Anyone screw up their tires with Bleach White spray?
Discussion in 'Wheels & Tires' started by Dabutcher, Jul 13, 2018.
  1. Jul 13, 2018 at 3:39 PM
    Dabutcher
    Dabutcher [OP] New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    My RG’s look like sheeeeeeeeeet now. They were not even dirty before. I should of left them alone. Third tire photo was from before I effed them up. Peace. D4816AC76-4EB7-4345-A9C8-13795D2BB56D.jpg4B858403-7D02-4380-9222-89F0EDB17751.jpg80C0E01C-272D-489A-81F9-251B3840EEAD.jpg1ACA8DF2-8386-4007-A5CE-3DB5F520423F.jpg
    Black Wolf and GNTundra like this.
  2. Jul 13, 2018 at 5:47 PM
    I use Simple Green!
    Capt J-Rod likes this.
  3. Jul 13, 2018 at 5:50 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    It does it to me as well. So do the other spray on “tire cleaners”. But I get that from spraying the shit and then just spraying it off. I would probably have better results if I sprayed it on and then scrubbed.
    I did use a good tire shine and they look good again.
    jewsNbrews likes this.
  4. Jul 13, 2018 at 5:50 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've had that happen before. Get the tires wet, spray them down, scrub them, then hose them off.
    Best I can tell it happens if your don't keep them wet enough.
    jewsNbrews and Silv333 like this.
  5. Jul 13, 2018 at 6:26 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Been using that stuff for years and no issues...
  6. Jul 13, 2018 at 6:46 PM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    I have used bleche white for 30 years and never had an issue. I wet my tire, spray them with bleche white, then use a scrub brush and dip that into my wash bucket and scrub the tires, then spray them off. They are clean when done that way. Then I armorall them nice and shiny black.
  7. Jul 14, 2018 at 11:28 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Bleche Wite hasn't been the same since Black Magic took it over. :notsure:
    Watt maker and BTBAKER like this.
  8. Jul 15, 2018 at 6:55 AM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    I use Mothers Back to Black works on old discolored tires, new tires that are dirty, stained tires haven't had it fail yet.
  9. Jul 15, 2018 at 7:17 AM
    Professional Hand Model
    Hand Protectors
    Low cost and very effective solution is a bucket of water and a few tablespoons of degreaser with a brush to clean your tires. BlackMagic ‘Gel’ to restore black.
    Black Wolf likes this.
  10. Jul 15, 2018 at 4:49 PM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    What are these wheels attached to?
    GNTundra likes this.
  11. Jul 15, 2018 at 4:51 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    I’ve been using this stuff for years. Unfortunately my Toyo rt’s don’t like it. But I think it’s because I let them get real dirty. I also find you need to spray it on with the tire wet and scrub much more than I was use to on other tires.
  12. Jul 15, 2018 at 4:55 PM
    kodiak
    kodiak New Member
    I’ve used a lot of them, including simple green etc. nothing has come close to working as well as Adam tire and rubber cleaner. Spray it on, scrub with brush, rinse off. Matte, clean finish.
    Watt maker and Tundra Fan like this.
  13. Jul 16, 2018 at 10:28 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    What he said...
  14. Jul 17, 2018 at 3:32 AM
    Dabutcher
    D
    Twin Cities
    They look better now that I coated with armoral gel. Thanks for the help. Peace. DB36DB714-ED4D-4622-BE72-64A702AA3F09.jpg
    Prostar 190 likes this.
  15. Jul 17, 2018 at 8:41 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    more pics please!!!!!!!!! Does it have pumps? *crossing fingers*
  16. Jul 17, 2018 at 9:45 AM
    Tundra Fan
    Toby
    Interesting, I might have to give that a shot.
  17. Jul 17, 2018 at 9:22 PM
    Tundra Fan
    Toby
    While researching the Adams tire and rubber cleaner, I saw a couple of people who commented that they use LA's Totally Awesome Cleaner on their tires. Since it's only $1 for a bottle I figured I try it out first. I think I will continue to use it, I was impressed with how well it did, and you can't beat the cost.
    Augparra likes this.
  18. Jul 17, 2018 at 9:35 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  19. Jul 17, 2018 at 11:24 PM
    Augparra
    Augparra New Member
    Domingo
    2014 Limited TRD crewmax
    I second Adams tire and rubber cleaner. Works greats. You will need to dress the tire after the cleaner. I have been working on my own tire dressing mixture. I don’t like any type of shine just want a clean black tire. so I took about a 1/4 of a bottle chemical guys natural shine dressing and filled the rest of the bottle with water and added a sprayer. With the Ridge grappler side wall being aggressive it’s a lot to spread tire dressing with a applicator. Now I can spray it and level the solution with the applicator. I tested it over the weekend and very happy with the outcome.
    Watt maker likes this.
  20. Jul 18, 2018 at 2:26 PM
    RickC
    Rick
    Knoxville TN
  21. Jul 20, 2018 at 4:45 AM
    Hand Protectors
    Yeah buddy. Those rims be kickin’!
  22. Jul 21, 2018 at 10:41 PM
    Aron9000
    Aron9000 New Member
    Aaron
    Nice Monte there. I used Wesleys Bleach White on my old Cadillac, stuff worked AMAZING.
    RickC, GNTundra and TUNDRA375 like this.
