Anyone ever repair a Bad lifter?
Discussion in 'General Tundra Discussion' started by J.A.T.O., Jun 26, 2020.
  1. Jun 26, 2020 at 9:20 AM
    J.A.T.O.
    J.A.T.O. [OP] New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    ***Update Aug 11 2020
    Problem solved. Took the easiest route first and swapped the Mobil 1 with OEM oil from the dealership and the problem has been gone now for over 2k.***
    2013 5.7 108k Flex fuel CM has developed a pretty noticeable lifter tick. Anyone here ever tackle this problem? I’ve always ran 87 octane btw.
    I’m hesitant to add any kind of oil treatment because I’ve heard these Toyota engines are pretty picky about oil viscosity. I’m not sure if those treatments would affect that.
    I’ve used Mobil 1 0w-20 since new with no problems so far. I’m going to swap out the oil with Toyota 0w-20 Today to see if that helps but I’m not too hopeful.
    https://youtu.be/T0hlRCSjsrg
  2. Jun 26, 2020 at 9:27 AM
    Cavalrysr5
    Cavalrysr5 New Member
    Jared
    2020 tundra cavalry blue sr5
    You could run a quart of ATF through it for a drive and then change your oil. ATF is high detergent and will clean crud that might have gotten in that lifter. It has fixed a few things for me in the past.
  3. Jun 26, 2020 at 11:59 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Old mechanics trick and it does work. Not sure why the OP thinks the 5.7 is fussy with viscosity? Before 0w20 the motor ran 5w30.
    Cpl_Punishment and Tundyfundy like this.
  4. Jun 26, 2020 at 3:10 PM
    Cavalrysr5
    Jared
    Probably had a Ford before.... those eat cam phasers with thicker oil
  5. Aug 11, 2020 at 12:56 PM
    J.A.T.O.
    Hawaii
  6. Aug 11, 2020 at 1:44 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Would it blow your mind if I told you OEM Toyota oil is Mobil 1:eek2:
    Tundyfundy, kenomouth64, Hoff and 5 others like this.
  7. Aug 11, 2020 at 2:28 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Was it "High Mileage" Mobil 1? Or " "Adavanced Formula" M1?
    Remember some members thinking it made their engines louder than normal.
  8. Aug 12, 2020 at 11:37 AM
    J.A.T.O.
    Hawaii
    Haha nope! I’ve heard others say that. I wasn’t sure if it was true or not so I tried Toyota oil anyway. Somehow it made a difference.
    Larly5000[QUOTED] likes this.
  9. Aug 12, 2020 at 11:37 AM
    J.A.T.O.
    Hawaii
    It was the regular synthetic with Toyota mentioned on the bottle.
  10. Aug 12, 2020 at 11:48 AM
    Trooper2
    JR
    I was referring to the oil prior to Toyota's oil. The oil that was in use with the lifter noise?
  11. Aug 12, 2020 at 11:58 AM
    Larly5000
    NV
    07 Crewmax
    My z06 is faster, louder and slides around corners better when its washed and waxed...i’ll fight anyone who says different:D
    J.A.T.O.[QUOTED][OP] likes this.
  12. Aug 12, 2020 at 12:23 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    What did you run for an oil filter. We have issues with aftermarket filters more than oil making these trucks tick.
  13. Aug 13, 2020 at 7:38 AM
    J.A.T.O.
    Hawaii
    It was mobile 1 synthetic that mentioned Toyota on the bottle.
  14. Aug 13, 2020 at 7:39 AM
    J.A.T.O.
    Hawaii
    It was an OEM filter.
    empty_lord[QUOTED] likes this.
  15. Aug 13, 2020 at 7:57 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Toyota oil is made by ExxonMobil and is really close to mobil1 full synthetic but has a slightly different additive package. I think i remember it having more moly or something along those lines.
    Here is a good read about different oils if you have the time, toyota oil ranked high on the list too.
    https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
    kenomouth64 likes this.
