Anyone with TIS Techstream here?
Discussion in '3rd Gen Tundras (2022+)' started by JohnWhicker, Mar 11, 2024.
  1. Mar 11, 2024 at 9:47 AM
    JohnWhicker
    JohnWhicker [OP] New Member
    I just installed the TIS Techstream version 18.XX but the highest it will go is 2023 Tundras and not 2024 :( Anyone got the TIS Techstream that will work with a 2024 Tundra? What exact version do you have on your TIS?
  2. Mar 11, 2024 at 9:51 AM
    Are you referring to the Amazon or internet lite version? It is going away altogether very soon.
  3. Mar 11, 2024 at 10:22 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    You’ll need GTS+. What is it you’re trying to do?
    JohnWhicker[OP] likes this.
  4. Mar 11, 2024 at 10:25 AM
    JohnWhicker
    ryanwgregg likes this.
  5. Mar 11, 2024 at 10:28 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    i used techstream to change settings on my 24 tundra. it works just set the year as 23.
  6. Mar 11, 2024 at 10:34 AM
    JohnWhicker
    OK, that's good to know. When I connected it didn't pull the info like for my 2021 truck so you have to manually select the specs and add the VIN to it. Is that normal behavior?
  7. Mar 11, 2024 at 10:40 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    yea sounds about right. i think the first time i had to add my vin then next time it remembered the vin but had to add everything else again. i recently added a TPMS to my spare with TS, so trust me it works.
  8. Mar 11, 2024 at 10:42 AM
    JohnWhicker
    Thanks so much partner. Is not for me, I have a 2013 and 2021 and works perfect. Is for a Navasota partner with a 2024 that I am helping :)
  9. Mar 11, 2024 at 2:53 PM
    JohnWhicker
    He needs deeper settings than CARISTA can give him :) Not available in carista for sure.
    Polo08816 likes this.
  10. Mar 11, 2024 at 3:11 PM
    JohnWhicker
  11. Mar 12, 2024 at 9:35 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
  12. Mar 20, 2024 at 3:26 PM
    JohnWhicker
    I need to connect you two guys. My Navasota friend or I are not very fluent in TIS so we could use a hand :)
  13. Mar 20, 2024 at 3:53 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Let me take a look at the tech stream settings this weekend and see if I can figure out what he needs and I’ll take some pictures if I can find it. I saw his thread about needing to "Turn ON Analog Disarm with factory key in the door".
  14. Mar 20, 2024 at 4:14 PM
    JohnWhicker
    Thanks much partner
  15. Mar 21, 2024 at 8:23 PM
    Pgain88
    Pgain88 Just Keep Truckin
    Valparaiso Indiana (Chicago)
    2024 Tundra
    How does the extra wheel appear on the dash where it shows tire pressures?
  16. Mar 22, 2024 at 3:25 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Just like this…
    ryanwgregg and Breathing Borla like this.
  17. Mar 23, 2024 at 12:29 AM
    Pgain88
    2024 Tundra
    Awesome, thanks for the photo! Do you have the part number for the tpms you used? I looked at tech stream for the tpms, what did you do when it asked for a wheel location/auto learn?
  18. Mar 23, 2024 at 4:27 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Pgain88[QUOTED] likes this.
  19. Mar 25, 2024 at 12:49 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    I’m still working on this. So far I haven’t seen anything in the customizable menu. I was going to check in the security ECU but my laptop needed to download framework first then a bunch of updates. Ran out of time for the day but will take another look later this week, as long as my laptop finishes the updates. It’s very old and I just keep it for tech stream use.
  20. Mar 25, 2024 at 1:10 PM
    JohnWhicker
    No worries. Yeah my TIS laptop is Win 7 and takes forever to update
  21. Mar 26, 2024 at 5:49 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    I just poked around again and couldn’t find anything. There is a security ECU I tried but didn’t want to proceed into after the warning it gave me. It said something about this ecu is for writing keys, or something along those lines. I cancelled out of it. Didn’t want to risk messing up my one and only key fob lol. I don’t think the setting he was looking for would be in there anyway. Maybe he should try a different dealer to see if they can get it done.
  22. Mar 26, 2024 at 7:01 PM
    JohnWhicker
    No dealer will do it for him nor even tell him how to do it as this will be a legal liability play. He tried that venue already and even tried to get access behind the scene to one of the techs, and same thing nobody wanted to touch it. I think his best bet will be an independent shop with TIS access willing to make the changes for him as long as he agree to the liability of these changes. The truck is under warranty so he can play "stupid" if something goes south, right :)
  23. Dec 23, 2024 at 9:41 AM
    johnejo
    johnejo New Member
    Southwest New Mexico
    2021 Tundra Double Cab SR5 2WD; 2024 Tundra Crewmax SR5 4x4
    I know this thread is a few months old but I have a question regarding TechStream. I have a 2024 CrewMax SR5 4x4 (non-off-road). I installed the mode selector switch to get MTS as I’ve read many have done, but apparently that doesn’t work for the SR5 versions. I was wondering if TechStream could activate it so that the MTS selection switch would work for me. Would anybody know if that’s possible? Thanks in advance!
  24. Dec 23, 2024 at 10:25 AM
    lapoolboy
    lapoolboy New Member
    What exactly are you trying to get it to control? There are other parts required the truck doesn't have.
  25. Dec 23, 2024 at 10:40 AM
    johnejo
    johnejo New Member
    I’m just looking to have the multi terrain selection capability. I know that the DAC/Crawl will not work for the same reason you mentioned, that there are parts needed for it that my truck does not have, but my understanding was that I should still be able to utilize the MTS if I installed the selector switch for it. Am I wrong on that? If other parts are needed for that specific feature, out of curiosity what would those parts be?
