AT Tire pressure in winter (cold snowy state people get in here)
Discussion in '2nd Gen Tundras (2007-2013)' started by Blue_Tundy, Dec 3, 2023.
  1. Dec 3, 2023 at 6:31 PM
    Blue_Tundy
    Blue_Tundy [OP] New Member
    Minnesota
    2010 BSM Tundra SR5
    Hello, I live in Minnesota and I’m getting new tires. I went with the Toyo AT3 getting them put on tomorrow l. We don’t have snow yet where I am but I’ve heard that you get better traction in the snow with lower tire pressures. What is a good recommended tire pressure for max traction in the snow?
  2. Dec 5, 2023 at 5:33 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I run 36 psi on my Wildpeaks regardless.
    Yes we live in Minnesnowta, but honestly, how often are you actually on snow pack?
    Blue_Tundy[OP] likes this.
  3. Dec 5, 2023 at 6:29 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Keep the correct air pressure. You should not air down for regular travel in snow. Stuck in a deep drift or off-road sure, but not for normal snow travel on roads.
    If the new tires are a different load rating or size vs the stockers, the air pressure needed will be different. Here is a good tool to get you in the ballpark of correct air pressure when switching to larger/smaller or different load rating tires.
    Blue_Tundy[OP] and GODZILLA like this.
  4. Dec 5, 2023 at 7:10 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    MN here. Same tire pressure you normally run.
  5. Dec 5, 2023 at 7:29 AM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    yep, same as the others, I run the same air pressure in the winter as I do in the summer
  6. Dec 5, 2023 at 1:35 PM
    Blue_Tundy
    Minnesota
    2010 BSM Tundra SR5
    Hey thanks everyone for the answers. I will run regular pressure!
