Anyone elses engine oil dipstick off?
Discussion in '2.5 Gen Tundras (2014-2021)' started by QSX15, May 18, 2016.
  1. May 18, 2016 at 6:11 PM
    QSX15
    QSX15 [OP] New Member
    Oregon
    2016 Tundra 4X4 SR5 LB TRD
    Factory spray liner, bed rails, TRD sway bar, firestone airbags
    Did my first oil change today. Book says 7.9 qts with filter. Put in 8 qts and dipstick shows 1/2 way between high and low on level ground. Turned truck around and waitrd 5 minutes to be sure, and reads the same. Not worried about it, just curious if others are seeing the same thing?
    Also drained oil into quart graduated bucket and got @9 qts so pretty confident the dealer had topped it off predelivery
  2. May 18, 2016 at 6:23 PM
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    Just did my 1st oil change in the Red Freighter (2013 46xxx miles) and ended up with 9qts. I wish it had a oil pan that would drain all the oil.
  3. May 18, 2016 at 6:38 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Dipsticks not off. Mine takes 8 1/2 quarts every time.
  4. May 18, 2016 at 7:11 PM
    QSX15
    Oregon
    Well if your sytem capacity is 7.9, like mine, I would say your dipstick is off.
