Anyone use a tire air compressor to inflate a SUP or kayak?
Discussion in 'Outdoors' started by Tun-D, Apr 8, 2019.
  1. Apr 8, 2019 at 2:30 PM
    Tun-D
    Tun-D [OP] New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
  2. Apr 8, 2019 at 2:40 PM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
  3. Apr 8, 2019 at 2:43 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yep. I have an ARB mounted in the truck and it does a great job of inflating the kids kayaks, air mattresses etc...
    I haven't read any reviews on the Smitty air compressor. Everyone I know uses ARB or Viair but the Smitty looks pretty affordable and I think they have a good warranty policy.
  4. Jun 1, 2019 at 11:06 AM
    flinky14
    flinky14 If I'm the wife, who says no to new mods?
    Genna
    Alberta
    2019 Tundra CM Platinum 4x4
    -TRD Dual Exhaust - 3m - UV front window tint/rear limo tint -TRD Oil Cap -Toyota Bed Mat - TRD Pro Grille - ARE canopy (sliding Windoors, pop down sliding front window, headliner, rack rails) -OEM Toyota Remote Starter -Baja Designs Sport Fog Lights -TRD door sill protectors -Ronin Factory short antenna
    You shouldn’t do it! There are electric pumps designed specifically for sups. An air compressor, compresses the air and creates moisture. Having moisture in your sup is a good way to ruin it!
    I worked at a store that sells high end sups and am on team CANADA for sup (just so you don’t think I’m full of shit lol).
    porkitt and YsoSeRiouS! like this.
  5. Jun 1, 2019 at 1:16 PM
    Tun-D
    Don
    Sacramento CA
    2019 TRD Sport MGM
    Just the kind of info I needed. Thank you!
    flinky14[QUOTED] likes this.
  6. Jun 1, 2019 at 5:24 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
  7. Jun 30, 2020 at 10:14 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Almost went the route of compressed air for my SUPs until i read this. Thank you @flinky14 for the advice. Had some REI gift cards so i picked up the airhead pump. Says it pumps up 33% faster than others. Not bad but definitely takes a while between 5psi and 15 psi.
  8. Jul 11, 2021 at 1:09 PM
    Hello77
    Hello77 New Member
    Will this cause moisture too? Thank you.
    https://www.dewalt.com/products/sto.../20v-max-cordedcordless-air-inflator/dcc020ib
