Are lifted struts same length as stock?
Discussion in 'Suspension' started by jsvwx, Dec 8, 2024.
  1. Dec 8, 2024 at 3:33 PM
    jsvwx
    jsvwx [OP] New Member
    New York
    2001 AC SR5 V6 5M 4WD
    I just purchased a new 5100/2883 strut to swap out my stock set and when I put them side by side, they are both 20.5" long top plate to bottom of strut. I know the original owner and he said he only replaced the front shocks once with a OEM and no changes to the suspension. Does all this make sense or should the new lifted strut be taller?
  2. Dec 8, 2024 at 4:39 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Never heard of 5110 or 3883, but my 6112's were the same length as stock, and use spring preload to increase lift.
    oh, is the 3883 the old man emu springs?
    jsvwx[OP] likes this.
  3. Dec 8, 2024 at 5:08 PM
    jsvwx
    New York
    I just edited my post. Meant to say Bilstein 5100 with OME 2883 springs. So that's normal then. Thanks!
  4. Dec 8, 2024 at 6:23 PM
    jsvwx
    New York
    So if both struts seem to have the same length spring and the bottom cups seems to be at the same height, would mine have a different preload then. My 5110s are one the lowest perch.
