Anyone running a block/shackle combo in the rear?
Discussion in 'Suspension' started by joem1cha3l, Jul 26, 2017.
  1. Jul 26, 2017 at 4:43 PM
    joem1cha3l
    joem1cha3l [OP] New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Planning to crank my front coils up to 3.5". They're currently sitting at 2.5" and I like the look I currently have with the 1.5" blocks in the rear. I'd like to keep the same angle, so if I'm adding 1" in the front, I want to add another 1" in the rear.
    Seems like OME Dakar Leaf Springs are the probably the BEST option, but I was curious if anyone on here is actually running a block/shackle combo.
    My truck is a pavement whore (nowhere around here to offroad), so I'm bouncing the idea around of adding shackles in the rear along with the 1.5" block.
  2. Jul 27, 2017 at 6:05 AM
    joem1cha3l
    Albany, NY
    **crickets**
  3. Jul 27, 2017 at 6:19 AM
    I'm running an AAL +ToyTec shackle set to max in the rear with OME coilovers up front. I like the setup but replacing with Dakar's would be a plus. I suggest calling ToyTec.
  4. Jul 27, 2017 at 6:54 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I've always heard stacking lifts are a bad idea. I'm assuming the same goes with the rear. Would definitely put more stress on your springs.
    I'd just go AAL (or Icon leaf pack) with shackles.
    gosolo likes this.
  5. Jul 27, 2017 at 7:13 AM
    joem1cha3l
    Albany, NY
    If my rear block can't be used anymore, I'm just going with the OME Dakar Leaf Springs so I get 2.5" of lift and then won't need shackles.
    This truck just gets more as more expensive. Ha. Just not sure $600 is worth it for another inch
    Law323[QUOTED] likes this.
  6. Jul 27, 2017 at 7:46 AM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    You'll be fine with blocks and shackles.
  7. Jul 27, 2017 at 7:48 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    no kidding! seems to never end!
    also.....some men may disagree with you about that inch....:bananadead::bananadead::bananadead:
    MTwiford likes this.
  8. Jul 27, 2017 at 8:00 AM
  9. Jul 27, 2017 at 8:01 AM
    joem1cha3l
    Albany, NY
    The bitch is, I have to make a decision like today. Need to get the new ball joints on before any major damage happens. I've already aligned this thing twice in 6 months....I only wanna do it one more time haha.
  10. Jul 27, 2017 at 8:02 AM
    I still say to call ToyTec.........
    T-Rex266 likes this.
  11. Jul 27, 2017 at 8:51 AM
    joem1cha3l
    Albany, NY
    I did and they suggested the Dakar Leaf Pack. I did not inquire about combining the block and shackle yet
  12. Jul 27, 2017 at 9:29 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I like the leveled look so I'm just at 1" in the rear. Should be ok with both but need to figure out if the shock length is ok and what size bump stop to use
    Black Wolf likes this.
  13. Jul 27, 2017 at 9:48 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Hey @joem1cha3l ,
    You should be just fine with running that setup but I would recommend, just as @csuviper stated, double check your shock lengths.
    You might want to consider the Dakar pack sometime or another though, having a shackle and block will break down the leaf pack integrity overtime, especially if you load the truck down.
    We do have options for you buddy! Shoot me a message and we can chat a little more about it!
    -David
    Law323, DVYota and T-Rex266 like this.
  14. Jul 27, 2017 at 10:18 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I wish blocks went away....just ask this guy who cranked up his kings in the front and decided that the Deaver K37 and Camburg shackles weren't enough in the rear. Now it rides like ass. And the fronts are stressed out as well.
    My advice, do it right and get a AAL system or a custom leaf pack for what you need. May cost more initially but your truck will thank you for a long time. If you're just looking for 1.5 or so, Icon can do that while retaining the stock shackles. You can choose to upgrade to Camburg/TC shackle at a later
    time.
    Law323 and Black Wolf like this.
  15. Jul 27, 2017 at 10:26 AM
    joem1cha3l
    Albany, NY
    I've put enough money into this truck that I have zero issue purchasing the new leaf springs for $600 in the future. My issue is, I always think I know what look I want and then it's not enough. Buying $150 in shackles to find out I don't like it is easier to swallow than $600.
    Law323 likes this.
