Are there supposed to be drain holes at the front of the bed?
Discussion in '2nd Gen Tundras (2007-2013)' started by Randy Morton, Oct 22, 2017.
  1. Oct 22, 2017 at 11:29 AM
    Randy Morton
    Randy Morton [OP] Life takes its toll, please have exact change.
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I back into my driveway (the neighbors park in the street and it's almost impossible to back out of mine when they do) and it rained last night. When I back in, the rear of the truck is a little higher than the front and I now have a small water feature in the back of my truck. If there are drains, it's possible that the spray in liner, or some debris, clogged them. I can't do a search without pulling the toolbox, and I'd rather avoid that. Thanks for any help and advice.
  2. Oct 22, 2017 at 12:43 PM
    Jim the Jarhead
    Jim the Jarhead New Member
    2017 SR5 4X4
    Seems mine is the same, my Taco had drain holes. It goes at the seam, not much space, couple fall days with some leaves and it will be a bathtub.
    Randy Morton[OP] likes this.
  3. Oct 22, 2017 at 12:52 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    i just went and looked at mine and i see none...
  4. Oct 22, 2017 at 12:58 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    The drain holes are small gaps about an inch wide between the floor and bulkhead. I think there are 5 or 6 of them and they almost always get closed up when a liner is sprayed in.
    Randy Morton[OP] and 4x4_Angel like this.
  5. Oct 22, 2017 at 1:00 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    makes sense
  6. Oct 22, 2017 at 1:12 PM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Mines got drain holes with tubes that go from the seam at the far end of the bed up to the last panel of my bakflip. I’m not sure how functional it is, but it’s there. Kinda weird.
  7. Oct 22, 2017 at 1:19 PM
    duece292
    Greg
    Green Bay, WI
    You can always drill a few holes. One on either side and one in the middle in the low ribs, 1/4" would be plenty. A little touch up paint around the inside of the hole and some spray undercoating from underneath should prevent any rust.
  8. Oct 22, 2017 at 2:10 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mine are a couple of coin slot shaped openings at the front of the box. They're easily plugged with detritus.
