At the dealership, I'm scared.
Discussion in 'General Tundra Discussion' started by Rakso, Oct 9, 2019.
  1. Oct 9, 2019 at 8:50 AM
    Rakso
    Rakso [OP] Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Time for 12 month, 10k service.
    My truck only has 5300 miles, the
    First employee says: first time service, rotation and fluid check.
    I: not, it's been a year, you'll change the engine oil as well.
    First employee: oh you have an appointment let me get you to second employee.
    Second employee seems to know wtf is going on now.
    Two hr wait time, shuttle requested, I'm still here.
    I've always been skeptical about POS dealership work, but also not sure the warranty depends on where you serviced the truck. I usually start servicing my vehicles after the free stuff from dealership is over. As I previously read, gotta check if they actually rotated the tires and changed the engine oil. Should've marked the tires and oil filter.
    RPKEAN likes this.
  2. Oct 9, 2019 at 8:53 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    What dealer? What area of So Cal?
  3. Oct 9, 2019 at 8:54 AM
    Rakso
    Oskar
    What difference does it make? They all are shady AF.
    Moss Bross, Riverside
    GODZILLA likes this.
  4. Oct 9, 2019 at 9:05 AM
    Stevenson's Toyota East and West here in Denver are quite good. Not unusual to see service techs driving Tacos and Tundras here.
    CO_Native and MS22 like this.
  5. Oct 9, 2019 at 9:19 AM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    I will not do any business at Moss Bros.
    Went to buy a car and was ignored.
    I have had good luck with Toyota of Riverside, but like you have said all dealerships have issues.
  6. Oct 9, 2019 at 9:29 AM
    Rakso
    Oskar
    At least the shuttle showed up.
    Black Wolf likes this.
  7. Oct 9, 2019 at 9:29 AM
    computeruser6
    Dirk
    Escondido
    Not every service department is garbage.
  8. Oct 9, 2019 at 9:33 AM
    Rakso
    Oskar
    Shady: Of doubtful honesty or legality.
    Garbage: A thing that is considered worthless or meaningless.
    Source: google
  9. Oct 9, 2019 at 9:35 AM
    computeruser6
    Dirk
    Escondido
    OK, sure. I'm sorry that I said anything to you. If you think that all dealers are dishonest don't go to a dealer for service.
  10. Oct 9, 2019 at 9:35 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Maybe you should do it yourself then
  11. Oct 9, 2019 at 9:37 AM
    Rakso
    Oskar
    I will, like I posted above, not sure how warranty works If you don't service the vehicle at a dealership. I did the same with my 09 Tacoma, took it for oil changes until out of factory warranty then never came back.
    PLC721[QUOTED] likes this.
  12. Oct 9, 2019 at 9:39 AM
    Rakso
    Oskar
    Of, SOME are shady AF. Relax bro, your dealership is the best on the west. :thumbsup:
  13. Oct 9, 2019 at 9:41 AM
    Rakso
    Oskar
  14. Oct 9, 2019 at 9:42 AM
    Rakso
    Oskar
  15. Oct 9, 2019 at 10:46 AM
    BuilderBee
    BuilderBee New Member
    Southern California
    2017 Tundra Double Cab TRD SR5
    BakFlip MX4 Tonneau Cover Stubby Antenna Husky Floor Liners
    I only did my original "free" oil changes through the dealer, all other oil changes, brake changes, tire rotations and routine maintenance are done by the only guy I trust and that is ME!
    Major service will consider a dealer ....maybe.....otherwise I can get it cheaper at a local mechanic as I am a supporter of small business and some local mechanics here are "factory authorized" and will accept manufacturer warranty repair. :thumbsup:
    Rakso[OP] and BravoDeltaRomeo like this.
  16. Oct 9, 2019 at 11:42 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Had that happen once. They said the did a rotation but it was obvious by looking that they didn’t. At least the advisor I’ve been using is very knowledgeable and helpful, but after the free stuff I’m taking over. Good luck
    Rakso[QUOTED][OP] likes this.
