Are TRD Sway bars on Platinum a good idea for towing?
Discussion in 'Towing & Hauling' started by Arniesea, Dec 13, 2018.
  1. Dec 13, 2018 at 6:29 PM
    Arniesea
    Arniesea [OP] New Member
    Bremerton, WA
    2017 White Crew Max, Platinum
    I have a new to me 2017 Platinum CM that I bought as I plan to get a larger trailer. The trailer will still be light at 5500 GVW so I'm not worried about the Tundra hauling it. But I do wonder if it would be a good idea to add the TRD Sway bars for handling. It would then be more like the SR5 TRD Sport package, correct?
    Looking for anyone who has experience with this setup. Feedback is appreciated!
    SoCal619 and NjPro like this.
  2. Dec 13, 2018 at 6:52 PM
    I have a 2010 Limited and added a Hellwig rear sway bar and wished I would have done it alot sooner.
    OR18TRD and NjPro like this.
  3. Dec 13, 2018 at 7:04 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    Sway bars, either TRD or hellwig are a good idea for towing and over all ride quality will improve. You will be happy with your investment.
    clarkritchie, nj636 and Prostar 190 like this.
  4. Dec 13, 2018 at 7:05 PM
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    Personally I have one and think it's a great idea unless you are planning on spending a lot of time in axle deep mud and stumps.
    Prostar 190 likes this.
  5. Dec 13, 2018 at 7:12 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I have TRD sway bars front and rear...made a huge difference. I also added "Sumo Springs". My truck is very stable and the handling is much improved over stock. My boat is 5-6000lbs. No sweat...truck rides level and handles great.
  6. Dec 13, 2018 at 7:43 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Good for towing, not so much for wheeling.
    SoCal619 likes this.
  7. Feb 7, 2019 at 4:25 PM
    Arniesea
    Bremerton, WA
    Thanks to everyone who took the time to reply. I appreciate it.
    I just got the Andersen Ultimate 5th wheel hitch, now for the TRD Sway bars. by the way, here is a link to the Escape Trailer that is being custom built for me. Delivery end of April.
    http://escapetrailer.com/trailers/the-5-0-escape/
  8. Feb 7, 2019 at 4:28 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Not that knowledgable on sway bars so I've been reading and what I've been reading is that RWDs use the front sway so what made you go for the rear?
  9. Feb 7, 2019 at 4:36 PM
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    I added one to my platinum and noticed a huge difference when towing my trailer. I use to sway on the highway with a heavy load and now my truck can handle it much better
  10. Feb 7, 2019 at 4:44 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Tundra comes with a front sway bar standard, but none on the rear. TRD front bar is stiffer to reduce the body roll more than the stock one. But it does not do as much as the rear one does. The rear if you put one on you go from nothing specifically made to reduce roll to very little body roll. The effects are significant with just the rear one, it stabilizes the ride a ton and you are stuck to the road a lot more.
  11. Feb 7, 2019 at 4:48 PM
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    Thank you very much sir!
