ARB Summit or Heavy Fab Aluminum front bumper?
Discussion in '2.5 Gen Tundras (2014-2021)' started by bmw345, Feb 8, 2023.
  1. Feb 8, 2023 at 8:06 AM
    bmw345
    bmw345 [OP] New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    I am looking to replace my factory front bumper with aftermarket. I have it narrowed down to either the ARB Summit or the Heavy Fab aluminum. Wondering if both will work with my TRD Skid plate and will the TRD Pro Fox front suspension handle the extra weight up front! Post up some pics if you have either bumper!
  2. Feb 8, 2023 at 8:20 AM
    2mchfun
    Fwiw, might make sure you have brackets that don't only rely on the face/end of the frame mounting studs. I've heard that some heavy bumpers tend to crack and tear them over time. For example, my Ranchhand also uses the transport anchor loop mounting locations with extended bolts to carry and support the loads.
  3. Feb 8, 2023 at 8:40 AM
    bmw345
    CT
    I think in the scheme off things the ARB is much heavier but is well built/designed with crumple zones etc. The Heavy fab is half the weight which is also an advantage. Both look like quality pieces!
    HulkSmurf14 and 2mchfun[QUOTED] like this.
  4. Feb 8, 2023 at 4:12 PM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    ARB or nothing
    AggiePhil, bmw345[OP] and 2mchfun like this.
  5. Feb 8, 2023 at 4:23 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Good point.
    The SOB bumper @STravis makes has a bracket that sandwiches the bumper against the end of the frame but also utilizes the two 17mm bolts that anchor the tow hooks to the frame. Solid support.
    STravis and 2mchfun[QUOTED] like this.
  6. Feb 8, 2023 at 5:04 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Ironman is much lighter, cheaper and with crumple zones and crash tested also. Just throwing it out there. I love mine.
    bmw345[OP], Wallygator and 2mchfun like this.
  7. Feb 8, 2023 at 5:36 PM
    2mchfun
    Same as Ranchhand, really fun to try and hold up the bumper brackets, front receiver hitch, and tow loops while trying to get a bolt started at the same time.:mad: Solid assembly after done though.
  8. Feb 8, 2023 at 5:50 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Gotta phone a friend and have some cold brews handy....
    2mchfun[QUOTED] likes this.
  9. Feb 8, 2023 at 6:37 PM
    2mchfun
    We were mostly "social distancing" at that time and I didn't want to get anyone hurt and need to get to the ER either. Was a great time to mod my truck while sitting around the house. Only problem is the list became freaking endless!:annoyed:
  10. Feb 8, 2023 at 6:42 PM
    Remember to keep payload and use in mind.......
  11. Feb 8, 2023 at 6:44 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I wanted to do all sorts of stuff to the truck but was concerned about the job security. Didn't wanna go on a spending spree and then end up unemployed.
    AggiePhil and 2mchfun[QUOTED] like this.
  12. Feb 8, 2023 at 6:56 PM
    raketemensch
    raketemensch New Member
    NEVADA
    I had the BAMF (Pelfreybilt) aluminum front bumper on my 4Runner and it was 1/4" aluminum, almost as light as stock, I think next lightest was the 4x4Labs. no issues with supports or frame cracks even with a big ol 31M battery sitting on the frame. Previously had steel on an old tacoma, and had issues at the front support bolts wearing out and minor bending of those due to that. If it were me based on my experience, I'd opt for lighter and better clearance.
