Anyone fit a FULL SIZE mattress into a CM Tundra with a shell?
Discussion in '2.5 Gen Tundras (2014-2021)' started by kevine0001, Jun 15, 2022.
  1. Jun 15, 2022 at 1:47 PM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    Weird question. I have a 2017 Tundra crew max. I have a shell and a DIY drawer system. Just wondering if anyone has hauled a full size mattress (not a twin, not a queen...).
    Need it to lay flat with box spring on my drawer. Has a shell with slight angle inward. With insane gas prices, I don't want to waste the gas driving to where it is, just to see that it does not fit. Hoping someone here has tried....
    Thanks
  2. Jun 16, 2022 at 11:59 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    A full size mattress is 54x75. I have a 2016 and did some quick measurements. The width would work as long as it sits over top the wheel well protrusions. But you are short on the length with a 2017 Crewmax, too long to close the tailgate. Would fit with tailgate down however.
    Luckydog and WILLINH like this.
  3. Jun 16, 2022 at 12:29 PM
    kevine0001
    Kevin
    Thanks, yeah with my drawer system, the box spring/mattress will be above the wheel wells, adn I planned to have the tail gate down, with ratchet straps holding the mattress. Door to the shell will be tied down, but obviously won't be closed all the way. I had done some measuring also, but hoping someone has actually tried this. Fingers crossed it works.
  4. Jul 20, 2022 at 2:38 PM
    Fallingblock
    Fallingblock New Member
    Southern MD
    2017 SR5 DC Tundra
    Overhang isn't a problem if you do something like this upload_2022-7-20_17-38-51.jpg
    Blueknights75 likes this.
  5. Jul 20, 2022 at 2:53 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I don't know, but he didn't mention anything about sleeping on the mattress in the truck. With both a box spring and a mattress, there'd be a severe lack of room to so much as roll onto your side.
  6. Jul 22, 2022 at 4:00 AM
    Retired...finally
    Aren't box springs just a box nowadays? If you already have a firm base, nix the box springs.
    Luckydog likes this.
  7. Jul 22, 2022 at 4:06 AM
    War Machine
    War Machine SSEM # 5 3MW
    There is currently a full size mattress in the back of my 2017 Crewmax. No box spring or shell, but the Bakflip is closed with no problem.
  8. Jul 22, 2022 at 4:56 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Just do a quick google search on Full size mattresses and then do a measurement on the inside of your bed/cap and you'll have your own answer. Push comes to shove, ratchet straps usually work pretty well.
  9. Jul 22, 2022 at 5:00 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Try looking at RV mattresses. They are sized differently than for home use.
  10. Jul 22, 2022 at 5:11 AM
    Retired...finally
    That they are. Not widely noted by the RV manufacturer but you figure it our real quick when you're 6'+ and you lay on one.
  11. Jul 22, 2022 at 5:18 AM
    Think OP is merely hauling the mattress from point A to point B. Not trying to build a broverlander in the back of his truck.
    Wynnded likes this.
  12. Jul 22, 2022 at 4:08 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    We use a 4 inch thick queen size memory foam mattress in our crew max. We fold about a foot or so over for a pillow and to fit length.
  13. Jul 22, 2022 at 4:33 PM
    Blueknights75
    Ron
    Clayton, NC
    That right there is pretty sweet!
    Fallingblock[QUOTED] likes this.
  14. Jan 27, 2023 at 1:25 PM
    irontmp
    irontmp New Member
    irontmp
    2013 Black Tundra TRD
    don't know
    Anyone out there happen to know the difference in bed size between Gen 2 and 3 CM? I am asking because I want to know if a bed cap( sleeper, camper shell) from a 14 will fit on my 10. Not to concerned if it is not centered on the rail caps just concerned it will fit.
