Apple CarPlay issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by ChrisLopez, Jul 19, 2021.
  1. Jul 19, 2021 at 5:27 PM
    ChrisLopez
    ChrisLopez [OP] New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
    I have a 2018 tundra sr5 and I upgraded the radio to the Kenwood DMX7706S. Apple CarPlay always worked great up until a week ago. It connects through usb and apple CarPlay comes up but it’s disconnects every so often. Sometimes it’ll disconnect every few minutes or it can not go out at all and it’s getting very frustrating. I even purchase a carlinkit wireless CarPlay adapter and it still does it. I have already erased and reconnected phone from radio. Does anyone know what it can be? Thanks for the help in advance.
  2. Jul 19, 2021 at 5:32 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    Try the simple, obvious and cheap things first if you have not already. Clean out the USB ports (male and female sides) as well as the lightning connections with compressed air, maybe try a new cable as the wires or pins could be damaged, update your iPhone operating system if it needs it, check for updates to the head unit by contacting Kenwood.
  3. Jul 19, 2021 at 5:46 PM
    Puppypunter
    Puppypunter New Member
    Johnny
    Denver, CO
    2019 Tacoma
    Not sure if it is related at all, but ever since I updated to iOS 14.6, connecting has been more involved. Hard to describe (and not exactly what you are experiencing, so I won't go into detail), but it might be relevant to you?
  4. Jul 19, 2021 at 5:50 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    There should be a firmware update for headunit. My 996xr was having issues after I updated my iOS. After the firmware update on the headunit it has been issue free
  5. Jul 19, 2021 at 6:08 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Try using an actual Apple usb cable not a knock off.
  6. Jul 19, 2021 at 6:21 PM
    ChrisLopez
    Christian
    Chicago,Illinois
    thanks will clean it out and will contact kenwood about a possible update on headunit
    ejes[QUOTED] likes this.
  7. Jul 19, 2021 at 6:22 PM
    ChrisLopez
    Christian
    Chicago,Illinois
    I have original iPhone cable and still does it. Thanks though
  8. Jul 19, 2021 at 6:22 PM
    ChrisLopez
    Christian
    Chicago,Illinois
    how do you check for software update? And how do you install with usb stick?
  9. Jul 19, 2021 at 6:23 PM
    ChrisLopez
    Christian
    Chicago,Illinois
    I was thinking the same thing. I feel with my last update that’s when it happened. It so happens I just got notification for iOS update 14.7 let’s see if this fixes it. Thanks
  10. Jul 19, 2021 at 7:06 PM
    ejes
    ejes New Member
  11. Jul 19, 2021 at 7:28 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Every time I start looking for fixes to Apple CarPlay issues, I eventually find that the issue started after an iOS update. It seems that the only way to find a longer term solution is for EVERYONE with these issues to complain to Apple. It will take some doing, but they will be more sensitive to this issue if they are hearing from us constantly. They will always blame the third party manufacturers of the radios, but they will notice that they are getting the blame from the users, and that will prompt them to find a solution.
    ChrisLopez[OP] likes this.
  12. Jul 19, 2021 at 7:35 PM
    ChrisLopez
    Christian
    Chicago,Illinois
    Yes I agree when I look up iOS 14.6 CarPlay issues I found a Reddit forum talking about some issues with connectivity to the CarPlay. I just updated to 14.7 that released today so I hope that took care of it. It’s not biggest problem in the world but man it’s annoying.
  13. Jul 19, 2021 at 7:48 PM
    ejes
    ejes New Member
    I doubt they would care as much as you hope. Apple is bigger than all those 3rd party's. They are the big dog and it is up to those companies to conform to Apple instead of the other way around. There is no way they can keep up with a bunch of smaller companies' nuances and glitches, nor do they want to because they know iPhone users will more than likely stay iPhone users even if they have to deal with these problems. Think of all the apps people have on their phones. I know people with a hundred or more. Only a small percentage are in car applications.
    This is the very definition of "1st world problems"...
  14. Jul 19, 2021 at 8:25 PM
    Derek242
    Derek242 New Member
    Derek
    2021 Super White CM TRD PRO
    Not sure if you have tried yet, but try just turning your phone off then back on. I was having the same issue with connecting car play. Sometimes it would connect, then other times I couldn’t get it to. My wife suggested restarting my phone, and no issues since haha. But not work in your case but it only takes a minute to try and it’s free.
  15. Jul 24, 2021 at 6:46 AM
    ChrisLopez
    Christian
    Chicago,Illinois
    So turns on it’s not the cable or the USB port. Realized it goes out when I hit a road bump. Phone stays charging but CarPlay disconnects and I have to plug and replug. I had Best Buy install when I purchased the head unit so I’m going to give them a call hopefully they can help me out.
  16. Jul 24, 2021 at 7:12 AM
    ejes
    ejes New Member
    Before you do that, you might check your phone's touch screen and "shake to undo" settings first. I have had my phone do things like that on bumps as well and that is what it was. My problem was during calls, it would mute the phone when I hit a bump.
  17. Jul 24, 2021 at 8:38 AM
    ChrisLopez
    Christian
    Chicago,Illinois
    Yes I did that but it doesn’t have anything to do with phone or cable. It is the head unit that disconnects from carol after going over a big enough bump on the road. The phone stays charging but the CarPlay disconnects. If I tap on the dash right above the headunit hard enough with out me driving it disconects. Kind of weird because I did my research and this head unit was rated pretty well only had it 3 months and this is happening. Was really liking it but I live in Chicago so the roads are HORRIBLE. It’s constantly disconnects now while driving
  18. Aug 8, 2021 at 5:34 PM
    ChrisLopez
    Christian
    Chicago,Illinois
    UPDATE!!
    Took my truck in to Best Buy to check out the CarPlay issue. Looks like the issue is the connection between the head unit and the factory usb. Apparently some head units don’t work properly with the factory usb outlet so what they did is they extended the headunits usb outlet so I can connect directly to the radio and it’s been working. Hasn’t disconnected once so far. Hope this helps anyone having issues in the future. Also thanks for all the advice!
