Anyone set 6112s at top setting driver & 3rd setting passenger side?
Discussion in 'Suspension' started by UTAHRTK, Mar 19, 2019.
  1. Mar 19, 2019 at 5:37 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I have been tapping the vast warehouse of knowledge from highly experienced Tundra people and will be ordering 6112/5160 any moment now.
    Looking for feedback on setting 6112s at 2.5 driver side and 1.9 passenger side without use of c/o shims/spacer.
    Other option(s) I am leaning to is 1.9 with 2 shims driver / 1 shim passenger.
    I will be running current wheels (20x9 et 40)/ tires (275/55/20) for about 30k miles and then move to 295/60/20. Yea I figure tires are gonna look pretty damn small for a bit...
    Also, thinking +2 or +3 CB shackles for "level: with slight rake.
    Understandably getting front dialed in and then determining which size shackle would be way to go. One issue is I will be paying to have this installed- the front first -rear second will result in incurring additional costs and the Tundra budget is tight...
    Rica25 likes this.
  2. Mar 19, 2019 at 5:39 AM
    UTAHRTK
    SOCAL
    A few more details: I will be adding bump stop extension and not adding diff drop. Also running stock UCAs - hopefully go TC UCAs when I get new tires.
    Rica25 likes this.
  3. Mar 19, 2019 at 5:46 AM
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    I personally would NOT use different height settings. You would have different spring preload, and I would imagine a sketchy ride over bumps
    Rica25 likes this.
  4. Mar 19, 2019 at 6:05 AM
    UTAHRTK
    SOCAL
    Thanks for the feedback.
    Rica25 likes this.
  5. Mar 20, 2019 at 5:34 AM
    UTAHRTK
    SOCAL
    Decided to shim at 1.9...actually 2 CB shims driver/ 1 passenger. Will go with CB+2 in rear w/ 5160s.
    Rica25 likes this.
  6. Oct 16, 2019 at 7:24 AM
    Youth is overrated
    Youth is overrated New Member
    2017 Silver Tundra CM TRD
    6112/5160 2.5 +2 driver 1 pass CB shims, CB+3 shackles,
    How is this setup working for you? I am in the same boat with a decision to make. At 1.9 with the 2/1 shim setup were you able to get aligned properly? I assume you are on stock UCA's. Thanks
    Rica25 likes this.
  7. Oct 16, 2019 at 7:46 AM
    UTAHRTK
    SOCAL
    I have not installed yet... I will install when tires need replacing- currently have 275/55r20 which will look small with lift. I purchased the following:
    6112 @ 1.9 & 5160 from Dirty Deeds- Keith is a great guy.
    CB +2 shackle, 3 shims, and career bearing drop kit- CB- David is a great guy
    Diff drop kit & 5160 billet bracket- 4wp- good deal
    I will be purchasing bumper shim kit from CB as I am going with Icon Rebounds & BFG T/A KO2 285/75r17.
    Sorry not much help but after research I am confident this will be a sweet set-up with no issues. Perhaps front sway bar spacer kit ...
    Rica25 likes this.
  8. Oct 16, 2019 at 8:34 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I just set both mine at 1.9. Installed and done but I am not as OCD as some. Just needed a little too adjustment for idle. Steers and rides great.
    Cheesy1 likes this.
  9. Oct 16, 2019 at 8:42 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Why the carrier bearing drop kit?
    Rica25 likes this.
  10. Oct 16, 2019 at 10:06 AM
    AZBoatHauler
    So.Arizona
    It is part of the CB+2 shackle.
    I have the same setup except only 1 shim driver's side and none on the passenger. With the shackle, the truck still has enough rake to not be nose high when loaded.
  11. Oct 16, 2019 at 7:47 PM
    UTAHRTK
    SOCAL
    Figured may as well just in case- longevity-price. 38K truck vs 60 bucks for peace of mind. I had an 08 Tacoma with a shitty lift and 35s and had a lotta issues at about 160K. Apple and oranges but helps the OCD/perfectionist German in me.
    Rica25 likes this.
  12. Oct 17, 2019 at 9:05 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Mine are both set at 2.5 with a 1/4" CB shim to get 3" lift. There is a slight driver lean but not noticeable looking at it. You can only tell by measuring. However, same set up for my bro's truck, he definitely had a lean by just looking at it. I ended up shimming another 1/4" for the driver side. I guess the lean varies truck to truck.
  13. Oct 17, 2019 at 9:12 AM
    Youth is overrated
    With that setup did you find it necessary to add UCAs or do the stock UCAs work fine? I noticed in the profile you are running JBA's UCA now but did the lift force the add or was that part of the initial build plan? How are you liking the JBA's? So many options and I want to get it right the first time. Thx
  14. Oct 17, 2019 at 10:19 AM
    matictundra
    Franco
    AZ
    I wanted higher caster for stability and more clearance for 37's.
    I recommend upgraded UCA for following reasons:
    • My coils doesn't rub a full droop against stock UCA, but bro truck does (sligthly) for some reason. I guess manufacturing variance.
    • His UCA joint now shows sign of leakage.
    • More caster.
