Anyone heating their camper shell or roof top tent? How?
Discussion in 'Outdoors' started by jpbewley, Apr 19, 2020.
  1. Apr 19, 2020 at 3:54 PM
    jpbewley
    jpbewley [OP] New Member
    I'm curious how others are heating their camper shells or roof top tents for really cold weather camping... like sub-zero? I'm thinking about mounting a diesel heater up under the frame and move this system below to a permanent install.
  2. Apr 19, 2020 at 4:06 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Lil buddy heater to take the chill off before entering and exiting my sleeping bag. Have been well below freezing but haven’t done sub zero. Single digits are cold enough for me.
    Tundyfundy likes this.
  3. Apr 19, 2020 at 4:36 PM
    jpbewley
    Do you get much condensation? I've been using a candle... but need a little more oomph!
  4. Apr 19, 2020 at 4:56 PM
    Jbehredt
    Westminster, CO
    I’ve got a carpeted headliner so I don’t see any built up condensation but my breath does really start to show. Seems to taper off pretty quick though as the temp climbs.
  5. Apr 19, 2020 at 5:47 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    I use one of those chinese diesel heaters. Works well. I dont run it all night but usually in the morning and as a side effect it dries out the camper/tent really well.
  6. Apr 19, 2020 at 5:50 PM
    pickeledpigsfeet
    Kings & Icons
  7. Apr 19, 2020 at 6:02 PM
    pickeledpigsfeet
    Kings & Icons
    From that thread
    Dylan7194x4 and JEFFTHEROBOT like this.
  8. Apr 19, 2020 at 6:03 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Disclaimer:
    Don't actually do this !!!!!
  9. Apr 19, 2020 at 6:04 PM
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    2007 Tundra and 2011 Sequoia
    I’m looking into a propex heater, still looking at options as well, something that is indirect.
    Right now waiting on getting my ARE DCU back to see where I could mount it.
  10. Apr 19, 2020 at 6:14 PM
    :crazy::rofl::rofl:
    Leo's first likes this.
  11. Apr 19, 2020 at 6:35 PM
    jpbewley
    Let me know what you decide. There is a lot of room underneath the bed but I worry about water crossings. I have a propex in my teardrop and it works great.
  12. Apr 20, 2020 at 10:15 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Another diesel heater here. Works great and doesn't add a bunch of moisture or CO to the tent.
  13. Apr 21, 2020 at 4:03 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
  14. Apr 21, 2020 at 5:24 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    Pudge[QUOTED] likes this.
  15. Apr 21, 2020 at 6:30 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    While on fishing trips, several times a year I sleep in the back of my Snug-Top when the temps are below freezing.
    At first I really liked the Heater Buddy, but it became extremely unpredictable and I wouldn't recommend it, particularly if you are camping at higher elevations. My Heater Buddy became extremely hard to start and it would constantly turn itself off, even though I always made sure it was in a well ventilated area. There of numerous posts on the internet with other people having similar problems. I think the problem lies with the oxygen sensors that are built into the heater.
    On my last trip I went simple and it worked great. It is a propane heater meant to be used outside to heat golf carts. I used mine in the back of my shell and I always made sure it was in front of a vented window. I only use the heater in the morning after I wake up and in the evening before going to sleep. I don't sleep with it on.
    Sunnier likes this.
  16. Apr 21, 2020 at 7:35 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  17. Apr 21, 2020 at 8:30 AM
    Warreng
    Warreng New Member
    I have a UCO 3 candle lantern. Wont heat my camper but takes the chill out. I dont sleep with it burning.
  18. Apr 22, 2020 at 1:00 PM
    kevine0001
    kevine0001 New Member
    Kevin
    Little Buddy heater. However, last few trips, I just threw a couple hand warmers in my sleeping bag. I was very toasty. Temps were in the teens. I know that's not sub-zero, but i basically use one hand warmer when i go to sleep if i'm cold. When I wake up to pee at like 0300-0400, if it's cold, I'll break open two more and toss in my bag. Usually more than enough for me.
    Tundyfundy and TheBeast like this.
  19. Apr 22, 2020 at 1:01 PM
    minter66
    minter66 2007 TSS CrewMax
    Just eat a bunch of these and zip yourself up tight in a sleeping bag - SCIENCE!!
  20. Apr 23, 2020 at 9:14 PM
    Wallygator
    I use a 12V throw like truckers use to keep me warm in the RTT. The throw is under the sheet and heat rises so the comforter holds the heat in. Power it using a Yeti 400. The throw has a timer on it and it shuts off in about 4 hours. It worked well in 30 degree weather. I was never out in weather colder than that so I don't when it's effectiveness stops.
    Challenger1 and Warreng like this.
  21. Apr 23, 2020 at 9:17 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Never be cold again!! Correction...Never FEEL cold again.Haha
    Northern likes this.
  22. Apr 23, 2020 at 9:23 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    We use a “little buddie”. The first time we used it I was in the rtt setting shit up. The wife was In the annex getting herself and our son into pjs she yelled up how “nice” it felt. I’m like I’m boiling up here She laughed and came up the ladder and said wow we don’t need to keep that on long to heat the tent. I’m like I know I’ve been sweating up here setting it up.
  23. Apr 23, 2020 at 9:50 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    @osidepunker and @Challenger1 have been discussing this. We all woke up in Johnson Valley last year to a 24* morning. That's cold for me.
  24. Apr 24, 2020 at 7:21 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    yeah I have a forced air heating system all planned out, but its not cheap, over $1k in parts. The cool thing is you can pull the hose from the tent and run it to your shower tent if you wanted, or an ARB room if you have one for your awning. A 10lbs bottle should last 3-4 nights I believe
    Every damn summer I say I want to install it, then in the fall I say its too complicated and expensive and sleeping bags work well enough, then by the end of winter I say dammit I wish I had it done, then in the spring I forget about it again LOL
    Challenger1 and 831Tun[QUOTED] like this.
  25. Apr 24, 2020 at 8:56 AM
    helidave
    flagstaff
    2015 DC 4x4
    You can do all that with a diesel heater for under $200. I've used maybe a gallon of fuel after 5 nights with outside temps in the 30's & 40's and my tent around 70. 1.jpg
    Warreng likes this.
  26. Apr 24, 2020 at 9:01 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yes true. But then you have to carry 3 fuels, gas propane and diesel
  27. Apr 24, 2020 at 9:09 AM
    helidave
    flagstaff
    2015 DC 4x4
    True, depending on the setup. My heater has the fuel tank built in and my propane tank is mounted on the trailer, so it's not much extra to carry in my situation other than the heater itself. On the plus side, you don't have to worry about not being able to cook cause you used up all your propane with the heater.
    Warreng likes this.
  28. Apr 24, 2020 at 9:47 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Why? It will help have a good night sleep.
  29. Apr 24, 2020 at 9:49 AM
    TXMiamiFan
    Jose
    Just don't light a match afterwards
  30. Apr 28, 2020 at 4:32 PM
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    Mock up...Test cardboard Propex, going to fab up some aluminum brackets to mount it to and replace the screen with a piece of black aluminum that’s removable. At least that’s the plan.
    Aluminum bracket for the gas bottle outside too.
    Wallygator and Warreng like this.
