Anyone using snow chains on Ridge Grapplers?
Discussion in 'Wheels & Tires' started by chrisbusnut, Nov 28, 2019.
  1. Nov 28, 2019 at 12:38 PM
    chrisbusnut
    chrisbusnut [OP] New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    I don't really think I'll need them, however I'm more concerned about the CHP/DOT requirements when driving up in the mountains.
    DM 2018 Tundra likes this.
  2. Nov 28, 2019 at 6:43 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    I like to know that also... I guess you can but snow cables probably be better. Have you called nitto tires?
  3. Nov 28, 2019 at 6:51 PM
    15whtrd
    15whtrd Mr. Blonde
    Not much room to put them on when you start turning. At least in the front. The control arm is really close as well as the body mount and front bumper. I guess it would all depend on the clearances you have. I would probably just use them for the rear and keep it in 2wd If I had to use them. I have a set that used to fit my old OEM tires. But they won’t fit my new size. I’ve never been stopped though. I’ve always been waived through, but if I was in a car or non-4 x 4 they always made me put them on.
  4. Nov 28, 2019 at 6:52 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe just look into some cables. I can see those may fit.
  5. Nov 28, 2019 at 6:53 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    As long as you are 4wd, I believe that covers you for the CHP/DOT requirements.
    GODZILLA and 15whtrd like this.
  6. Nov 28, 2019 at 7:02 PM
    trainracer
    trainracer New Member
    you still have to carry chains with 4x4
  7. Nov 28, 2019 at 7:02 PM
    chrisbusnut
    Pasadena, CA
    Thanks for the responses, guys. I haven’t called Nitto yet. I figured it would be a good idea to at least get a set for the rears and keep them in the truck, just in case.
  8. Nov 28, 2019 at 7:07 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    I had cables on my Fords. They was easy on the tires. 15 whtrd is right about the the front tires. Didn’t even think about that. Great eye
    15whtrd likes this.
  9. Nov 28, 2019 at 9:07 PM
    ZPMAN
    Minnesota
  10. Nov 29, 2019 at 12:30 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I've always been waived through. But if you really feel like putting them on our owner's manual says Do not install tire chains on the front tires. Just for your references
  11. Nov 29, 2019 at 1:50 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I would check the CHP/DOT requirements before doing anything. Maybe there are exceptions depending on size, brand, and type of truck. Seems ridiculous to me that chains would be required, maybe you just have to carry them. Then again, I live in VA and haven't even seen chains in a very long time.
    Black Wolf likes this.
  12. Dec 1, 2019 at 6:36 AM
    Mr_Lahey
    Mr_Lahey New Member
    SE Idaho
    2016 TRD Double Cab (Black of course)
    Once you go black you never go back.
    Why can’t you run chains on the back tires and not have it 4wd also?
  13. Dec 1, 2019 at 7:32 AM
    Depends on your state. Here in CO we have Code 15 and Code 16 Alerts. Under a Code 16 chains don't have to be carried or used with 4X4 capable vehicles with "adequate" tires. Can't hurt to buy a set and stow them away. I have some that I bought in 2004 and have never had to use them.
    15whtrd likes this.
  14. Dec 6, 2019 at 9:56 AM
    tbutler
    tbutler Team Toyota
    2021 Land Cruiser HE - Black
    Does anyone know where to get tire cables for 275/65/18 tire? I've done some quick searches for this size but it usually results in chains, not cables.
    I'm one of the 2wd guys that usually has 1 weekend / year that I need to carry chains/cables in the Sierra's. The few times I've had to put chains on it felt like the whole truck was going to rattle apart.
  15. Dec 6, 2019 at 2:17 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Don’t know where you live but I get mine from a place Mack Fulbright
  16. Dec 6, 2019 at 2:44 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    I've had trouble finding chains or cables for my 295/70 18 tires. Op for whats its worth, I've been snowed in a few times last time being at June Mountain last Feb over super bowl weekend. Cal trans and CHP had to escort us down the 395 until Mammoth. I asked them both if we needed chains (which I didnt) and he looked at my tires and said no you're good as long as you're 4WD and theres a MS marking on your sidewall. I have Toyo MT's but as long as your tires are rated properly and you have 4wd you should be good!
    Pinay likes this.
  17. Dec 6, 2019 at 2:47 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    www.tirechain.com
    scpete24[QUOTED] likes this.
  18. Dec 6, 2019 at 3:01 PM
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    One of the reasons I didn’t want to switch to ridge Grapplers. The exos are snow rated and CHP is good with them. Just couldn’t find the exos in the size I needed.
    scpete24 likes this.
