Gen 1 Hitch / Receiver Lift / Replace - Rear Bumper Build
Discussion in '1st Gen Tundras (2000-2006)' started by alb1k, Oct 5, 2021.
  1. Oct 5, 2021 at 2:28 PM
    alb1k
    alb1k [OP] Always Coming From Take Me Down
    Left Coast
    05 2WD DC w/ attitude
    It's good
    My search yielded rear fender chops and high clearance rear bumpers on later Gens and receiver flips on a tube cross mount.
    Gen 1 has a pretty stout towing set up. But the receiver mounts to rectangular tube steel that is flat on top and a Z bottom. The tubing is at an angle as well.
    After looking at it and doing gymnastics in my head, I’m thinking about cutting the tubing out and flipping that. The receiver really seems to want to be on the side it’s on. Anyone do anything like this to a Gen 1?
  2. Oct 5, 2021 at 2:57 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Haven't done it on a tundra. Did it to my old 4Runner, but it was a lot simpler. I'll be interested to see the outcome.
    alb1k[OP] and FrenchToasty like this.
  3. Oct 5, 2021 at 3:10 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I haven't done it nor have I seen it, but I did look at my scrappy bumper today and think "I will need to make my own receiver mount if I make a bumper". It's funny how I haven't thought about it until today and now I see this thread.
    I say give it a shot. Or you could take the stock mount off and make a new one.
    alb1k[OP] and Darkness like this.
  4. Oct 5, 2021 at 3:11 PM
    2mchfun
    What exactly are you trying to achieve?
    FirstGenVol, ezdog and Tundra2 like this.
  5. Oct 5, 2021 at 4:07 PM
    ezdog
    ezdog New Member
    Gateway To The West
    My question too,why?
    Tundra2 and 2mchfun[QUOTED] like this.
  6. Oct 5, 2021 at 4:22 PM
    2mchfun
    If ground clearance is the goal, maybe get some new springs, and or tires. Pretty sure your springs have lost some of their arch over time.
  7. Oct 5, 2021 at 4:36 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I see what you're saying. Seems feasible.
    @jImmegart posted a stock hitch setup somebody was giving away recently, it was in the Long Beach area I think. Maybe try to grab that to operate on if its still available.
    jImmegart, Sunnier and alb1k[OP] like this.
  8. Oct 5, 2021 at 5:40 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    For some reason when I saw the title of this thread I pictured someone selling used Gen 1 stereos out of the back of a van. My mistake.
    KK6PD, tdrich7, Darkness and 3 others like this.
  9. Oct 5, 2021 at 6:14 PM
    KarmaKannon
    Utah
    Some junk
    Getting the hitch out of the way would give you about 3" gained on departure. It would be hard to get that with just new springs unless the old ones were toast.
    des2mtn likes this.
  10. Oct 5, 2021 at 7:04 PM
    alb1k
    Left Coast
    It's good
    Yeah, I’m looking to replace my stock bumper with a mid clearance bumper w/o body chop. I’ve looked at a lot of them and I have a pretty good idea where I want to go with that. It will be a fab job. But, it will work better with the receiver higher and likely integrated. I’m pretty confident I can get there. I was just wondering if anyone had cut into and modded theirs.
    2mchfun likes this.
  11. Oct 5, 2021 at 7:11 PM
    alb1k
    Left Coast
    It's good
    I have to do some more measuring and less eyeballing, but last time I gave it a look, it may be I cut that cross tube and move it higher without flipping it. I’m back to work tomorrow, but I’ll give it more consideration on Sunday.
  12. Oct 5, 2021 at 7:35 PM
    2mchfun
    Did I specify stock replacements? Or even replacements only? No, I generalized and said IF, and for good reason, cuz the goal was not stated. As for springs lifting a few inches, yep, many brands of custom made springs and aftermarket lift springs are available for purchase. I was simply giving OP a few more options to consider.
  13. Oct 5, 2021 at 7:43 PM
    2mchfun
    Why not just weld a new harbor freight receiver tube to a drilled plate and bolt it on to the same holes in the crossmember, except on the top. Weld a few gussets to the plate and tube of course.
    Darkness likes this.
  14. Oct 5, 2021 at 7:45 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    I'm not familiar with the gen1 hitch, but anything is possible with a welder.
    Wes_heppy and 2mchfun like this.
  15. Oct 5, 2021 at 8:16 PM
    alb1k
    Left Coast
    It's good
    That is super helpful @2mchfun, thank you. Is it possible I’ve been over complicating this? Lol :) your way I only have to relocate the welded nuts on top of the tubing, that area can use some cleaning up anyway. I think you saved me a shit ton of work.
  16. Oct 5, 2021 at 8:26 PM
    KarmaKannon
    Utah
    Some junk
    You are so correct. I'm sorry I ever gave you the impression that I was implying you implied they were stock by implying that this thread wasn't about lifting a beautiful first gen so it was as tall as those goofy pug nose third gen trucks. Op must have just typed "I want new leaf springs" in the thread title before his autocorrect got him off on a tangent about some hitch thing or whatever. Thanks for being here to help us lesser beings navigate the world.
    Op-just get stilts for your truck. Problem solved. When in doubt you should just lift it to the moon or whatever my man third gen superhero says. Maybe bigger tires, but just on the back will solve the problem? Maybe deflate the front tires? The options are as endless as the 3rd gen "mu gas mileage is worse than my 4 cylinder car" threads.
    chrisb, jimf909, MrDirtjumper and 2 others like this.
  17. Oct 5, 2021 at 9:03 PM
    alb1k
    Left Coast
    It's good
    So I went and looked at it again in the dark. The receiver move alone won’t get me there. I don’t gain enough clearance by moving it to the top of the tubing, I need to move the tubing as well. But @2mchfun did get me looking at it differently. I’ll put new rectangular cross tube where I want it, and a new receiver.
    Darkness, Sunnier and 2mchfun like this.
  18. Oct 6, 2021 at 5:15 AM
    2mchfun
    Don't forget chain loops on your new designed hitch.
    alb1k[OP] likes this.
  19. Oct 6, 2021 at 7:23 AM
    Fabbing something purpose built would be less effort and yield a custom, desired result. Guess that's what is being proposed here. How often are you dragging the hitch on trails? Bobbing the bed and frame are gonna yield the most dramatic increase in departure angle. Removing the hitch would also be more effective. Using what you got, cut the crossbar off the existing mount, make some new mounts to move the hitch from it's current location and then weld the crossbar to the new mounts. Or buy a new rear bumper with the hitch integrated into it.
  20. Oct 6, 2021 at 7:40 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Or how often do you tow? If you don't tow often maybe drop the whole part and bolt it up when you plan to tow. Unless you're towing off road maybe.
    2mchfun likes this.
  21. Oct 6, 2021 at 4:00 PM
    alb1k
    Left Coast
    It's good
    I rarely tow, I do use the receiver often for bike rack and or cargo basket. But, I would hate to not be able to tow when I need to, and I also want to maintain a recovery point.
    2mchfun and Darkness[QUOTED] like this.
  22. Oct 6, 2021 at 4:02 PM
    alb1k
    Left Coast
    It's good
    ^ I think this is where it's going.
    2mchfun likes this.
  23. Oct 7, 2021 at 9:16 AM
    alb1k
    Left Coast
    It's good
    After more research, the hitch aspect appears to require consideration for liability in the event of a failure. Obviously the goal is no failures ever. But, there are rated kits that have that rating label. I've also noticed the heavier rated hitches have a consistent design aspect. the receiver tube is literally the only place where welds are the securing method alone. The cross tubes are captured in the side plates, side plates are bolted to the frame, etc. I ordered a 15K rated kit from Draw-tite on Amazon. It will be interesting to see if the plates will give me the positioning I would like.
    2mchfun likes this.
  24. Oct 7, 2021 at 9:36 AM
    2mchfun
    I may be wrong, but I'm pretty sure your covered under your auto liability even if you were sort of negligent in your construction of the hitch. Does that mean I suggest you go construct a poor design. No! Just stating that as long as you don't leave a trail or proof of intentional wrongdoing then your insurance would pay out a liability claim. Drunk drivers hitting things or injuring people is an example. They pay out claims everyday for those cases. That said, only do what you think is good for you. I do think a private party could file a civil wrongful death or injury suit beyond an insurance claim, but again I don't practice law in any state. Just roll the dice sometimes, and If I was manufacturing a hitch it would likely be both bolted and welded because I always build HD or not at all.
    lamboboy732 likes this.
  25. Oct 7, 2021 at 9:57 AM
    alb1k
    Left Coast
    It's good
    Full agreement. If I can achieve what I would like to do and get a rated sticker, follow standard practices, etc, I will feel very confident. I am going to weld and bolt the side plates to the frame. I'll add pictures from my phone in a minute of what I ordered.
  26. Oct 9, 2021 at 3:36 PM
    alb1k
    Left Coast
    It's good
    Got some parts delivered. Here’s the inspiration/concept. Hitch location will determine a bit.
    Darkness, des2mtn and Casper421 like this.
  27. Oct 9, 2021 at 5:25 PM
    Casper421
    In the woods
    06 DC
    Wanna make 2?! :D
    Darkness and des2mtn like this.
  28. Oct 9, 2021 at 6:48 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    3*
    Darkness and Casper421[QUOTED] like this.
  29. Oct 9, 2021 at 6:57 PM
    alb1k
    Left Coast
    It's good
    I would love to say hell yes. But you ever see college furniture made from 2X4s? The proportions are F'ed. Bad stock and bad lines. So I'm trying to avoid the brick look, but time will tell. The hitch assembly just came and it is gnarly. 1/4" everywhere. I held a bracket up before dark and I think I can get it where I want with mods. Probably in the bumper or half in. This would be a lot easier if I was willing to chop the body today. Have to get a nice look 8" tall at lic plate. Even then, body is that tall, so I think a cardboard mock up is needed. I'll post hardware from my phone. PS, @Casper421, you weld - so if this works....
    Darkness and Casper421 like this.
  30. Oct 9, 2021 at 7:16 PM
    alb1k
    Left Coast
    It's good
    So this crazy setup is rated at 16K #. It’s still a drop setup, but I can eliminate most drop. I’ll likely mount the brackets outside the frame rather than inside for bend clearance, etc. Use factory bolts when possible, add G8 as needed. Everything is 1/4”. This alone is 50 pounds.
    jimf909, des2mtn, Darkness and 2 others like this.
