Are the oem starters Denso or no
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Feb 20, 2020.
  1. Feb 20, 2020 at 12:26 PM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    I'm sure you guys have seen me post before. Ill keep it short. Looking at the starter of my 01 tundra with 130k miles, it says W.P.S on the starter, and the starter is completely white, not grey like the traditional yota starters which are oem. Does this mean i have an aftermarket starter? Wps and under it says "world power system". It seems to me its aftermarket, which is suprising considering the fact its only got 130k miles! Thanks.
  2. Feb 20, 2020 at 12:31 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I can only comment on the starter for the 3UZ-FE from my 2001 LS430 I had. That was a Denso unit and I installed a rebuilt Denso. I would assume they would be the same, as most of the electrical stuff Toyota uses is Denso.
    That sounds like an aftermarket starter that has failed.
    Seems like low mileage for a starter failure...?
    theblurry1 and Pucks18[OP] like this.
  3. Feb 20, 2020 at 12:41 PM
    Pucks18
    @N84434 yes seems like very low mileage
  4. Feb 20, 2020 at 1:24 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    I would guess someone misdiagnosed a starting problem and replaced it for no reason. Very low mileage for an OEM starter to fail.
    Pucks18[OP] likes this.
  5. Feb 20, 2020 at 1:27 PM
    Professional Hand Model
    Hand Protectors
    Yes. Denso!
  6. Feb 23, 2020 at 7:42 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Yep denso, and don’t get a rebuilt just fork out the money for a new unit.
  7. Feb 23, 2020 at 10:15 AM
    Pucks18
    @Filthyphil thanks, but what are u referring to when ur talking about dont rebuild and to get a new unit? Little confused to what ur talking about
  8. Feb 23, 2020 at 11:17 AM
    Filthyphil
    Phil
    Re read your post I thought you said you were looking into getting a new starter
    For your truck not that your just questioning the starter that’s on it haha.
  9. Feb 23, 2020 at 1:22 PM
    Hand Protectors
    @Filthyphil just went through buying a rebuilt and had it installed only to have it go bad on him. He had to do it all over again but we helped him spend his money and got him into a Heavy Duty OEM Denso (they made two for our truck a regular duty and HD depending on your package). His starts are quicker than ever. :yes:
    Filthyphil likes this.
