Are the door tensioners adjustable?
Discussion in '1st Gen Tundras (2000-2006)' started by Aerindel, Mar 31, 2019.
  1. Mar 31, 2019 at 3:04 PM
    Aerindel
    Aerindel [OP] New Member
    Montana
    I don't own any flat land. I'm always parked on a slope. Is there a way to stiffen up the probably worn out tensioners on my doors so they stay open on their own when parked on a slope? Between the front doors and the suicide doors one door or another is always swinging closed on me while I'm trying to load or unload things.
  2. Mar 31, 2019 at 3:05 PM
    Maybe buy a new set of tensioners from @Roman?
    Roman likes this.
  3. Apr 1, 2019 at 4:39 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    No, but I can show you how to stand on you door and bend it in a little to get rid of that little air leak by your left ear. :bananadance:
  4. Apr 1, 2019 at 3:23 PM
    Aerindel
    Montana
    That air leak is interesting on mine. I only get it when I go over a bump......almost makes it worse.
  5. Apr 1, 2019 at 3:49 PM
    Professional Hand Model
    Hand Protectors
    Try tightening every 10mm bolt on all your doors first. The keepers on mine were ‘improved slightly’ by tightening their respective bolts. You’ll be amazed at the other bolts on the hinges/etc. that improve the rigidity in the other areas. Take care to not over tighten the keepers. The hinge ones you can crank a little harder.
    Aerindel[QUOTED][OP] likes this.
  6. Apr 23, 2019 at 3:41 PM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Yep...and if that dont work refer to step #2......that's 2 paragraphs up. :smack:
