Anyone ever seen something like this before
Discussion in 'General Tundra Discussion' started by Fireace, Mar 8, 2019.
  1. Mar 8, 2019 at 9:23 AM
    Fireace
    Fireace [OP] New Member
    Oregon
    2018 Crewmax SR5 CM
    BAmuffler Pro Comp 6” lift ADD bumper Smittybilt 10k winch
    my truck just all of the sudden two days in a row start errors and all the gauges stop working while driving. Except the fuel gauge. So strangeACC8BA4C-5B31-4380-96A0-866C1EE40EB9.jpg
  2. Mar 8, 2019 at 9:28 AM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    Search for tss issues.
    Research and attempt possible repair solutions on your own.
    Visit your dealer.
    Be prepared for your dealer to inform you that your modifications are the culprit (assuming the truck in your avatar is your truck).
    Fireace[OP] likes this.
  3. Mar 8, 2019 at 10:02 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    That has nothing to do with the TSS system. There’s a bigger problem going on here. See the dealer immediately.
    Fireace[OP] and Jengel451 like this.
  4. Mar 8, 2019 at 10:25 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    So many issues at once makes me think that it might be to a bad ground. Are you able to read the OBDII codes yourself? If so, check for codes.
  5. Mar 8, 2019 at 10:29 AM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Yea. Thats dangerous. The dealer should pick it up.
  6. Mar 8, 2019 at 11:36 AM
    Fireace
    Oregon
    2018 Crewmax SR5 CM
    Well as it turns out it isn’t the TSS. The only thing it had to do with my lift is the fact I have a speedometer calibrator which has gone bad. It was messing everything up. Fortunately the company is replacing it. Was a bit scary. Should be fixed by the end of the day. I am glad I did most of my work through the dealership for this reason. May cost more but when stuff happens they warrantee it
    TheBeast, hi_rawb, mojojo and 3 others like this.
  7. Mar 8, 2019 at 11:52 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Yep, it's sure nice to take it back to the dealer and say "Broke. Fix. Call when done."
    TheBeast and Fireace[QUOTED][OP] like this.
  8. Mar 8, 2019 at 1:11 PM
    ZPMAN
    Minnesota
    What type of speedometer calibrator do you have?
  9. Mar 8, 2019 at 2:09 PM
    Fireace
    Oregon
    2018 Crewmax SR5 CM
    Pretty sure it was a hypertech. I will check when I pick the truck up. I only have had the truck since last July so it seems odd that it went bad so fast. Hopefully it was just a lemon and I won’t have these issues again
  10. Mar 8, 2019 at 3:56 PM
    Riccitundra
    Riccitundra New Member
    11 black baby
    Yep! Been there done that! They tried to say it was the cluster. However it was a bad ground!!
  11. Mar 8, 2019 at 4:06 PM
    dsrtblly
    dsrtblly New Member
    Bob
    Tundra Limited
    battery / electrical connection
  12. Mar 8, 2019 at 4:14 PM
    Bigant
    Bigant 2019 TRD Pro CM
    Anthony
    NY
    2019 TRD Pro CM
    Clean the front of the sensor off the light goes off
  13. Mar 8, 2019 at 4:17 PM
    Bigant
    Anthony
    NY
    2019 TRD Pro CM
    Salt dust and Mudd make the sensor off
  14. Mar 8, 2019 at 6:24 PM
    Thattundradude
    Thattundradude New Member
    Platinum Tundra
    Lifted
    I had an issue similar to this one a bmw turned out to be 2 bad speed sensors
    SNO BUS likes this.
  15. Mar 9, 2019 at 4:13 AM
    Ycitytundra
    Ycitytundra New Member
    Gary
    Red 2008 sr5
    I had a similar issue was a ground wire at the frame
  16. Mar 9, 2019 at 7:59 AM
    Fireace
    Oregon
    2018 Crewmax SR5 CM
    Interesting because we had snow and they did salt the roads for the first time in along time in Oregon. I guess that is a possibility
  17. Mar 9, 2019 at 10:36 AM
    Bigant
    Anthony
    NY
    2019 TRD Pro CM
    Every time it snows the 1st two days all those lights go on once the wife goes to the car was they go off
  18. Mar 9, 2019 at 11:44 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    This is why I’m hesitant to install my hypertech.
  19. Mar 9, 2019 at 4:57 PM
    ZPMAN
    Minnesota
    I've had a hypertech speedometer calibrator installed since late 2016 with no problems but will remove it as soon as I get my gears installed
  20. Mar 9, 2019 at 5:04 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Had this once too. Turns out Linda's boobs were so big that she activated the Stage 1 aspect of the Vertical Stability Control. Swapped her for A cup Anna. All back to normal.
    Fireace[OP] and Brownsfanhere like this.
  21. Mar 9, 2019 at 5:35 PM
    SNO BUS
    SNO BUS Professional Moneywaster
    Nick
    Washington
    White '18 CM 4x4 Limited+
    LEER Canopy, Line-X, Bed mat, Wireless charging
    TPMS + ABS + no gauges are what we got on our old Range Rover when a wheel speed sensor went out.
  22. Mar 9, 2019 at 5:38 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    I got the same thing when a Squirrel chewed up my engine wiring harness
  23. Mar 9, 2019 at 5:55 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Jesus seriously?
    God bless British engineering...
    SNO BUS[QUOTED] likes this.
  24. Mar 9, 2019 at 5:56 PM
    TheBeast The Beach
  25. Mar 9, 2019 at 7:02 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    How many miles do you have on the lift?
  26. Mar 10, 2019 at 7:41 PM
    BehindenemylinesCali
    BehindenemylinesCali New Member
    Rick
    NORCAL
    2018 Tundra Platinum
    Locker Down console safe Bakflip MX4 Spray in bed Bilstein 6112 Bilstein 5160 2019 TRD Pro wheels
    I had the same message on my 2018 platinum after replacing the windshield. It was a nightmare as safelite tried and tried to get the camera to calibrate after the window install. Toyota figured it out. The camera had been damaged during the process so they replaced it. After I settled the 3 thousand dollar bill with Toyota and my insurance made it right, I gave the dealership the bad cam at their request. I guess they use it to compare or some mechanic type thing. I ain't no mechanic, but after my experience, I'd have em look at the camera up in your windshield. If this helps, pm me and I'll give you my mailing address so you can send me a bottle of whiskey.;)
  27. Mar 14, 2019 at 10:10 PM
    SNO BUS
    Nick
    Washington
    Found a pic. The mileage I racked up on the old girl probably didn't help.
  28. Mar 17, 2019 at 3:42 PM
    Fireace
    Oregon
    2018 Crewmax SR5 CM
    I had 7k on the lift when this happened.
  29. Mar 17, 2019 at 3:45 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Interesting. I have the Hypertech speedo cal as well so will have to keep this in mind in case my dash goes all Christmas tree on me.
  30. Mar 17, 2019 at 3:48 PM
    Fireace
    Oregon
    2018 Crewmax SR5 CM
    Yea if all the gauges go to zero and pretty much every light you can imagine comes on that is probably what it is. Interestingly the gas gauge was the only thing that didn’t zero. I am not sure the calibrator is worth the effort if it goes bad
