Are the dealerships fixing the vibration issue in the newer Tundys? (Video of issue added!)
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by trucksareforgirls2, Sep 26, 2020.
  1. Sep 26, 2020 at 1:38 PM
    trucksareforgirls2
    trucksareforgirls2 [OP] New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Hi all,
    I have read multiple threads about the vibration type noise on start up of newer Tundras, mine has this problem, but it only happens when it has been sitting for a while. Now that it is cold though it is happening more frequently, and its a bit annoying for a new vehicle.
    I am just wondering if anyone has complained to a dealership, and if so did they fix it, or do anything about it? Anyone know what it actually is as far as the problem goes?
    Thanks,
    -T
  2. Sep 26, 2020 at 1:55 PM
    timsp8
    NY
    How new? Either I dont know what you mean or mine doesn’t do it. Don’t remember my 2010 doing it either. Both have the high idle at start though.
    Tundyfundy and Cpl_Punishment like this.
  3. Sep 26, 2020 at 2:36 PM
    trucksareforgirls2
    Northeast USA
    2020. A few others have complained about it on here, but not sure if there is a fix as of yet, or if anyone has tried. It literally does it when you first turn it on and maybe for another minute or so then it is quiet again. The noise seems to come from vibration of the dashboard area. Seems to be a 2019 and 2020 issues.
    -T
  4. Sep 26, 2020 at 2:51 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I’ve got a 2019 5.7L and know of no such vibration with mine and it sits a lot (just drive it today after setting for 3 days and fired up nicely.)
    rockmup and Moon Puppy like this.
  5. Sep 26, 2020 at 2:54 PM
    HaveFun
    HaveFun Happy to be here
    Fair Oaks Ranch, Texas
    2019 Black Tundra CM SR5
    Same ^
    rebmo likes this.
  6. Sep 26, 2020 at 4:00 PM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
    Wonder if it’s a 2020 issue. My 2018 sits a lot, I might drive her once a month. Sometimes, every other month and never experienced this vibration issue you speak.
  7. Sep 26, 2020 at 4:01 PM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    My 20 has had no such issue
  8. Sep 26, 2020 at 4:03 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    Just started my 2020 doesn't have a vibration. It does, though, make a small roar, like I have a loud exhaust for a moment when I start it up after letting it sit for a couple days.
  9. Sep 26, 2020 at 4:05 PM
    Dodger46
    Dodger46 New Member
    2019 Silver Sky Metallic SR5 Crewmax
    No vibration on my 2019...I’m pretty impressed with it
  10. Sep 26, 2020 at 4:39 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That roar is the engine cooling fan spinning up until the viscous fan hub releases and lets the fan basically freewheel.
  11. Sep 26, 2020 at 5:03 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Haven't seen this issue on my truck yet and it's been sitting quite a bit when I've been working from home. :fingerscrossed:
    glowblue and Tundrafan23 like this.
  12. Sep 26, 2020 at 8:30 PM
    Tundrafan23
    Tundrafan23 New Member
    I have a 2020 and have never heard of any problem with vibration at start up. Are you sure it's not the cold start you are hearing/feeling?
    Moon Puppy and Cpl_Punishment like this.
  13. Sep 27, 2020 at 6:23 PM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    No idea what you're talking about....
  14. Sep 27, 2020 at 8:33 PM
    Dodger46
    Dodger46 New Member
    That knock is awful! Not normal.
    I think on a normal start up you hear the roar of the secondary air pump heating up the cats. Those pumps have a history of failure in older models. A lot of guys buy the bypass kit when they do fail and never fix them.
    Cpl_Punishment likes this.
  15. Sep 28, 2020 at 7:22 AM
    trucksareforgirls2
    Northeast USA
    I haven't check if the sound is outside too, but basically when you start it there is a vibration noise in the dashboard area. It does not happen all the time though.
    -T
  16. Sep 28, 2020 at 7:31 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Sorry if I missed it above but what did your dealership service department say?
  17. Sep 28, 2020 at 7:34 AM
    trucksareforgirls2
    Northeast USA
    I didn't bring it there yet for the issues, I was just curious. I will mention it when I Bring it in for the 5K service in a couple months!
    -T
  18. Oct 2, 2020 at 4:16 PM
    trucksareforgirls2
    Northeast USA
    Hi, Finally got the noise on video. It is definitely worse when I am going up my hilly driveway!
  19. Oct 2, 2020 at 4:27 PM
    trucksareforgirls2
    Northeast USA
    I know, it sounds like something is causing the dashboard to rattle, for whatever reason. I did watch a Youtube video with similar noise and that guy said he fixed it by taking the temp clips off the windshield, as they were the source. I will let the dealership deal with it at this point....
    -T
  20. Oct 2, 2020 at 4:29 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Black Wolf likes this.
  21. Oct 2, 2020 at 4:37 PM
    mountainpete
    Things make noises when it's -10C or colder.
    Cpl_Punishment and Black Wolf like this.
  22. Oct 2, 2020 at 7:46 PM
    mountainpete
    I appreciate that response - you want a specific answer. I’ve just learned that startup noises when it’s below freezing are not worth the time to investigate. If it’s still happening when it’s warm then I look into it. Fluids are very thin on the 5.7 so warm oil falls into the pan fast and cold oil still takes a bit to circulate.
    rockmup and SomeGuy4 like this.
  23. Nov 20, 2020 at 7:59 AM
    Tandru
    Tandru New Member
    SomeGuy4 likes this.
  24. Nov 21, 2020 at 7:30 PM
    CujoTRD
    CujoTRD New Member
    2021 Jeep JL Rubicon 6spd
    That almost sounds like rod-knock during startup (like the 4.7 iForce’s). What type of oil are you using in that temperature? Have you tried a thicker weight oil and see if that makes any difference? Good luck, and please let us know what you find out.
    Tandru likes this.
