Anyone ever use Roadmaster Active Suspension Custom Leaf Spring Enhancement Kit?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Takcar13, Feb 15, 2020.
  1. Feb 15, 2020 at 1:24 AM
    Takcar13
    Takcar13 [OP] New Member
    2018 tundra crewmax limited
    I'm looking to buy this but just wondering if anyone had any first hand experience with thi .
    Lake.Life24 likes this.
  2. Feb 15, 2020 at 5:15 AM
    ginocara74
    ginocara74 New Member
    North Carolina
    2017 SR5 5.7 V8 FFE 4WD magnetic gray with front bench seat and off road package
    TRD dual exaust, TRD drop in air filter, Weather Tech rain GUARD, tri-fold bed cover
    I do on my 17 crew max. I like it better then the sway bar.
  3. Feb 15, 2020 at 8:04 AM
    ATHiker
    ATHiker New Member
    Tom
    2015 DC SR5TRD 5.7L 4X4
    If you install the Roadmaster Active Suspension, does that require or is it recommended to remove the rear sway bar?
  4. Feb 15, 2020 at 9:10 AM
    Takcar13
    Have you towed anything with it?
  5. Feb 18, 2020 at 5:56 PM
    ginocara74
    North Carolina
    Unless you have a TRD PRO, I don't think any other truck configuration comes with sway bar. But if you have one it will probably need to be removed. Towing was purpose for the installation but I haven't personally towed anything yet. It does eliminate the body roll, lift the back of the truck about 1", and increase by 50% your payload (sag is reduced). In the attached pictured I've 2400 in the bad of the truck. I hauled locally but you'll probably need a 10 ply tires if want to haul on a longer trip or highway.
    Mobeyk, Terndrerrr and Bad Cow like this.
  6. Feb 28, 2020 at 12:23 PM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    That's pretty dang impressive. I just watched a YouTube video on the installation of the RoadMaster Active Suspension. Might even be a better solution over Air Bags. Oh and BTW, the TRD PRO Tundra's DO NOT come with a rear sway bar. That would pretty much destroy the TRD tuned Fox Shocks articulation. If you buy a PRO for the suspension, then DON'T install the TRD sway bar on the rear.
    Tundyfundy and trddriver like this.
  7. Mar 15, 2020 at 5:45 PM
    TriggermanOutfitters
    TriggermanOutfitters New Member
    Todd
    Oxford, NC
    2020 TRD Pro
    I have a 2020 Pro and when I hook it up to my boat I have a very noticeable sag in the rear!! I was looking at the roadmaster active but was told it may still sag when pulling my boat versus the air bags??? Also had someone recommend sumo springs??? My boat only weights about 3500lbs any ideas on what I should get??
  8. Mar 15, 2020 at 5:49 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Just because the truck sags less doe not mean that the payload is increased. The payload capacity is what it is from the factory minus whatever you do for add ins. You are way overloaded, illegal, and dangerous with loads like that.
    Tundyfundy likes this.
  9. Mar 15, 2020 at 5:51 PM
    Pudge
    CT
    Whenever I see a pro, even with an empty bed it looks like its sagging, the front lift and no rear lift is not for me. I don't know about the roadmaster stuff but airbags will work. I would consider and add a leaf or change leaf packs so you have some rake like a truck should have.
    NyCSnEaK and Tundyfundy like this.
  10. Mar 15, 2020 at 6:13 PM
    Todd
    Oxford, NC
    2020 TRD Pro
    Looks like the bags are the way to go and only guarantee for no sag when towing!!! I was unaware Pro’s had lighter suspension in the rear? I guess it has something to do with the fox shocks for the better ride
  11. Mar 15, 2020 at 6:20 PM
    Pudge
    CT
    I don't think that the leaf springs are lighter, it's the front lift that give it that saggy look.
    I had air bags on my Tacoma because the damn thing would bottom out with 2 passengers in the rear seat. The bags slowly lost air and I'd have to fill then now and then. I just used a bike pump, it only takes a few pumps to add 5 psi. Anyway they did make the rear ride a little stiff because you have to keep some air in them. I also added Daystar cradles so they wouldn't rip at full droop. They would be good to level it out when towing with just a few pumps of the bike pump.
  12. Mar 16, 2020 at 3:02 AM
    Bad Cow
    Georgia USA
    Yes, all the PRO's "appear" to be low in the rear, when in fact they are not. There are just high in the front due to the TRD coil springs. After much debate I now believe I will be going with Air Bags by Firestone. I like the simplicity of the Roadmasters, and the Sumo's are good too, but the air bags are the only solution that is truly and easily adjustable "on the fly", providing you have onboard compressor. But still, I am in no hurry to do anything as my boat does not kill the rear of my truck. It only pushes it down by an inch, no biggie.
  13. Aug 6, 2020 at 1:03 AM
    LanXTR
    LanXTR New Member
    David
    2008 CrewMax
    Which model of Roadmaster did you install, the Standard or Heavy Duty. If you went with the HD how is the ride unloaded?
  14. Aug 6, 2020 at 1:08 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Beat me to it . More than suspension contributes to payload. Frame, tires, hubs, axles, etc...
  15. Aug 6, 2020 at 1:15 AM
    Tundyfundy
    Bay Area, CA
    I got airbgs and got me one of these https://www.oreillyauto.com/detail/...r-compressor/hv40a2/4683301?q=SuperFlow&pos=2
    couldnt see the point of spending 500 bucks on on board air for a few PSI into my airbags. I love it. Fills my truck tires fast when I need to air down and I use it to fill my trailer tires as well when they are low. comes with a nice little bag as well and fits perfect under the seat with my jack and tools.
    saybng and HulkSmurf14 like this.
  16. Aug 6, 2020 at 5:04 AM
    coTony
    Tony
    Montrose, CO
    How does the rear sway bar destroy the TRD tuned Fox Shocks articulation?
  17. Aug 6, 2020 at 9:17 AM
    Tundyfundy
    Bay Area, CA
    The articulation thing isn’t just pro suspension. A sway bar effectively ties the two rear wheels together. That’s how it reduces sway. In a left hand sweeping turn for example the lady wheel wants to come off the ground but a sway bar uses leverage from the right wheel to push it back down and vice versa. Say you go over a hump on the right side only. The right wheel wants to push up into the wheel well but it can get go so far up with the left wheel not moving since they are tied together so it will actually force the left tire to come off the ground. Here’s a good video showing the concept
    https://youtu.be/-J-h1F1mojQ
  18. Aug 6, 2020 at 9:44 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    The Roadmaster kit works as advertised... I had them on my 2002 Tundra back when I was hauling bottled water. The only thing that I did not like about them is that they caused the bed to sit noticeably higher than stock when it was unloaded. The modern version looks even better than the old version.
  19. Aug 6, 2020 at 9:49 AM
    art64
    art64 New Member
    Roadmasters don't provide as much lift as the airbags. They almost act like shock absorbers. They keep the truck from going up and down when you're loaded heavy. They dampen more than they lift. The airbags, on the other hand, just lifts. They won't dampen. I have both. I've used them together on my 2007 RCSB. I now have 2010 Crewmax 4x4 and I have the Roadmasters installed. Last year, I installed the airbags without the Roadmasters and with the King shocks I have in the back, the ride was unsafe. It's like a pogo stick on the back. So I removed the bags and installed the Roadmasters. Still planning on putting the airbags though.
  20. Aug 6, 2020 at 9:53 AM
    Tundyfundy
    Bay Area, CA
    Do these lower your ground clearance?
  21. Aug 6, 2020 at 1:02 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    My TRD Sport came with the sway bars
    ConspiracyOfOne likes this.
  22. Aug 6, 2020 at 1:10 PM
    Rex Kramer
    Georgia
    No, it works with the rear sway bar.
  23. Aug 8, 2020 at 8:50 PM
    mbahr
    mbahr New Member
    2020 4x4 Crewmax TRD Limited
    Any updates to this? Do they reduce bed bounce?
  24. Aug 10, 2020 at 3:56 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I’m interested as well. I’m not looking to lift my rear much if at all. I have 130k on it and the leaf pack is not in the greatest shape. Also have original shocks. Planning to upgrade to the Eibach front and rear shocks. I have a DECKED system and also additional 150-200lbs on top of that at all times so roughly 350-400lbs in the bed. Would rather do these than airbags or AAL, since I don’t want to lift the rear just level the front with new shocks. I also tow a 5500lb travel trailer on occasion. Thoughts?
  25. Aug 10, 2020 at 5:09 PM
    Ericsopa
    Ericsopa Old man and the sea
    I have the Firestone RideRite airbag kit with the onboard compressor and wireless controller. Without the airbags, pulling my 4500# boat with 400# TW dropped the rear about 2". Airbags at 5 psi have no noticeable effect on the ride when empty (actually, I think the airbags provide a little more damping effect, taming the leaf springs a little). If you've ever pulled a 53' trailer with air suspension, you damned well know the difference between pulling that and pulling a trailer with leaf springs. Air bags tend to dampen themselves.
    Anyway, with the boat hooked up, it takes 34psi to raise the truck back to normal height and level the boat trailer, putting equal weight on each of the trailer's tandem axles. Now I'm considering sliding the tandems back a few inches and increasing the tongue weight a hundred pounds.
  26. Aug 24, 2021 at 10:44 PM
    Last of the V8
    Last of the V8 New Member
    21 limited Trd calvary Blue
    Rsi smartcap, predator steps, roadmaster suspension, nicks tyranny cooler. Rago dash mount plate. Console safe.
    I put the load masters on a couple of weeks ago. Unladen, the ride is actually improved, especially in turns. Less body roll. It did raise the rear an inch on the lighter adjustment I have towed about 75 miles with a 5000# trailer. It seems very stable. I put on the HD version as I will be towing close to max from time to time. I was told by a seasoned friend, that bags and weight distribution hitches are problematic. The trailer company also said they did not recommend it. I should have inquired why, but just trusted their experience.
  27. Aug 25, 2021 at 5:15 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I tow a 7700 lb travel trailer and have had the standard RAS on my 2017 Tundra DC for about 18 months. During that period towed about 6,000 miles. I think it has helped tighten up the rear end resulting in a less body roll, trailer sway and definitely less porpoising. It does lift the rear end a little bit unloaded (maybe 1-1.5") and I like the look. If I had to do it again, I would do the HD model.
  28. Oct 1, 2021 at 8:53 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Thinking to remove my sway bar and get this so I can run a differential skid. Does the RAS completely fill in for the rear sway bar or between the 2, would the actual sway bar be better at the job?
    I imagine you would get more articulation with the RAS over the sway bar correct?
  29. Oct 3, 2021 at 1:42 PM
    2mchfun
    I have the HD kit, great little addition. Have loaded over a ton in the truck several times. However, I also have Dobinson's HD leaf packs. That being said, my truck barely squats with a ton or more on it, and that includes over 1k behind the axle. RAS is just perfect for keeping my springs arched well for many years to come.
    Sumo91 and Terndrerrr like this.
  30. Oct 3, 2021 at 3:52 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Well, I lifted my front almost 3 in. to level it.
    It does not look rear low at all.
    I have Sumos on the rear for support and they act like sway bars only nicer.
    Rodtheviking likes this.
