Are Wildpeaks that much better?
Discussion in 'Wheels & Tires' started by Outbound, Nov 28, 2022.
  1. Nov 28, 2022 at 7:21 AM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    I'm heading into the tire shop today to replace the trash stock Michelins. I've narrowed it down to the Cooper AT3 XLT and the Falken Wildpeaks. I'm leaning towards th Wildpeaks but they're around $500 more for the set.
    Are they actually $500 better or is that alot of marketing wank?
  2. Nov 28, 2022 at 7:28 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    They used to be almost the cheapest, gained popularity and now are on the other side of the spectrum regarding pricing. Look great...hard to swallow the extra cost though...
    PermaFrostTRD and Outbound[OP] like this.
  3. Nov 28, 2022 at 7:30 AM
    Kung
    KG, VA
    Depends on usage. Were I to spend all my time offroad, yes, I'd pony up the extra $. For mainly onroad usage? Naah, I'd go with the Coopers.
    Outbound[OP] likes this.
  4. Nov 28, 2022 at 7:30 AM
    Coopers flat spot…fyi. At least my XLT’s did.
    They were great in the snow and everything else I tossed at them. 27k miles I replaced them.
    NewImprovedRon and Outbound[OP] like this.
  5. Nov 28, 2022 at 7:38 AM
    https://youtube.com/shorts/nCz5HS5X5Gw?feature=share
    This was 2wd in the rolling hills around my place. We had rain, sleet, and then snow. It was pretty slick on the roads. I was pretty impressed with the performance.
    The flat spotting on the first 10k miles was annoying though.
    Outbound[OP] and Saltyhero13 like this.
  6. Nov 28, 2022 at 7:38 AM
    Outbound
    Aaron
    Northern Alberta
    I'd say my usage will be about 80% road, 15% gravel/dirt and 5% thick, sticky mud.
    Did they flat spot after sitting for a long time? My truck gets driven at least every couple days.
  7. Nov 28, 2022 at 7:42 AM
    After 10-12 hours.
  8. Nov 28, 2022 at 7:45 AM
    Shawn4x4
    Shawn4x4 New Member
    I don’t know if Wildpeaks perform better, but they for sure look better. How important are looks to you ?
  9. Nov 28, 2022 at 7:48 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Do not get the coopers I have them they suck once you get down to 60% plus I’ve had balance issues since day one. my wife’s wildpeaks are 100x better I’m scrapping my coopers with 22k on them and getting falkens.
    the issue I have is these coopers fill up with snow and basically become a racing slick. Plus the flat spot thing is annoying. And one tire will not balance out it’s been bad since day one and my tire shop wouldn’t warranty it.
    I can’t even get my wife’s Subaru with the wildpeaks to slip the tires in the snow they are impressive. Very quiet and look awesome to.
  10. Nov 28, 2022 at 7:51 AM
    Kung
    KG, VA
    IMHO, were I to use them that much for gravel/dirt/mud, yeah, I'd pony up the extra dollars for the Wildpeaks. I did lose about 0.5MPG because they're a heavier tire, but they're a good tire for sure. They absolutely lasted longer than my Cooper XLTs.
  11. Nov 28, 2022 at 7:54 AM
    xtyfighterx
    Ty
    North Idaho
    Yep I also noticed my coopers wore really fast.
  12. Nov 28, 2022 at 7:57 AM
    Outbound
    Aaron
    Northern Alberta
    No bueno
    Looks are the lowest priority to me. Performance is the most important.
    We get lots of snow here, and even though I plan to buy dedicated winters next year I still want the snow capabilities. Sounds like the Coopers really aren't that great after all.
    I don't mind losing .5 or even 1.5 mpg for better tire performance. Longer tread life is good to.
    Sounds like I'll be going for the Falkens unless someone makes a really good case for the Coopers. I'm okay spending the extra money as long as the increased performance is there, especially since The Woman drives the truck while I'm on my work rotations so money comes second to my family's safety.
    NewImprovedRon likes this.
  13. Nov 28, 2022 at 7:59 AM
    This. I think 60% was very generous. Mine became worthless well before that and I run centramatics wheel balancers.
    One more thing, when new the tires seemed to “wonder” more until at least 5k miles and some wear down on the tread. Not all that great for towing if that is a concern for you.
    When I was hauling top soil for 3 days straight in town, my rear tires wore down 4/32nds. I was shocked and knew these were not going to make it to 30k.
  14. Nov 28, 2022 at 7:59 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I have Wildpeaks AT3, and they are definitely worth the money, I had Yoko X-at before.
    The Wildpeaks are:
    - Whisper quiet, they are as quiet normal car tires.
    - Great in the rain, way better than the Yoko
    - Great in the sand, gravel.
    - Tows great
    I drive about 70% on the road, rest is gravel and dirt road, and tows often, the Yoko was great, I liked it a lot, but the Wildpeaks are just so much better, we bought a set for wife's car, and I was amazed at how quiet they were so I bought a set for myself, it'll be pretty hard to switch for my use.
    I have yet to drive in deep snow with them, but I've heard great things about them so not too worried.
    Outbound[OP] and ryanwgregg like this.
  15. Nov 28, 2022 at 8:03 AM
    xtyfighterx
    Ty
    North Idaho
    Ya I’m probably closer to 50 percent with 22k on them. I had to chain up a couple weeks ago to go up a logging road with 6” of snow after getting stuck 3 times and digging my self out no traction whatsoever
  16. Nov 28, 2022 at 8:05 AM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    I had the NITTO trail grapplers on my 2015. 12:50x35x18. They was good tires, lasted pretty well, a bit loud but they are mud tires so that is to be expected. I just recently installed the Faulkin wild peak mud terrains and these ride much much smoother, and hardly any road noise at all. I only have about 1000 miles on mine but so far I reallY like them
    Outbound[OP] and ColoradoTJ like this.
  17. Nov 28, 2022 at 8:08 AM
    Yep. I got stuck on my own property with those tires. Pretty sad I had to walk up 100 yards and start the tractor and have the wife suit up.
    New I have to admit they did excellent. It was a short romance.
  18. Nov 28, 2022 at 8:10 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Don't know if it matters, but they do come with tread life warranty. Most AT tires don't, from what I could tell when I bought mine.
    No issues with mine in the year or so I've had them.
    55,000 MILE TREAD LIFE WARRANTY
    The WILDPEAK A/T3W features a 55,000 mile / 90,000 km Limited Tread Life Warranty on all sizes.
  19. Nov 28, 2022 at 8:11 AM
    Sunnier
    Sunny
    San Diego, CA
    Another vote for Wildpeaks. We run them on an old 4Runner with upgraded suspension. Very polite road manners, good off-road (aired down in sand, rocks and gravel, mud and puddles… but no bogs) and in city rain (all the slippery pavement oils). Cannot attest to performance in snow, but I read good things.
  20. Nov 28, 2022 at 8:13 AM
    xtyfighterx
    Ty
    North Idaho
    Yep I had a Chevy pull me out I think that’s even worse and he said you need different tires not highway tires up here in the mountains hahaha.
    BravoDeltaRomeo and Outbound[OP] like this.
  21. Nov 28, 2022 at 10:48 AM
    mustangr2
    mustangr2 New Member
    I always ran Wildpeaks and I currently run them. It used to be hard to beat for the price. Now they are a lot of good tires in the price range,
  22. Nov 28, 2022 at 12:22 PM
    PermaFrostTRD
    Northern NY
    No experience with the Coopers. Wildpeaks are a great tire. Heavy for their size but if a little mpg drop isn't a concern due to weight, they're worth the extra $$. Also, online seems to only be about a $200 difference between the 4 tires (about $50 tops more for the Falkens) - not sure why your shop is saying $500. That was for the LT 275/70r18 size, btw.
  23. Nov 28, 2022 at 12:34 PM
    TheBeast The Beach
    BFG KO2s always been good to me. I buy them at costco when on sale and the 5 years warranty is great.
  24. Nov 28, 2022 at 1:20 PM
    Outbound
    Aaron
    Northern Alberta
    Well, I pulled the trigger on a set of Wildpeaks. They'll be installed on Friday. My wallet has gone and hid.
    They good tires but I found that they don't clear mud well at all. We have sticky gumbo mud and it turns KO2s into slicks.
    Sunnier, B.Ross and BravoDeltaRomeo like this.
  25. Nov 29, 2022 at 12:26 PM
    Falken QA
    Falken QA New Member
    We do offer a 30 day, 1000 mile (whichever occurs first) trial period on the Wildpeak AT3w. If you don't like them for any reason (smell, performance, ride, etc), return to your tire shop to exercise the trial period and use the credit towards the Coopers or another tire.
    The Wildpeak AT3w also includes road hazard coverage for the first 3/32nds of wear or 2 years, whichever occurs first. However, speaking as a consumer, purchasing tire certificate or additional coverage from the tire store (if offer) makes sense and will pay for itself after the first incident on truck base tires (AT, HT, RT, or MT).
