Anyone know about ATV engines?
Discussion in 'Outdoors' started by trucksareforgirls2, Feb 29, 2020.
  1. Feb 29, 2020 at 10:27 AM
    trucksareforgirls2
    trucksareforgirls2 [OP] New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Hi all,
    Soo I bought a Can-AM ATV (I knew I should have stuck with Honda) about 2 years ago, maybe three, it was new. I think it's a 2017 Outlander 480 or whatever. Anyway since I got it it has nearly stalled or stalled when I first push in the throttle or when I am just about to let it go. I did tell the dealer and of course they couldn't find anything wrong. The problem has only gotten worse and now it is stalling more than it is nearly stalling, and I have no idea what it could be. I have like no knowledge, or interest in engine stuff or working on it myself, but at least if I had an idea what might be causing it I could bring it to a repair shop to see if they can fix it.
    Any ideas? I have tried higher octane gas and lower, and the in-between kind to no avail!
    Thanks,
    T
  2. Feb 29, 2020 at 10:33 AM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    Is it efi or carbed?
  3. Feb 29, 2020 at 10:33 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    I don’t know much about them either, but I bought a 2015 Polaris 570 last fall that had 9 hours on it. It did the same thing you are talking about and I had to have the fuel
    Pump replaced, no issues since then.
  4. Feb 29, 2020 at 10:46 AM
    If it has a carburetor it could be gummed up with bad/old gas.
  5. Feb 29, 2020 at 10:53 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Need to know if fuel injection or carb. Knowing that aside, did you treat the gas with something for the ethanol? If you leave pump gas in a ATV, bike, outboard for anything over a month it starts to absorb water. That could be a factor. Fuel injected engines handle that better but it can still be a problem.
    #1 issue with any motorbike, ATV, etc is bad gas. I sell boats and ATVs for a living and we have a full service shop that works on them all.
    Other suggestion - could be the fuel pump going out.
    Have you kept up on the maintenance? Oil and filter changes? It probably has a fuel filter, could be clogging. 3 years old, may also be time for spark plugs.
