Anyone know where the 3rd brake light wire is under the dash?
Discussion in '2.5 Gen Tundras (2014-2021)' started by BlueBottle, Nov 6, 2016.
  1. Nov 6, 2016 at 5:35 AM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    I want to add a 3rd brake light flasher to my crewmax. It be great if anyone knows where that +wire is under the dash.
    I'm going do a write up once I figure it out.
  2. Nov 6, 2016 at 5:49 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Are you wanting to tie into the wiring under the hood for a closer location the relay and fuse?
  3. Nov 6, 2016 at 2:53 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Under the dash would be ideal. I will add a flasher board. Hope someone knows the location under the dash if it exists.
  4. Nov 6, 2016 at 3:05 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  5. Nov 6, 2016 at 4:57 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks @RowdyRon
    If I can find where A51 wire is Under the dash that would be ideal.
  6. Nov 6, 2016 at 5:20 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @RowdyRon how do I figure out where the A51 junction is located. That is the key to this.
  7. Nov 6, 2016 at 6:19 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Can I Pull the 3rd brake lamp assembly out from outside? I remember when I replaced my bulb, the housing stayed and could only pull out the bulb. If I could pull out the housing I could install the module behind the housing.
  8. Nov 6, 2016 at 6:24 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    This has been asked before.
    No, has to be pulled form inside to replace the whole assembly, only the bulbs can be replaced outside.
    I pulled these for a 2008 a while back.
    BlueBottle[OP] likes this.
  9. Nov 6, 2016 at 6:25 PM
    Nor7
    Ok, sorry, just read the OP. The 3rd gen hasn't been published to the site I have access to yet. I can look it up for the 2nd gens if you'd like
  10. Nov 6, 2016 at 7:36 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Way to go Ron! Gotta give that seeing eye dog a special treat!
    NewImprovedRon likes this.
  11. Nov 6, 2016 at 8:13 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Wow excellent!!!! When I have some time I will sniff back there with my test light to confirm this. :bowdown:
  12. Nov 6, 2016 at 8:21 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    So you want the third brake light to flash a few times before going solid when braking??
    If so I am so annoyed with cars that do this. Don't know why, just annoys me. But might help with others stopping and not hitting you.
