At what point are diff drop and carrier bearing kits necessary?
Discussion in 'Suspension' started by SLOWER, Feb 21, 2020.
  1. Feb 21, 2020 at 2:53 PM
    SLOWER
    SLOWER [OP] New Member
    I have 5100 at the top setting and considering rear shackles.
  2. Feb 21, 2020 at 3:00 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    I have 5100's at top setting and Toytec shackles at 1.5 and I added a drop due to just wanting my drive line aligned with little to no angle. I did it very simple with SS washers and longer bolts. Easy
  3. Feb 21, 2020 at 3:02 PM
    nvrgvup444
    KCMO
    To answer your question correctly = if you have the shakes then do the drop.
    Toyotoholic likes this.
  4. Feb 21, 2020 at 3:22 PM
    SLOWER
    Looks like the +3 shackles include the carrier bearing kit. Do the diff drop as well?
  5. Feb 21, 2020 at 3:32 PM
    nvrgvup444
    KCMO
    Sorry, it looks like I said shackles, but I meant shakes / shaking when you are driving due to a bad drive line angle.
  6. Feb 22, 2020 at 5:06 PM
    rustytoys
    rustytoys New Member
    Shackles change your pinion angle from stock - there is no aligning that as long as the shackles are installed. If you are concerned about angles then blocks are the way to go.
  7. Feb 22, 2020 at 5:08 PM
    rustytoys
    The carrier bearing drop kit is like $30 and two minutes to install, its cheap and easy enough to just drop it regardless of if there is a noise or not.
  8. Feb 22, 2020 at 5:09 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I have 5100's at the middle setting with a front diff drop. Truck had a 3" kit when I bought it so it was on there already. With 1.5" lift up front I have little to no cv angle which I like. Took the block off the rear so I did not do a carrier bearing drop.
  9. Feb 22, 2020 at 5:28 PM
    I had to do the carrier bearing drop with a 2 inch block in the rear.
