Are the Dirtydeeds BAM cat-back systems 2.5" from the mid to the y-pipe?
Discussion in 'Performance and Tuning' started by Youngfrankenstein, Jan 5, 2020.
  1. Jan 5, 2020 at 11:56 AM
    Youngfrankenstein
    Youngfrankenstein [OP] New Member
    2015 4x4 CM SR5
    I was just curious if the 6", 8", 10", Dirty-Deeds cat backs that keep the stock tailpipe systems are using 2.5" pipe from the factory's converter/mid-pipe to the Y-pipe right before the axle. Or is it 2.25 or somewhere in between.
    Thank you.
    Rica25 likes this.
  2. Jan 5, 2020 at 6:40 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    That depends on the application. Were you looking to order one?
    Rica25 likes this.
  3. Jan 6, 2020 at 12:01 PM
    Youngfrankenstein
    2015 4x4 CM SR5
    Thank you for popping in! I am looking at a used one that is for sale. It is a pretty annoying drive from where I live, it has to be done well after any traffic hours. I currently have an 8 coil Spintech welded in place of the original. I am wondering if I will notice a difference in low end power/all power. It also seems like a much better set up for future headers.
    Thank you.
  4. Jan 6, 2020 at 2:10 PM
    dirtydeeds
    Keith
    USA
    You will definitely notice an increase in low end torque.
    Rica25 and Rex Kramer like this.
  5. Jan 10, 2020 at 10:09 AM
    Youngfrankenstein
    2015 4x4 CM SR5
    This cat-back is radical.
    dirtydeeds, Rica25 and Pudge like this.
  6. Jan 10, 2020 at 10:57 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I love mine
    dirtydeeds and Rica25 like this.
  7. Jan 10, 2020 at 11:01 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    Thank you for using this word unironically. this made my day
  8. Jan 12, 2020 at 11:13 AM
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    @Pudge are you 8 or 6? Which way did you ever go? Did you ecu tune yet I’ve noticed my shift points seem to have gotten dragged out since installing the 8 w/ resi
    dirtydeeds likes this.
  9. Jan 12, 2020 at 12:17 PM
    Pudge
    CT
    I had a 6 for a few months and switched to 8.
    I didn't change anything with the ECU or even disconnect the battery. I don't think I have noticed any shift point changes.
  10. Jan 12, 2020 at 12:24 PM
    Doylfish
    Doylfish New Member
    could be that I’m just in the throttle a lot more to hear the sound now too :bananadance:
    dirtydeeds and Pudge[QUOTED] like this.
  11. Jan 12, 2020 at 12:27 PM
    Pudge
    CT
    :thumbsup:
