Anyone put on 2.5in front spacers?
Discussion in '1st Gen Tundras (2000-2006)' started by Brizzle B, Nov 22, 2019.
  1. Nov 22, 2019 at 7:20 PM
    Brizzle B
    Brizzle B [OP] New Member
    2005 red Toyota tundra
    nothing yet
    I have in 05 tundra 4x4 limited that I want to put a 2.5 in the front and 1 in the back. I ordered the parts off Amazon and the spacers I got don't measure out 2 1/2 inches. I went to a few different shops and some of them said that the spacer should be what they say and measure out to 2.5in but some of the other shops said it could be a spacer that is 1.5in or 1.25in that will make you have a 2.5in lift. I just want to make sure I got the right size spacers before I put them on. These guys got me coming and going a bit ridiculous. Can someone please tell me what it's really supposed to be
  2. Nov 22, 2019 at 8:27 PM
    turboser91
    turboser91 New Member
    Fresno
    06 DC 4x4
    6" RCD lift
    I believe it's not a 1 to 1 ratio ( 2.5 in spacer = 2.5 in lift ). The spacer will be smaller for a 2.5" lift.
    Tundra234 likes this.
  3. Nov 22, 2019 at 8:33 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    2" of lift at the hub is not equal to 2" of space at the shock. The factory shock maybe has 5" of travel and the factory front suspension has maybe somewhere around 7". The hub is further out on the lever arm than the shock. No idea what the actual length of the spacer should be but I can measure my 2" spacers tomorrow. I think they were 1.75-2".
  4. Nov 22, 2019 at 8:38 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    The 2.5 spacer lift should equal 1.25-1.5 actual thickness.
    because_wumbo-truck likes this.
  5. Nov 22, 2019 at 10:06 PM
    Brizzle B
    nothing yet
    Ok cool. I ordered 2.5in spacers and the spacers I got are 1.25in from Superior suspension. I just wanted to make sure they will equal out to 2.5 inch Lift. For some reason no one could give me straight answer for sure around here at any of the shops
    revtune likes this.
  6. Nov 27, 2019 at 2:03 AM
    Hawkonhorizon
    Hawkonhorizon New Member
    Collin
    '06 sr5 dc trd
    Hardly any
    /this
    Ive been reading up on it and youre right. theres a mathematical equation im sure; but in the end, it seems due to tundys geometry, spacers are not a 1:1
    OP: your truck is not a trd, correct?
  7. Dec 1, 2019 at 10:23 PM
    Ddoza27
    Ddoza27 New Member
    David
    2000 Black Tundra
    Would love to know how it turns out when you do it. I'm thinking about doing the same on my 2000 tundra and wanted to know if it makes a big difference or not.
