Are there two Different rear bearing assemblies???
Discussion in '2nd Gen Tundras (2007-2013)' started by jamesjems, Aug 20, 2020.
  1. Aug 20, 2020 at 2:53 PM
    jamesjems
    jamesjems [OP] New Member
    James
    2010 Tundra Doublecab, silver, w/Leer Canopy
    So after 140,000 miles, I need new rear wheel bearings. Both sides.
    OK, fine. Now I’ve replaced wheel bearings before and it’s not a job that I really want to do again so I’m planning on hiring it out.
    here’s a thing: One mechanic wants me to bring it in so that he can inspect it, because he says that there are “two versions of this. And you can’t tell from the VIN number. One version is easy it’ll cost you $550 per side, the other version is hard and it’ll cost you $850 per side.”
    Has anyone here ever heard of such nonsense? Since when would Toyota create two different versions of the hub assembly and the wheel bearing assembly in the rear on a 2010 Tundra? Am I being fed a line?
  2. Aug 20, 2020 at 3:48 PM
    timsp8
    NY
    Maybe it’s different between the 5.7 and 4.6 (4.7?)? Does the smaller engine have the 10.5 rear axle? You’d think they could tell that from your vin though. Check an online parts catalog.
