Approaching 100k
Discussion in '2.5 Gen Tundras (2014-2021)' started by tja1080, Jun 28, 2022.
  1. Jun 28, 2022 at 4:50 AM
    tja1080
    tja1080 [OP] New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    2016 Platinum, approaching 100k
    Looking to replace brake pads, possibly rotors before I go with 35x12.5 Ridge Grapplers… recommendations?
    any other recommended maintenance?
  2. Jun 28, 2022 at 4:54 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Nice looking truck!
    I would follow the manual for any other maintenance items. Fluid changes and an alignment check with the new tires would be a good idea
  3. Jun 28, 2022 at 6:37 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Probably plugs, at the very minimum I would check them.
    tja1080[OP] and Taco-Spike like this.
  4. Jun 28, 2022 at 7:15 AM
    Taco-Spike
    Two Trucks
    In addition to ^
    Throttle body and MAFS cleaning. $15-$20 in parts (cleaners and can get multiple uses out of them) and about 10-15 minutes of time. Easy quick hit item and can do quite a bit of good
    tja1080[OP] and MadMaxCanon like this.
  5. Jun 28, 2022 at 8:46 AM
    MadMaxCanon
    grease that baby up to
    TheBeast, tja1080[OP] and Jaypown like this.
  6. Jun 28, 2022 at 5:33 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    spark plugs
    serpentine belt
  7. Jun 29, 2022 at 4:19 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    It's recommended to install a supercharger after you get the engine finally broken in at 100k...it comes with everything and makes you confident in your choice of truck... just saying.
    PapiShields, vipgs3 and tja1080[OP] like this.
  8. Jun 29, 2022 at 5:57 AM
    BlazingBlueFiveSeven
    BlazingBlueFiveSeven New Member
    If you haven't done it yet or recently:
    - Diff fluid front and rear
    - Transfer case fluid
    - Transmission fluid
    - Coolant
    and like someone else mentioned, spark plugs
    tja1080[OP] and HulkSmurf14 like this.
  9. Jun 29, 2022 at 10:10 AM
    tja1080
    TJ
    Whidbey Island WA
    2016 Platinum
    Thoughts on these
  10. Jul 1, 2022 at 6:59 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    • Diff/transfercase/trans fluid
    • Coolant
    • Spark plugs
    • Grease driveline zerks (if your truck has them, should be doing this every oil change anyways)
    Those powerstop kits are nice. For me personally i've never had an issue with OEM though and they last a while.
  11. Jul 1, 2022 at 9:31 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    A few items have already been mentioned:
    -check all bushings. replace if needed
    -check engine/transmission mounts. replace if needed
    -change as many fluids as possible
    -lube everything that can be lubed
    -sparkplugs
    -search for leaks (fluids or vaccuum)
    -rust? get rid of it
    -torn/rotten CV boots, ball joint dust covers. replace if needed (sadly, OEM ball joints are not greaseable and must be replaced)
    Got nothing on rotor/pad combos since I've only had OEM, but there's a chance that might change sooner than later.
    If your truck has no apparent issues, leaks, strange noises or anything in between, then you can expect another 100k without issue
