Are there lower cost rear suspensions with equal performance to the TRD Pros?
Discussion in 'Suspension' started by Badknees, Dec 17, 2020.
  1. Dec 17, 2020 at 5:01 PM
    Badknees
    Badknees [OP] New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Howdy Folks,
    I’m looking to put some TRD Pros on the front of my 2016 1794 CM but having trouble finding and affording the Pro rears. Is there a lower cost alternative with equal/better performance or will I be “bastardizing” my suspension if I don’t stay with the Pros?
    Any advice is certainly appreciated!
    TelemarkTumalo likes this.
  2. Dec 17, 2020 at 6:43 PM
    timsp8
    NY
    Look at Fox rear shocks. That way they are all at least by the same mfg. But I don’t think it really matters. Even stock won’t be horrible as the leafs are the same on Pros and non Pros.
    Badknees[OP] likes this.
  3. Dec 17, 2020 at 7:21 PM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    Why not change the fronts and drive for awhile? You might have a good combo there.
    Badknees[OP] and gosolo like this.
  4. Dec 18, 2020 at 4:04 AM
    Badknees
    South Carolina
    Thanks for the good advice. I probably won't have the $ to act soon after dropping almost $2K on the front. I'll have time to drive with stocks in the rear and also keep evaluating all the options (maybe if I call Fox they can help too!). Also, since I don't want to sag too much when pulling my boat/trailer and loaded down for vacations, I'll need to figure out if a 1" shackle or air bags are best for my situation.
  5. Dec 18, 2020 at 11:33 AM
    Badknees
    South Carolina
    Just as information, I called FOX and the technical guy told me they don't make an exact match to the TRD Pro for the general public. They do however have something with the same or better performance characteristics (P/N 883-24-006):
    Unfortunately, I think these cost more than the TRD Pros!...but might be easier to find.
