Anytime Front/Rear camera
Discussion in '2.5 Gen Tundras (2014-2021)' started by WillTunBlack20, Feb 21, 2022.
  1. Feb 21, 2022 at 5:00 PM
    WillTunBlack20
    WillTunBlack20 [OP] New Member
    William
    Houston, Tx.
    2020 Tundra TRD PRO Midnight Black
    Grille Lights, Bumper Lights, Front Facing Camera, Interior Upgrade, Leer Topper
    @RainMan_PNW, is it possible to use the Toyota push button Front/Rear camera switch, instead of the one in the kit, and if possible, any instructions would be great
  2. Feb 21, 2022 at 5:01 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
  3. Feb 21, 2022 at 5:43 PM
    Why don't you want to use that switch?....just curious.
  4. Feb 21, 2022 at 6:24 PM
    WillTunBlack20
    William
    Houston, Tx.
    I’m using it now, and it is great, I like the Tundra push button switches, if possible every switch I install, will have that factory look.
    Patch999 likes this.
  5. Feb 21, 2022 at 7:43 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Can't say that I'm familiar with the switch you're referencing. Got a link?
  6. Feb 21, 2022 at 7:50 PM
    WillTunBlack20
    William
    Houston, Tx.
    This is the switch, a friend ordered, and I told him, I would ask on the forum, hopefully he will join in soon
  7. Feb 21, 2022 at 8:06 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Gotcha.
    I'm not really sure. It seems that someone I was chatting with a while back was trying to use a similar switch (maybe the same one) with the ABC harness, and ultimately the wiring is going in the opposite "direction" - it could be done but not with the illumination working. I don't recall all the details any more, it was a few months ago.
    WillTunBlack20[OP] likes this.
  8. Feb 21, 2022 at 8:12 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
  9. Feb 21, 2022 at 8:14 PM
    RainMan_PNW
    Casey
    Clark County, WA
    yeah - that's the same kit/setup I have.
  10. Feb 21, 2022 at 8:14 PM
    WillTunBlack20
    William
    Houston, Tx.
    Ok, he’s just sent me a additional photo, the wiring harness labeled, maybe someone, can chime in
  11. Feb 22, 2022 at 3:43 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    HulkSmurf14 likes this.
  12. Feb 23, 2022 at 7:28 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The switch you posted is basically two independent ON-OFF switches in one. So both the front and rear camera videos can be turned on at the same time. The OEM-style Switch I offer is an ON-OFF-ON rocker switch so only one camera can be selected at once. If you use your switch with the FRAC Harness and if both switch positions are on at the same time, you will get the rear camera display. The FRAC circuit is designed to resolve the two source conflict. I have no idea how the other harness will react to this condition.
  13. Feb 23, 2022 at 7:57 AM
    It was probably me when I was wiring the on-off-auto switch to replace the Rigid rocker switch for the lights in my rear bumper. We were trying to figure out how to get the amber light to illuminate with the applicable switch position.
  14. Feb 23, 2022 at 2:03 PM
    Chowdah
    Chowdah New Member
    Oceanside, CA
    2020 MBM Tundra TRD Pro
    A.R.E. Truck Cap HD Method Grid Wheels Mickey Thompson Baja ATZP3s
    Following. I've been meaning to install one of these for a while now.
  15. Feb 23, 2022 at 9:54 PM
    RainMan_PNW
    Casey
    Clark County, WA
    That's right. Different application. It's coming back to me now.
    I'd need to look back through some of that to recall what I had figured out in that setup, and then mess around with the CH4x4 switch to compare. I know the issue we had with George's switch/setup was the position of the illumination ground vs the power source - the ABC switch is set up for a single common power input and separate power outputs (one for front and one for rear).
    If someone wants to send me a CH4x4 two-position switch to test out, I'll be happy to get it figured out. :D
    PonyMan likes this.
  16. Feb 23, 2022 at 9:56 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Lou - your setup is pretty sweet looking. If I were to be starting from scratch today, I'd definitely be looking at your setup. The ABC one works fine, but yours looks to be a bit cleaner is all...especially with the new switch (which, if I'm not mistaken, is the same one ABC uses?).
    TundraTex[QUOTED] likes this.
