Anyone know a solution to a broken side glass on my Snug Top?
Discussion in '1st Gen Tundras (2000-2006)' started by TurtleWrench, Apr 29, 2021.
  1. Apr 29, 2021 at 10:28 AM
    TurtleWrench
    TurtleWrench [OP] New Member
    Dom
    2000 Tundra 4Dr 4x4 SR5 300K+
    Looks like a rock kicked up and hit my side sliding glass window and shattered it.
    I called Snugtop but they want 1500$ for the whole window assembly and I only paid less than 500 for the canopy .
    Was wanting to know if anyone had a similar problem and if any ideas that may help fix it. Luckly the tint is holding it together for now.
    Thanks for the input .
  2. Apr 29, 2021 at 10:32 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Not sure what model you have, I have the xtra vision which supposedly the glass is curved so it’s harder to get replicated. But best bet is go to a local auto glass company.
    I don’t know how or why they quoted you 1500$ I literally just had a entire passenger assembly ordered for mine; 480$ otd and I installed myself. Call a local camper dealer not Snugtop for parts
  3. Apr 29, 2021 at 10:33 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I may be missing something because I'm looking at a picture but all I can see is that those look like stickers.
    FirstGenVol likes this.
  4. Apr 29, 2021 at 11:50 AM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    If it is completely flat, a good glass shop can replace it with laminated glass (it has tempered in it). The laminated will be clear or slightly tinted so you'll then have to get a window tint place to match the other windows, but it will be a lot cheaper. The key is that it has to be flat.
  5. Apr 29, 2021 at 11:57 AM
    TurtleWrench
    Dom
    Its shattered glass its caved inward towards the inside of the bed, you can see a gap in it. its not suppose to look like that.
    I believe I also have the Xtra Vision model.
    The side with the decals is shattered and falling inward, the tint is holding it together .. for now.
    it is curved glass it looks like. Does not seem flat.
    FrenchToasty likes this.
  6. Apr 29, 2021 at 12:11 PM
    APalmTree
    Brandon
    SW Washington
    Gotcha:thumbsup:. Can you see spiderwebbing from inside the truck looking out under the tint?
  7. Apr 29, 2021 at 12:26 PM
    I've also replaced a window with plexiglass of similar thickness (found at Home Depot) on the cheap (for an old motorhome). You can even apply tint to it, drill it to attach the hardware etc. It is a little finicky to work with (likes to crack if your too aggressive), but is DIY and less $$ if cost is the issue. Could use the window on the opposite side as a template even.
  8. Apr 29, 2021 at 2:29 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I am pretty certain that the Cap Companies do not make any Windows but instead just buy them off the shelf from OEM companies which means that if you can find out who makes the ones for your Cap you can probably just order it from someone Local for a lot less money.
    I know that I have in the past and have also found them at Junk Yards a few times too.
    I still have a Cap on my 2001 Tundra that came with sliders but I wanted WinDoors instead so I contacted the manufacturer who was not all that far away from me and I drove to the Factory and the Manager and I yanked my Sliders and slipped the WinDoors right in and in an hour or so I was headed back home!
    So there are for sure some universal sizes and styles out there for sale.
    des2mtn and FrenchToasty like this.
