Anyone Know Why My Brakes Squeak In Reverse Only?
Discussion in 'General Tundra Discussion' started by tconrad, Nov 3, 2021.
  1. Nov 3, 2021 at 5:46 AM
    tconrad
    tconrad [OP] New Member
    Tom
    NJ
    2019 Tundra SR5 CrewMax 5.7L FFV 4WD
    The 2019 truck was purchased from a dealer in Aug’21 and just had it inspected + serviced by a Toyota dealership, in NJ, with no callouts mentioned.
    However, I’m noticing “My Brakes Squeak In Reverse Only?” … and can’t understand why? ‍♂️
    ~ before I take to my local mechanic, I’m asking your thoughts / feedback to ensure I’m not overreacting
    thanks
  2. Nov 3, 2021 at 6:02 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    My tundra does not do that, but my 4runner will. It is pretty common in autos. Generally it is due to sitting overnight or such, condensation/moisture occurs inducing some corrosion which gets rubbed off my the pads the first few brake applications. You are also going "against the grain" of the wear pattern the brakes are normally operated in-forward. So it happens, and honestly toyota is the only manufacturer I have owned where this happened with operational brakes in good order. On other cars it was a sign of pad wear or something else like uneven material transfer.
    You can still check it out and see if there are any issues, but I am guessing no problems will be found.
    Demented Canine and tconrad[OP] like this.
  3. Nov 10, 2021 at 9:38 AM
    tconrad
    Tom
    NJ
    Literally had it serviced and no callouts were made other than “brakes look new”… but the squeak persists .. ugh…
    I appreciate all y’alls feedback & thank you!!!
    frichco228 likes this.
  4. Nov 11, 2021 at 4:46 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Happens a lot on 1st gens. Mine does it. We still haven't found a fix for it.
  5. Nov 11, 2021 at 5:27 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    I believe it's @Lil Steve that applied grease (?) to the area affected on the backing plate that squeals and eliminated it. The affected area is easy to recognize due to the lack of paint from where is has rubbed off.
    bmf4069[QUOTED] likes this.
  6. Nov 11, 2021 at 5:29 AM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    Cold start in the morning? How many miles on pads/rotors? Do they feel warped?
  7. Nov 11, 2021 at 6:06 AM
    Critical05
    Critical05 New Member
    2018 MGM TRD Sport, Crewmax 4x4
    Mine does that as well, only reverse and only the rear brakes.
  8. Nov 11, 2021 at 6:15 AM
    Rubberdown
    Stupid question but isn’t the parking brake in the rear drums on the inside of the disc? I wonder if maybe that’s out of adjustment?
    i used to get an annoying click out of my brake pads when I backed up but never squealing. Also now that I think about it I went to 280 thousand miles on the original set of rear brake discs.
    Maybe it’s just gummed up and Rusty and stuff in there and you need to use your parking brake more often and that’ll make the noise go away?
    tconrad[OP] likes this.
  9. Nov 11, 2021 at 6:47 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    My neighbors Ford does it, the tundra with drums does it, our 4runner with discs does it. I wouldn’t worry about it
  10. Nov 11, 2021 at 8:46 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Yes, that will work on our first gens since we have drum rear brakes, but the OP's truck is 4 wheel disc I believe. Not sure if the parking brake has a mini drum/shoe or a ratchet type caliper on newer gens.
    OP, check for anything (like a small rock) lodged between the disc and backing plate/shield. If all good there spray down the discs with brake cleaner to make sure they're clean/grease free. If the squeal persists pull the calipers and pads to apply some brake lube/anti-seize to the back of the brake pads, particularly where it makes contact with the caliper/piston as well as the brake pins/slides with care not to get even a little bit of that brake lube on the discs. I know that last part isn't easy, I almost always wind up with anti-seize somewhere I didn't intend.
  11. Nov 11, 2021 at 8:52 AM
    FrenchToasty
    Mo
    Bone stock
    So I think it has something to do with the ebrake portion of the rear disk. I can’t remember exactly how it’s setup on our 4runner, I think it’s some sort of mini drum brake but even after doing complete brakes F&R the noise was still there. It doesn’t bother me enough to really dig deeper, and it’s a reality check to make sure I’m not on shutter island
    bmf4069 likes this.
  12. Nov 11, 2021 at 9:04 AM
    Lil Steve
    Gilbert, AZ
    Mini drum shoes almost never need replacing but it's possible the back side of the shoes are just barely touching enough to produce that squeal. Hopefully a little dab of brake lube will quiet things down for the OP without having to replace anything. Or turn the radio up! :D
  13. Nov 11, 2021 at 9:52 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The mini drum parking brake is known to be adjusted incorrectly from the factory - I've been meaning to check mine out and do the full adjustment, but haven't had the time yet.
    https://www.youtube.com/watch?v=p19-geSIkq4
  14. Nov 11, 2021 at 10:22 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    This, I had to do it on my 05 4runner but so far the Tundy is okay.
    TRDFerguson[QUOTED] likes this.
  15. Nov 11, 2021 at 10:29 AM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Mine does it after sitting overnight.
    Aerindel likes this.
  16. May 17, 2023 at 3:01 PM
    pilotpro
    pilotpro New Member
    Lincoln
    2020 Tundra
    Na
    2020 tundra has done it since new, every service I have done at Toyota they say brakes are all good. I’d like the techs that say this live next door do they’d hear it every morning when I back out.
    FrenchToasty likes this.
  17. May 18, 2023 at 10:42 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    It's OK. The squeaking noise lets people know you are backing up.
    AggiePhil, Tundrastruck91 and bmf4069 like this.
  18. Jun 30, 2023 at 1:31 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Normal but only on first back-up of the day. Later I can't get brakes to duplicate sound. New brakes as well and properly lubed.
    Demented Canine likes this.
