Anyone mount a fire extinguisher in their truck?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 996scott, Apr 12, 2017.
  1. Apr 12, 2017 at 9:38 AM
    996scott
    996scott [OP] New Member
    Scott
    Salt Lake City, Utah
    Was thinking it would be a good Idea to have one handy just in case. Anyone carry one in their truck and if so where do you keep it? I have the ESP plastic storage under the rear seats but I don't think it is deep or big enough to hold one.
  2. Apr 12, 2017 at 9:52 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    i keep one in my truck, i couldn't find a good mounting spot. so i just tucked it behind the left rear seat. it doesn't rattle and the rear seat goes up and down fine.
  3. Apr 12, 2017 at 9:55 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Ideally you want it outside the truck. If the fire is in the cab, last thing you want to do is flounder around inside. You can use the rails and t slot nuts to mount a QD mount. Poly performance sells the QD mount made by synergy.
  4. Apr 12, 2017 at 10:25 AM
    15whtrd
    15whtrd Mr. Blonde
    Would be cool if manufactures actually installed them from the factory.
    I'd want mine mounted in the bed near the tailgate if I could
  5. Apr 12, 2017 at 12:33 PM
    Great idea! never thought of might go get me one
  6. Apr 12, 2017 at 1:24 PM
    PMG
    PMG New Member
    There's an extinguisher in a can that works well. Aptly named Tundra.
  7. Apr 12, 2017 at 1:37 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    I got one mounted in the bed via the bed rails.
    I may have a picture somewhere of it.
    If not, I'll snap a photo tonight when I get home and post it up for reference if you'd like.
  8. Apr 12, 2017 at 1:40 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah take a pic. Get a close-up of the mounts too please.
    Krezz[QUOTED] likes this.
  9. Apr 12, 2017 at 1:48 PM
    996scott
    Scott
    yea, that would be great.
  10. Apr 12, 2017 at 2:29 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Pictures please Kevin.
  11. Apr 12, 2017 at 3:36 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    2007 Slate Metallic Double Cab
    I'm thinking of bolting one to the inside of the bed by the tail light on the drivers side. Anyone done something like this? Also wanting to get some bed rails soon, so may look into that option as well.
    15whtrd likes this.
  12. Apr 12, 2017 at 3:44 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I keep one in my tool box. Just make sure it's serviced every year or at least check the gauge last thing you want is a fire extinguisher that doesn't work.
    NewImprovedRon and Krezz like this.
  13. Apr 12, 2017 at 5:39 PM
    Krezz
    Kevin
    I was able to snap a couple quick ones when I got home.
  14. Apr 12, 2017 at 6:14 PM
    15whtrd
    15whtrd Mr. Blonde
    I wonder if that would fit under my bed cover. Are those straps rubber or hard plastic? @Krezz although where I would want to put it is behind one of the taillights. So those straps would work no matter what if I did that. Nice set up.
  15. Apr 12, 2017 at 6:18 PM
    Krezz
    Kevin
    Those are a hard rubber.
    Quickfist's
    15whtrd[QUOTED] likes this.
  16. Apr 12, 2017 at 6:29 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I have one mounted next to the driver's seat. It fits well and further stabilized by a single bungie cord. No rattle, and it takes a couple of seconds to take it out if I ever need it.
  17. Apr 12, 2017 at 6:43 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Good advice about being in the bed (not the cab) and easily accessible. Regardless, mine is strapped into the factory location behind the rear seat where the useless little jack was that came with the truck. Access isn't too bad with the rear seat fold down mod.
  18. Apr 29, 2017 at 4:26 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I picked up a Max Out 2.5 today at work just because I'd rather have it and not need it than need it and not have it. I'm mounting mine behind the console on the floor tomorrow. I personally feel safer with it inside the cab in case of a roll over with a potential fire threat or needing to battle a fire from inside the cab of the truck
  19. Apr 29, 2017 at 6:28 PM
    RussellVaughan
    Houston
    That's a good spot. I always thought, need to hide it, but better out in the open. Especially since almost no one ever sits in middle seat.
  20. Apr 29, 2017 at 7:05 PM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Here's mine, mounted to the passenger seat bolts. It's easy to reach/remove and out of the way for passengers.54aab84bb65ddfabea025326aed94f68_c538ad281e9181a16803adab50699e8946da050e.jpg
    Fallingblock, TXBrit, 831Tun and 5 others like this.
  21. Apr 29, 2017 at 7:09 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    What bracket is that? I had almost the exact same setup in my Subaru and loved it. Tundra would be more of a stretch to reach it, but I liked that it was conveniently located and out of the way.
  22. Apr 29, 2017 at 7:30 PM
    jc153
    San Diego
    It's called The Bracketeer, got it on Amazon. It didn't fit right at first but the seller/designer reached out to me even before I contacted him. He sent me the pieces I needed at no charge. Awesome customer service and really nice guy!
  23. Apr 29, 2017 at 7:32 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    Thanks for the heads up. I think this is the route I'll probably go! Might also mount one in the bed still as well though, just for good measure. :thumbsup:
    jc153[QUOTED] likes this.
  24. Apr 29, 2017 at 7:45 PM
    cheehab
    cheehab Fan Boy
    Southern Maine
    2015 TRD Pro CrewMax
    That'd be a hell of a projectile if you ever got in a front end collision
    NewImprovedRon and landphil like this.
  25. Apr 30, 2017 at 5:09 AM
    Krezz
    Kevin
    She's in pretty tight.
    I realize I can only pull and grab is so tighly but reefing on it hasn't caused it to move yet.
    Always check it before each drive as well, just to be safe... also to make sure it's still there! lol
  26. Apr 30, 2017 at 9:55 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I mounted mine onto the wheel well of the bed for easy access offroad. It's rare I ever have anything on top of that area when the bed is loaded with gear.
    Krezz and NewImprovedRon like this.
  27. Apr 30, 2017 at 11:59 AM
    996scott
    Scott
    That would be a great way to go. I know a lot of people who use mounts like that in their sports call. Nicely done!
    TXBrit and jc153[QUOTED] like this.
  28. Apr 30, 2017 at 3:28 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    All finished.
    kevine0001, Mountun Goat and TheBeast like this.
  29. May 7, 2017 at 10:33 AM
    TheBracketeer
    TheBracketeer New Member
    Thanks for finding our product and giving it a plug!
    FYI the bracket has now been evolved based on our conversations to be a direct fit into a Tundra ... your feedback was invaluable!
    You can see more at www.thebracketeer.com
  30. Jul 3, 2020 at 5:31 PM
    Ad4mmd
    Ad4mmd New Member
    2012 Toyota Tundra TRD DC
    Camburg UCA Fox shocks TRD Front/Rear SwayBars TRD Air-box Intake Mod KN Air filters EBC Brakes TRD 3rd Gen wheels/tires JL Subwoofer 700watt PIONEER Nav HU Focal speakers 3way Dynomat Center Console Safe Led Interior Lights
    How well does it work for passengers? Does it get in the way of there leg room?
