Anyone have Camping setups with DECKED...Let's see em...
Discussion in 'Tonneau Covers, Caps and Shells' started by LittleTRD, Apr 16, 2019.
  1. Apr 16, 2019 at 10:10 AM
    LittleTRD
    LittleTRD [OP] New Member
    James
    Central California
    2015 Tundra Crewmax
    Camburg UCA's, Fox Factory 2.5's Front & Rear, Coachbuilder +3 Shackles, Decked Bed System, Snugtop Rebel Shell, switch pros 9100, and baja designs for all additional lighting.
    Just got a DECKED system for my Crewmax. Want to get a mattress setup for it. Wondering if any other members already figured out and tested some good options.
    Thanks in advance.
    LittleTRD
  2. Apr 16, 2019 at 10:21 AM
    Zero One Actual
    Call them directly and they will have some information for you. Very awesome people to talk with. @DECKEDUSA
    LittleTRD[OP] likes this.
  3. Apr 16, 2019 at 10:35 AM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Thanks Zero One. Called DECKED but they have no input on mattress/sleep setups as of now. just told me to google and keep asking on the forum. They were very good people though.
  4. Apr 16, 2019 at 11:09 AM
    Stig
    Stig New Member
    Wouldn't you just put a mattress on top of the drawers??? Not much to it.
  5. Apr 16, 2019 at 11:26 AM
    Zero One Actual
    @LittleTRD, Do you have a topper/ shell on the bed or are you open truck bed in the back? I have the @DECKEDUSA two drawer for a crewmax also, but will have a Leitner Designs rack in the back which will prevent me from getting a topper/shell (whatever people call it now). Like @Stig says, you can just get a custom sized memory foam mattress made online professionally to your exact size you want. Foam thickness, fabric color or design, etc. If you are open top and want to run just a mattress or a pad, look at inflatable camping sleeping pads that air down and will fit in one of your drawers when not in use. This plus a nice sleeping bag will work anywhere. This is most spartan option of course but easiest to store and break down when not in use. If you google "car camping" you will see all sorts of ideas that people have come up with. I hope that helps as a starting point. I am curious also because I have the same setup.
  6. Apr 16, 2019 at 11:31 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I built a deck for my 1st gen which lays level with the tire well. I have a cap on my truck. I have tried various bedding options since 2005 and ended up using a 3 inch thermarest inflatable mattress with a nice sleeping bag. Allows for comfortable sleep and easy to stow when moving the truck. A lot of your comfort will be determined by your size and weight. I am 6' 190 lbs and needed the extra padding while sleeping on plywood and carpet. I tried the thinner thermarests but not comfortable on hard surfaces.
  7. Apr 16, 2019 at 11:37 AM
    Zero One Actual
  8. Apr 16, 2019 at 12:27 PM
    Limber
    Limber New Member
    Chase
    to much to list
    I have a decked system in my CM. I set it up to camp out of while hunting elk in sept and for short weekends I dont want to pull the trailer with me. Here is what I use
    https://www.amazon.com/gp/product/B01N2VRBP3/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    I will try and get some pictures up later. I do sleep at an angle to fit but I'm 6'3 but it leaves enough room for the Lab when hes with me
    Also I have cut this roll of reflectix in to for my side windows. https://www.homedepot.com/p/Reflect...-Reflective-Insulation-Roll-BP24010/100318552
  9. Apr 16, 2019 at 1:02 PM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Thanks for the feedback so far.
    @Stig - Ya, pretty much. I was mainly talking options as like best for storage, comfort, and quality. But I got ya, it is just throwing a mattress on a flat surface.
    @Zero One Actual - I just got a Camper shell as well. Snugtop Rebel. So i'm closed top. I like your idea with the custom dimensions mattress. sounds like a great option. I want to make sure I could possibly fold or air it down so I can keep in the truck all the time and still have the top of my deck usable for working/hauling miscellaneous supplies.
    @mtntop - Thanks for the information from experience. I'm 6' 215lbs so pretty close. I'll look into thermarest options.
    @Limber - Thanks, Pretty much exactly what i'm going for. I looked at that Lucid Mattress on Amazon and see the dimensions are (Full mattress measures 53" X 75" X 3") my bed on top of the Decked measures approx 65" X 65" do you leave the short section folded up in the front or rear of the bed while sleeping?
    -LittleTRD
  10. Apr 16, 2019 at 1:05 PM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Also to add to the discussion.
    I have the core trax option installed on my Decked so I was a little worried about air filled mattresses. Don't want to wake up laying on hard plastic, because the trax are pretty flat but still have alot of edges.
    -LittleTRD
  11. Apr 16, 2019 at 1:15 PM
    mtntop
    mtntop New Member
    You could lay down a liner under the mattress, they sell them to use when sleeping on the ground to prevent punctures.
    LittleTRD[QUOTED][OP] likes this.
  12. Apr 16, 2019 at 3:20 PM
    Zero One Actual
    Sounds like a custom memory foam cut in three pieces is your best route. That way it fits perfectly and breaks down into three smaller linear pieces for storage. Additionally the memory foam on the bottom will conform to your core trax.
  13. Apr 16, 2019 at 3:32 PM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Ya, I've already started some searching around after you pointed me that direction. Those custom cut mattresses jump quite a bit in price but definitely the best route. It would be nice to have a perfect fit. Now its time to decide how much more I really want to spend on this setup. :spending:
  14. Apr 16, 2019 at 8:01 PM
    Zero One Actual
    There is always the cheaper route of getting a roof top tent and rack and additional rear suspension to support it. That should be cheaper than memory fo.......oh wait. My bad.
    jordan0317 and LittleTRD[OP] like this.
  15. Apr 16, 2019 at 8:29 PM
    Quikrete
    Quikrete New Member
  16. Apr 17, 2019 at 6:59 AM
    Limber
    Limber New Member
    Chase
    to much to list
    @LittleTRD I leave the fold section at the front for a little bit of cushion under my pillow
  17. Aug 20, 2019 at 3:02 PM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Here’s an update of the sleep setup for LittleTRD.
    Haven’t slept on it yet. But looks and feels promising.
    I’ll update after the first trip out.
    -LittleTRD
    A13A0DD5-B5AF-4326-BAB2-1ED811E5D5F2.jpg E968E187-EE4E-45ED-B681-0ADBE339DB90.jpg
  18. Aug 20, 2019 at 3:21 PM
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    Forgive the ignorance...mind a little blown here
    Do you crawl through the tailgate side window and then close it? Or do you go in with tailgate down also and then pull the tail gate up once you're in?
  19. Aug 20, 2019 at 3:52 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’m curious, how do y’all SPLIT your typical CrewMax load?
    Luckydog, Hbjeff and Zero One Actual like this.
  20. Aug 20, 2019 at 3:54 PM
    escuzi_me
    William
    Nashville, TN
    brb...afk
  21. Aug 20, 2019 at 4:43 PM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    I have been getting in with tailgate down and pulling tailgate up then closing the window. Ill need to add a strap to one of the bolts on the inner tailgate if I continue this way. Because its a bit of a reach. So i'm just going to see what way works better.
    1. Hitch or Bumper(Fold up) Step going in with tailgate up.
    2. Strap on tailgate to help with closing.
    Whichever one works out to be the most convenient.
  22. Aug 20, 2019 at 4:44 PM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    My snug top window has a handle on the inside as well to open from the inside.
  23. Aug 20, 2019 at 4:51 PM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    :rofl::rofl::rofl:
    Pack em all in. whatever fits....ships.
    Luckydog likes this.
  24. Sep 12, 2019 at 1:16 PM
    Pistol0528
    Pistol0528 New Member
    2013 Toyota Tundra CM
    I'll add to the mattress discussion by sharing my experience. I worked with an upholster years ago that placed large orders of padding used in couches. Memory foam is pricey but given his years working this material, he fixed his hunting rig with a combination of three types/layers of foam/padding. Very inexpensive material that you can find at a local upholstery supply store and cut into shape. Just my .02
    I am also pending purchase of my own Decked system.
  25. Mar 17, 2020 at 9:53 AM
    slam38
    slam38 New Member
    LittleTRD what mattress did you go with that looks nice and Im getting ready to do the same
  26. Mar 17, 2020 at 10:13 AM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    @slam38 I purchased 2 of these from Amazon. Since I have the super short bed, I cut off the additional pillow part and had the cover re-sewn, now it fits perfect.
    Without cutting they are about 70inches long.
    https://www.amazon.com/gp/product/B01HEI512C/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
  27. Mar 17, 2020 at 10:21 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    There are places that sell replacement mattresses for RV’s too. They have lots of smaller sizes
