Are Lockers Necessary?
Discussion in 'General Tundra Discussion' started by Mass_Sequoia, Jan 4, 2021.
  1. Jan 4, 2021 at 6:02 PM
    Mass_Sequoia
    Mass_Sequoia [OP] New Member
    John Henry
    Massachusetts
    2021 Sequoia TRD Pro
    I've owned my 2019 TRD Pro about a year and half, and I haven't had too many chances to go off road. Recently during a snowstorm in New England, I did go somewhat off road -- up a gravel path with heavy snow, ~ 6-12 inches of snow, up a steep hill for ~200 ft.
    I was expecting the Tundra may have some difficulty going straight up, with poor traction. In 4H it went straight up the hill with no hesitation at all. It's all stock.
    -- My question is, are lockers really necessary if the Tundra can go up that kind of snowy terrain with no problems at all?
    -- How would lockers actually improve off-roading? In severe muddy conditions?
    Thanks in advance for your responses.
    gosolo and Wallygator like this.
  2. Jan 4, 2021 at 6:10 PM
    Pine Tree State
    Pine Tree State New Member
    2021 SR5 TRD Sport CM
    Lockers start to prove their worth when you get tires off the ground.
  3. Jan 4, 2021 at 6:10 PM
    Wallygator
    Lockers are more beneficial in rock crawling. I don't do rock crawling in my Tundra but I wish it had a locker none the less
  4. Jan 4, 2021 at 6:19 PM
    A locker is good for rock crawling or terrain that will max out the travel on your suspension.
    Situations like this:
  5. Jan 4, 2021 at 6:21 PM
    TheBeast The Beach
    I would get a winch before a locker but I dont do rock crawling with my Tundra. It's just too big imo.
    Ely010606, ColoradoTJ, MTRock and 3 others like this.
  6. Jan 4, 2021 at 6:41 PM
    Mass_Sequoia
    John Henry
    Massachusetts
    I really appreciate the responses!
  7. Jan 4, 2021 at 6:46 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The system designed by Toyota works really well. Don’t mess with it until you actually have a traction problem. Admittedly, the electronic locker like the 4Runner and Tacoma have would be preferable, but it’s not worth tearing apart the rear end. There’s lots of posts about failure of after market lockers but I have never seen a post about the OME not doing the job
    Terndrerrr, Ely010606 and TheBeast like this.
  8. Jan 4, 2021 at 6:51 PM
    Elduder
    Elduder New Member
    Had lockers on all my previous trucks and never used them, so havent been worried about the Tundra not having one. Toyota does a pretty good job with their auto lsd and ATRAC systems.
    gosolo likes this.
  9. Jan 4, 2021 at 6:51 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Terndrerrr and Elduder like this.
  10. Jan 4, 2021 at 6:52 PM
    Mass_Sequoia
    John Henry
    Massachusetts
    I appreciate that feedback. I wish I had some pictures of that snowy hill, I was amazed that the truck went straight up with no issues, and none of the 'traction lights' came on either.
    gosolo likes this.
  11. Jan 4, 2021 at 6:54 PM
    Elduder
    Elduder New Member
    Tundra has been much better than both my FJ and Tacoma were in the snow, but it also has a longer and wider wheelbase, as well as weighs a bit more.
    TheBeast and gosolo like this.
  12. Jan 4, 2021 at 8:55 PM
    I would rather have a good limited slip than a locker on a daily/weekend warrior.
    Like others have said, it your not having issues, wouldn’t bother with it.
    Wynnded, Ely010606 and gosolo like this.
  13. Jan 5, 2021 at 7:28 AM
    Blue Thunder
    Washington
    I agree 100%.
  14. Jan 5, 2021 at 7:36 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    IMHO
    Drive, wheel the truck and go get stuck on purpose.
    Learn the system.
    The OE electronically controlled system works surprising well once one learns how to use it.
  15. Jan 5, 2021 at 5:39 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I never got stuck in my unlocked 2012 4Runner. ATRAC works too well.
    I don’t have any experience using it on my Tundra yet. I’ve been told the only downside vs the 4Runner is you need more wheel spin to engage ATRAC on the Tundra than may be prudent given your situation. On my 4Runner (which did not have a locker), all I had to do was push a button while in 4Lo.
    Here’s how all the nannies and ATRAC work on your Tundra.
    Wallygator likes this.
  16. Jan 5, 2021 at 6:26 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    You don't need lockers if you don't know if you need lockers. Nothing will match lockers for traction, but there's also a point where more goodies will just get you more stuck if you don't have a solid knowledge of the basics. If 4Hi seems fine, stick with that for now.
  17. Jan 5, 2021 at 6:32 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    And a locker in the snow can get you into trouble very quickly if you are imprudent enough to engage it on the road.
  18. Jan 6, 2021 at 2:51 AM
    Wallygator
    But so fun making the donuts:cheers:
  19. Jan 6, 2021 at 3:39 AM
    defaint
    defaint New Member
    Jeremy
    Innawoods
    2021 MGM Tundra TRD Sport
    Freakenrage likes this.
