Anyone running balancing beads?
Discussion in 'General Tundra Discussion' started by joseph_womack, Sep 21, 2022.
Balancing Beads?
  1. Yes
    37.5%
  2. No
    62.5%
  1. Sep 21, 2022 at 11:00 AM
    joseph_womack
    joseph_womack [OP] @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    About to get new tires and debating on running balancing beads vs wheel weights, the thick clay mud in Louisiana generally throws my tires off on the way home from a wheeling trip (closest self wash to the trails is a good 30-45 mins & potential to blast weights off).
    I've seen a couple people have issues where they don't balance out, or they'll get slight vibrations when starting/stopping; anyone getting these issues? Or anyone having good results?
    PFA
    reywcms likes this.
  2. Sep 21, 2022 at 11:22 AM
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    I’ve run ceramic beads on a couple of my Land Cruisers, 1993 FJ80 with 37x12.50r17 Falken MTs and my 1972 FJ40 35x10.00-16 TSL SX2 Super Swampers (bias ply tires). I noticed some vibrations when I first start driving or sometimes at certain speeds but it always seems to smooth out quickly. I like the beads for the ease of not dealing with rim weights for wheeling. I daily drove the 1993 for several years with beads and the current owner is still running them now.
    joseph_womack[OP] likes this.
  3. Sep 21, 2022 at 11:37 AM
    WVI
    WVI New Member
    @008 Tundra Limited
    I have them in my 18" tires now. I'm not sure I went with enough or if they work well with tires this large. Hopefully I can determine this with my next round of parts replacement. BUT, I ran them in my 06 Ram 3500, CRD, which had 17" tires. They worked fantastic in my Nitto's of Firestone's....
    Some where I have them to put in my RV tires...14" rims on a travel trailer...
  4. Sep 21, 2022 at 11:53 AM
    joseph_womack
    Joe
    Louisiana
    do you know how many ounces you used? I was recommended 14 oz but thinking about doing 16oz to be safe
  5. Sep 21, 2022 at 11:55 AM
    joseph_womack
    Joe
    Louisiana
    so you used the ceramic beads that aren't contained in a bag? Just poured into the tire? I was looking at the counteract beads that come in a bag
  6. Sep 21, 2022 at 11:56 AM
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    I’ve always been curious about this. Any impact on tire monitors?
  7. Sep 21, 2022 at 12:00 PM
    joseph_womack
    Joe
    Louisiana
    I know you have to have special TPMS sensors, or maybe valve stems with mesh over them so the beads don't get in the stem. I don't have TPMS anymore so I'm just gonna look into getting valve stems with some sort of mesh so when airing down/up the beads don't leave the tire
  8. Sep 21, 2022 at 12:03 PM
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    They come in little plastic ziplock bags but we just dump them in the tire loose. They work pretty well I started adding 2oz over the recommended when using heavy lug tires.
  9. Sep 21, 2022 at 12:39 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Had them initially on my KO2's. Tire shop put them in without me knowing. Called back as soon as I picked up my truck because it felt like they forgot to balance the tires.
    Took it back immediately and had them perform a traditional balancing and never looked back.
  10. Sep 21, 2022 at 12:40 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    I contact the company each time I need to use them in a different size tire.
    I went with the lighter amount this time, which if I recall correctly, was 5oz per tire. I get the bags pre-measured per tire.
    Some times the folks putting them in will throw the bags in, without opening the bags, as they will open them selves, and until they open the tire wont balance and you can feel it.
    I may get another oz per tire....
    It also depends on the tires. my Nittos were originally balanced with weights, and they were great as they needed very little weight. I ran them on H2 rims for the Dodge. It was a great combo
  11. Sep 21, 2022 at 12:41 PM
    joseph_womack
    Joe
    Louisiana
    yep, I know this is possible, my boss has them in two cars, he's told me that when the truck sits for a couple days then you drive it'll be rough until everything heats up
    Tundyfundy[QUOTED] likes this.
  12. Sep 21, 2022 at 12:41 PM
    joseph_womack
    Joe
    Louisiana
    ceramic beads?
  13. Sep 21, 2022 at 12:43 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Used them years ago in my diesel. Worked fine but just haven't considered it since. Good to know it's still an option.
    WVI and joseph_womack[OP] like this.
  14. Sep 21, 2022 at 12:44 PM
    Tundyfundy
    Bay Area, CA
    Its true. also at slow speeds that don't allow the centrifugal force hold the beads in place. Was just too much vibration for me. I would be willing to give them a try in the future. I pay for a balancing every 5000 miles or so, and that would save quite a bit of money I suppose. I would also be curious on how the tires wear vs traditional balancing. Great thread BTW
  15. Sep 21, 2022 at 12:47 PM
    joseph_womack
    Joe
    Louisiana
    how slow of a speed are we talking? My concern is that when I'm trail riding (5-20 mph) it'll be all over the place, but then again going that slow and being aired down I don't think the tires will be moving fast enough to cause a bunch of vibrations..?
    can you use them if you air down?
  16. Sep 21, 2022 at 1:02 PM
    Tundyfundy
    Bay Area, CA
    Great question. Its my understanding (which could be wrong) that the way the beads work is, once the tire is spinning, the force generated forces the beads to evenly distribute against the inside wall of the tire, and thus balancing the tire as more beads go to lighter areas. If the tire isn't spinning fast enough to hold the beads in place, they just pool around the bottom or move around inside the tire instead of holding to the tire surface. Furthermore, its said that they only correct vertical imbalance and not lateral imbalance. Take short trip through google and read some of the info. I think application, tire size and average speeds all play a factor in this. For instance, if you are off-roading very often, it might be worth it so you don't have to constantly balance because of lost weights.
    To answer your question about speed I think it pertains the the beads weight and the tire circumference. But I would think like stop and go city traffic would see the tire unbalanced more often than not.
  17. Sep 21, 2022 at 1:05 PM
    joseph_womack
    Joe
    Louisiana
    yeah I've done a fair bit of research, I think the slow off road speeds are fine since I've never really started to get wheel shake until like 40 mph, so the crawling shouldn't be a problem. I did read that someone was saying they use it in their rock crawler, and the only issues at slow speeds they have is just hearing the beads roll around, but other than that they were good
    This is the first I'm hearing of the lateral vs vertical imbalance; I'll have to take my chances I suppose, but generally I see the mud collect relatively evenly on the inner drum of the wheel
  18. Sep 21, 2022 at 1:06 PM
    joseph_womack
    Joe
    Louisiana
    this will probably end up being a trial by fire lol :bananadead:
  19. Sep 21, 2022 at 1:17 PM
    I tried the balancing beads in my tow rig and they just never worked out. Ended up having the tire shop busy the tires down, vacuum out the beads, remount and balance.
    Now I have heard the air soft pellet work well if measured correctly.
    I now run Centramatic wheel balancers on every 8 lug wheel I have. Unfortunately they are not made for the Tundra due to space.
  20. Sep 21, 2022 at 1:18 PM
    joseph_womack
    Joe
    Louisiana
    yeah I remember reading your post about the centramatic balancers, do you know what type of beads or brand you ran?
  21. Sep 21, 2022 at 1:18 PM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    I’m running counteract in my tires right now. I just recently swapped my tires out last weekend and used counteract. I went with 8oz each tires as what counteract website chart has. I don’t really notice anything different or off during low mph 20-40mph or maybe I’m just not “focused” on that low side of the mph. At higher mph on freeways I do noticed a huge difference from before when I had some kind of sticky weights on the wheel. I mentioned some kind because my wheels and tires then were super hard to balance, I had almost half the inside barrel full of weights and by the time I left the shop all the weights were gone on the two front wheels because the calipers knocked them all off. Then eventually the rears after rotating tires. My wheels are 17x9 and tires are 37x12.5.
    what I noticed on freeways was that my steering wheel doesn’t shake anymore between the 55-70mph range during acceleration and deceleration like it has before. Pretty easy to work with on the balancing beads and the truck has been pretty smooth on the street and freeway. I have not taken it out for any off-roading yet since i put it back up on jackstands to rebuild all of the shocks.
  22. Sep 21, 2022 at 1:20 PM
    joseph_womack
    Joe
    Louisiana
    you left the counteract beads in the bag they come in?
    And I'm assuming you have 37" all terrains if they only said 8 oz each tire?
  23. Sep 21, 2022 at 1:22 PM
    Counteract. I kept adding beads per their recommendation. Sometimes they were smooth as a new paved road. Other times it felt like I hade octagons for tires.
    I know they work…they just didn’t for this guy.
  24. Sep 21, 2022 at 1:26 PM
    joseph_womack
    Joe
    Louisiana
    I wonder how its gonna work at high speed rough roads, I send it pretty hard on dirt roads and trails so thats got me wondering if the bumping at 40-60mph will really throw the beads off
    oh also did you keep the counteract beads in their bag? Or take them out and pour in?
  25. Sep 21, 2022 at 1:50 PM
    I poured them in and tossed the bag.
  26. Sep 21, 2022 at 2:23 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Beads always seemed like a janky solution and I never had issues with balancing up to 40s, plus lots of hit or miss reviews. Though I understand your thought process of maintaining balance once there's mud and stuff on the tires.
    Tundyfundy and joseph_womack[OP] like this.
  27. Sep 21, 2022 at 2:28 PM
    5.7TRDProm
    Dara
    Yeah the clear bags… supposedly it’s suppose to break open once it feels the energy of rotation, the bag is really fragile so if you accidentally drop that clear bag… just buy another one. I also did use the valve core that was included in each of the counteract bags.
    37 M/T
  28. Sep 21, 2022 at 2:33 PM
    joseph_womack
    Joe
    Louisiana
    oh weird, they were telling me 14oz bags per tire
    sweet I didn't even know it came with cores as well
  29. Sep 21, 2022 at 3:31 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    That seems way to much...Thats the amount for 4 tires in total at times
  30. Sep 21, 2022 at 3:44 PM
    5.7TRDProm
    Dara
    Now that you mentioned it I just checked myself on the site and it says 14oz per tire... Google did me wrong with this research this time... I followed some chart floating around that had Counteract name on it and I saw 8oz. :facepalm:
    But no problems still with my experience lol
