Appliance parts sites
Discussion in 'Home Improvement' started by Medic343, Aug 9, 2021.
  1. Aug 9, 2021 at 7:12 PM
    Medic343
    Medic343 [OP] 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I am looking at replacing the ice dispenser motor on my fridge and was wondering if you all knew of any good appliance parts websites? Or do you think going OEM is the better option?
    Also, if there are any appliance repairmen/women in here...my fridge makes ice but does not dispense it. I can hear the little trap door open but the motor that turns the auger doesn't not fire up. That leads me to believe it is the auger motor and not anything electrical like the paddle or motherboard. Do you agree the motor is the issue and not anything else I may have missed?
    Any help appreciated! Cheers
  2. Aug 9, 2021 at 8:11 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Make and how old
  3. Aug 9, 2021 at 8:20 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I replaced our Samsung ice maker unit about 6 months ago.
    Took a few hours to let it thaw, remove safely and replace.
    Ice works perfectly now.
    I purchased OEM part based on my fridge model number and went through an online parts store. Amazon didn't have stock at the time or I would have went through them for return ease etc.
    It was a super easy fix. Cost me about $130 Canadian and a few hours of watching ice melt.
    As for your ice maker, does it need a good defrost? I tried that a few times first and it did help sometimes but I think I damaged it by using a hair drier to speed up the process along the way. Let it defrost using force defrost or powering the fridge/freezer off for a few hours or longer.
  4. Aug 9, 2021 at 8:20 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Look your model and issue up on boobtube, usually it’s a easy fix.
    Like I could see that as being a door switch issue not a motor issue(my moms sorta does the same thing) it hinges enough to open the flapper but the micro switch doesn’t make so the motor doesn’t turn.
    Any of the sites can be a gamble, but all the parts are pretty much the exact same. Good luck with your adventure.
    ToyoMafia likes this.
  5. Aug 9, 2021 at 8:31 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Partsselect.com is 1 I've used, ebay and another online oem parts stores I've used.. I'm a tenant and try to reduce my Landlord's time in my place, so I've replaced a washer motor, dishwasher door and AC starter module... worth every penny IMO... but as stated search by make and model and there are some cross fitting parts.. youtube is your friend too
    Medic343[OP] and FrenchToasty like this.
  6. Aug 9, 2021 at 8:46 PM
    Medic343
    Kenny
    New Mexico
    Date of manufacture is 9/2016, it's a whirlpool gold series
    I've already taken it apart to see how easy of a fix it would be and it doesn't look like there are any signs it needs a defrosting but then again I don't really know what I'm looking for other than ice build up from condensation.
  7. Aug 9, 2021 at 8:48 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    Give model number
  8. Aug 9, 2021 at 8:51 PM
    Medic343
    Kenny
    New Mexico
    Sorry.
    WRS975SIDM00
  9. Aug 9, 2021 at 8:58 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    Pull the bottom grill and chk the wire harness going into bottom of door, it’s wrapped in black plastic and u may find it broke open . If so look inside for broke wires
  10. Aug 9, 2021 at 9:25 PM
    Medic343
    Kenny
    New Mexico
    Looked at the wiring harness and all looks well there.
    BravoDeltaRomeo likes this.
  11. Aug 9, 2021 at 9:28 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    Is the plastic wrap around wires broke open?
  12. Aug 10, 2021 at 6:59 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    For mine, it was a common Samsung issue and many YouTube videos. Apparently there are class actions lawsuits in the works in the USA for the crappy design of mine.
    The Samsung ice maker was a solid block of ice for me and it was frozen over the condenser coil thingies (non technical term) and on my model, if you bent that portion it rendered the fridge unfixable. Stupid design. I spent a year googling, trying resets and nothing fixed it. It's nice to have ice again.
  13. Aug 10, 2021 at 7:11 AM
    IgotSR5onit
    IgotSR5onit New Member
    I always use appliance parts pros. Have bought from them many times.
    Medic343[OP] likes this.
  14. Aug 10, 2021 at 9:33 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    For our Jenn Air range parts, I've used partsdr.com. They've been consistently cheaper than anywhere else and I generally have the part in a couple of days even with the cheapest delivery method.
