thread further reinforces the belief that the 2019's and 2020's are gonna be a serious problem for Toyota long term.
    The sooner an aux cooler is installed, the better.
    Mine went on before I hit 4000 miles and the fluid still looked new.
    I also pinned the Tstat open fulltime and plan to leave it that way.
    Any of you still on the fence... should get your wallet out and order one of Chase's kits ASAP.
    jetfishn, sask3m, RitcheyRch and 2 others like this.
  11. Sep 20, 2020 at 3:36 PM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    If that were my truck I would have the dealer flush, drop the pan and install new filter and refill with fresh fluid. I would also have them document the condition of the fluid because you may be dealing with a powertrain warranty claim in the future.
    jetfishn, RitcheyRch and Blue Thunder like this.
  12. Sep 20, 2020 at 4:03 PM
    Greg Marmalard
    Install was a piece of cake! Yer a genius! Thanks for being so detailed in the instructions!
    I opted not to drop skid plate (TRD Pro one piece) and got lucky as hard lines fell right into place! Basically took a little over 2 hours.
    I took it for a run out here in Tucson. Temps ~100° I hit 85mph up slight incline. ATF temp 179°. When getting off and hitting stop light; idling it spiked to 194° and dropped back to 180° when going 35mph.
    Compare that with 75° days going 65mph on similar terrain and getting 230°.
    Shifted like a champ! No issues...aside from the burnt ATF! More on that to come after I send in to Blackstone tomorrow!
    Thanks!
  13. Sep 20, 2020 at 4:06 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I have read on other forums that Toyota ATF turns dark really fast. So dark doesn't necessarily mean burned. I do agree with others that you should send it to Blackstone labs.
  14. Sep 20, 2020 at 7:57 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Send your sample through UPS or fed ex. I sent mine through USPS and it took about 6 weeks to make it there.
  15. Sep 20, 2020 at 8:49 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Watching thread for the follow up. Very interested in the results
    Alex38, YardBird and GODZILLA like this.
  16. Sep 20, 2020 at 8:56 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Eh honestly that fluid doesnt look too uncommon for anything with over 30k miles honestly.. the WS fluid looks like hell really early on. i do a drain and fill every other oil change on all my cars that have it. lol
  17. Sep 21, 2020 at 3:56 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  18. Sep 21, 2020 at 6:30 AM
    Greg Marmalard
    Cool!
    I'm sending it in today!
    Not sure how long it takes to get back but I'll certainly post results!
  19. Sep 21, 2020 at 7:06 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    What will you do when the results say the oil is fine?
  20. Sep 21, 2020 at 7:21 AM
    jsquared22
    jsquared22 _________________
    2018 White Tundra Platinum
  21. Sep 21, 2020 at 7:25 AM
    Greg Marmalard
    Smile!
    :D
    Question is what if it's bad?! I'm absorbing the cost of the ATF cooler but Toyota is going to have to answer on some level about this.
    I seriously doubt it's "fine" I towed across the Mojave this summer. Up Cajon Pass in 90°+. Up I-40 to Flagstaff in 90°++.
    If I got 260° on a 4% grade in 90° you can rest assured I pushed past that both in grade slope and time....
    bvia and Txexplorer23 like this.
  22. Sep 21, 2020 at 7:27 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    No no no no no...
  23. Sep 21, 2020 at 7:34 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Found the comment at about 3:23 to be interesting as it goes along with the image of Toyota WS....
    Jtundra81, Justbass, Rbohno and 6 others like this.
  24. Sep 21, 2020 at 7:17 PM
    Vizsla
    Vizsla pretend2send
    I’ll add, have access to how the transmission is programmed and learning lots. The fluid will be dark regardless of brand, we have flex lock torque converter to improve fuel economy. Torque converter has the ability to partially lock, leaving it in a constant slip scenario resulting in the color. Early on in Tundra production the torque converter clutch material had to be changed due to partial lock shudder. I would never use anything but WS fluid after seeing how the transmission operates.
  25. Sep 21, 2020 at 7:24 PM
    Tundrafan23
    Tundrafan23 New Member
    Well, by adding the cooler you just voided any future claims you had towards warranty work on your transmission.
  26. Sep 21, 2020 at 7:31 PM
    timsp8
    NY
    He said it took about 2 hours to install. Can probably be removed in half that time. Toyota would never know. Plus there are reports of people with one going in and the techs don’t even notice it.
  27. Sep 21, 2020 at 7:40 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    How did you operate the transmission? Meaning, left it in D or downshifted manually to S5 or S4?
    koditten likes this.
  28. Sep 21, 2020 at 7:53 PM
    koditten
    Kirk
    Midland of the Mitten
    I was wondering this as well.
    If I was making that same trek, I'd be locked to 4th gear.
    AZBoatHauler likes this.
  29. Sep 21, 2020 at 8:47 PM
    Tundrafan23
    I'm not saying his entire warranty will be voided, but if he goes in for a tranny issue they will certainly refuse to cover that under warranty. I don't agree with it, but you are kind of forced to play their games regarding "modifications". He certainly could take it off.
  30. Sep 21, 2020 at 8:55 PM
    AZBoatHauler
    So.Arizona
    How would they know if he removed the cooler before taking it in?
Thread Status:
