Anyone running 275/70r18 with +25 offset?
Discussion in 'Wheels & Tires' started by Mr. Wolf, Apr 3, 2021.
  1. Apr 3, 2021 at 10:58 PM
    Mr. Wolf
    Mr. Wolf [OP] New Member
    Hello all. I have a 2021 CM Limited. Came with 275/55/r20 radials with the standard +60 offset. I am wanting to put on 275/70/r18 (either Toyo Open Country AT3, or, Falken Wildpeak AT3W) and mate them with some Method 701's which are +25 offset. Sticking with Method's because I can get a killer deal. The kicker...I am having to keep stock suspension for now, upgrade in the next 3 month or so.
    Any pictures of this combination, especially showing poke as I don't want my tires sticking out too much, as well as fitment advice would be greatly appreciated!! And yes, I've read that posting about largest tire size.
    Thank you so much!
  2. Apr 3, 2021 at 11:01 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Pretty sure it will stick out only about an inch to inch and half at the very most.
  3. Apr 3, 2021 at 11:09 PM
    Mr. Wolf
    Thanks for your prompt reply. So do you think sticking out 1-1.5” from where the tire currently sits, or, 1-1.5” past the fender? Sorry if that’s a dumb question but just trying to wrap my head around all of this and get a visual.
    Thank you again.
  4. Apr 3, 2021 at 11:15 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    That measurement would be from the flat plane of your rim. If you got wider tires that stick out further than the face plane of your rim, the tires sidewall may stick out past that 1.5 inch. Probably looking at around 3 inches max from your tire sidewall to outside of fender.
  5. Apr 4, 2021 at 7:06 AM
    Mr. Wolf
    Thanks again.
  6. Apr 4, 2021 at 10:26 AM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Show us pics when you can!
  7. Apr 4, 2021 at 10:29 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I have the same tires on +10 rims....they do poke out a bit and the tires run large compared to other makers.
    I had rub on full lock reverse and slight on forward, on plastic flaps etc, no major issues. Most of it has been corrected with removal of flaps and pulling forward.
    Even if everyone says they will fit without rub....you never know until you get them on.
    Barrett50 likes this.
  8. Apr 4, 2021 at 11:19 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome
  9. Apr 4, 2021 at 11:24 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    He's been a member for 6+ months. :cool:
  10. Apr 4, 2021 at 1:04 PM
    Mr. Wolf
    BravoDeltaRomeo - would love to see some photos. Thanks!
  11. Apr 6, 2021 at 4:07 PM
    Dansly56
    Dansly56 New Member
    daniel
    I just bought SCS sr8 in +25 and looking into 275/70/18 also. I had some 33x12.5x18 and those rubbed in reverse and in uphill/downhill curved roads. I hope I won’t rub as bad with the 275/70 seeing that it’s skinny compared to the 12.5
    Skey44 likes this.
  12. Apr 6, 2021 at 4:22 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Shouldn’t rub nearly as bad.
    Dansly56[QUOTED] likes this.
  13. Apr 8, 2021 at 5:36 PM
    Username Kyle
    Username Kyle ...
    Kyle
    Chesapeake, VA
    2019 Tundra
    ReadyLift 2.4” Level Fuel Off-road Wheels Wrangler Duratrac Tires Predator Steps ARE Z Series Cap ARE Ascend Basket BedRug Bed Liner Debadged
    I have 275/70R18 with +20 offset. The poke is noticeable I can take some different perspective pictures tomorrow and post them if you want to see more.
    Dansly56 likes this.
  14. Apr 8, 2021 at 5:42 PM
    Username Kyle
    Username Kyle ...
    Kyle
    Chesapeake, VA
    2019 Tundra
    They will probably rub on front mud flaps and possibly a little in the front wheel well fender plastic depending on your lift. I’m running 275/70R18 with +25 offset and I rubbed in reverse at full turn with a 2.4” front level. I removed front fenders and did some minor trimming to front fender with a box cutter and no more rubbing.
  15. Apr 8, 2021 at 5:55 PM
    18" TRD Off Road Wheels
    Mine aren't methods, they are SCS wheels, but these are 275/70R18 Falken Wildpeaks on +25 offsets. FYI, the Wildpeaks run a little large so there is some rub on stock suspension at this size. The little air dams on the front bumper have to come off, and when reversing at about 3/4 turn there is some rubbing on the mud flaps. Nothing major.
    Stock tire poke
    +25 Wheels and 275/70R18 Wildpeaks
    Gee Dub, hennly, toyofan87 and 6 others like this.
  16. Apr 8, 2021 at 6:00 PM
    The Towse Tundra 2.0
    The Towse Tundra 2.0 New Member
    Loy
    2021 Lunar Rock Tundra TRD Pro Crewmax
    TRD Inlay Package, Spray-in Bedliner, Cargo LED Light, Power Tailgate Lock, Center Console Safe, MX4 Bakflip Tonneau Cover, CaliRaised LED Rock Sliders, Nitto Ridge Grapplers 275/70/18, Rigid Industries Amber Fog Light Covers, Coachbuilder TRD Pro lift kit
    :cool::cool::cool::cool:
    That looks nice...:cool:
  17. Apr 8, 2021 at 6:01 PM
    Thank you. :)
  18. Apr 8, 2021 at 6:14 PM
    Dansly56
    Dansly56 New Member
    daniel
    That SCS +25 is fire!
  19. Apr 8, 2021 at 6:51 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Recycling some old pics, haven't taken any recent
    275/70/18 Falken Wildpeaks on Black Rhino Stadium 18x8.5 +10
    PXL_20210116_182820296.jpg PXL_20210116_182812559.jpg PXL_20210122_213349184.jpg
    Tundra14Platinum likes this.
  20. Apr 8, 2021 at 7:32 PM
    Kanobi13
    Kanobi13 New Member
    I barely rubbed on stock suspension with that set up each truck i different so pull trigger!
    BravoDeltaRomeo likes this.
  21. Apr 8, 2021 at 7:33 PM
    Mr. Wolf
    Thank you everyone, this is all very helpful!
  22. Apr 8, 2021 at 8:14 PM
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    Here is 275/70/18 KO2s on +25 offset. Took off air dam and cut a small amount of front mud flap in front of body mount. No lift.D18D0C35-E45D-499E-B720-C9D5B03C5C13.jpg
  23. Apr 11, 2021 at 2:04 PM
    Dansly56
    Dansly56 New Member
    daniel
    Just got my SCS SR8 +25 installed this morning and I love the look!!
  24. Apr 11, 2021 at 3:31 PM
    Kanobi13
    Kanobi13 New Member
    Sweet any rub?
  25. Apr 11, 2021 at 4:31 PM
    toyofan87
    Seth
    Gettysburg, Penna
    295/70/18 Falkens WP, +25 Visions wheels...gives you a idea IMG_20210307_161804.jpg
  26. Apr 11, 2021 at 5:36 PM
    Dansly56
    Dansly56 New Member
    daniel
    0 rub. I should of went with a 285! Next time I will
  27. Apr 11, 2021 at 5:41 PM
    Mr. Wolf
    A
    ll great rigs, thank you!
  28. Apr 12, 2021 at 2:43 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Nice!! Do you think 285/70/18 would have cleared with your SCS wheels?
  29. Apr 12, 2021 at 8:38 AM
    Dansly56
    Dansly56 New Member
    daniel
    they’re 18x9 don’t see why not. I have procomp coilovers in the front with about 2” front lift from stock. I tow a travel trailer so the 275 is a better option
  30. Apr 12, 2021 at 8:51 AM
    RusPro21
    Don
    Pa.
    Yeah that’s why I’m not sure if I will go with 285’s on my tundra pro. Might stay with 275 so that whey I can run SCS wheels when I get them.
