Anyone else’s Tundra come with PPF film?
Discussion in '2.5 Gen Tundras (2014-2021)' started by AAA96, Jan 27, 2023.
  1. Jan 27, 2023 at 6:18 AM
    AAA96
    AAA96 [OP] New Member
    2020 Tundra 4x4 SR5 CrewMax
    So when I got the truck it has the PPF or 3M film (not sure which) on the hood, door edges, as well as under the door handles. Over the last few years the seal seems to have broken and has like an orange mildew under it. Does anyone else have this? How can we figure out if it’s covered by the company’s warranty?
    thanks.
  2. Jan 27, 2023 at 6:24 AM
    Taco-Spike
    Two Trucks
    Mine has the exterior inner door handles and front lower rear fenders, but not colored mildew. :confused: Not sure it was a factory or dealership add on?
  3. Jan 27, 2023 at 6:25 AM
    joe_from_iowa
    joe_from_iowa New Member
    Iowa
    2021 Tundra Double Cab SX
    Peeled off the SX stickers from the bed sides. Tyger running boards. A.R.E. DCU topper
    Mine has some clear film on the lower front of the bed, tight behind the cab. One came loose and was flapping in the wind on the way home from the dealership.. new truck. The other one is still there and looking good after a year and a half.
  4. Jan 27, 2023 at 6:26 AM
    AAA96
    I think it might be a dealership add on. Wonder if the manufacturer would cover it. If somehow I can identify what was put on.
  5. Jan 27, 2023 at 7:43 AM
    WaterTrash
    WaterTrash New Member
    The last 5 toyotas I bought has this on them in common scratch/ding areas. I usually pull them off when they start to look bad.
    I get the idea of it, but I really dislike them. Also makes it a royal pain to wax the vehicle
  6. Jan 27, 2023 at 6:10 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    How do you remove them. Mine look like shit.
    WaterTrash[QUOTED] likes this.
  7. Jan 27, 2023 at 6:19 PM
    WaterTrash
    Just peel them slowly. They leave a little residue but it scrubs out easily with some soap, water and a Microfiber. I'm sure a heat gun or hair dryer would make them leave a little less residue behind
    SPOirish28 likes this.
  8. Jan 27, 2023 at 6:25 PM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Mine has it on the door edges, behind the handles, and on the bed sides in front of the tires. One of the bed side pieces is starting to come off and the stuff on the doors is looking bad. I plan on removing it all before the next detail/wax.
  9. Jan 27, 2023 at 6:33 PM
    AAA96
    just removed mine and got the residue off on about 30/40 mins. Used some mckees wax remover for plastic for the residue. Looks way better without it.
  10. Jan 27, 2023 at 7:24 PM
    2mchfun
    Lots including clear bra on my truck, dealership add on that I didn't pay for (could be argued). Waxed frequently since new and it still is in great condition. I never pressure wash my rig, might make a difference. YMMV
  11. Jan 28, 2023 at 8:15 AM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    Definitely a dealership add on, my good friend who does vinyl wraps and clear ppf does dealership work all the time. Use a heat gun/ blow dryer to help remove them, mild dish soap will take off the residue with a small amount of elbow grease. Clear ppf is good stuff to have on your vehicle but not when the seams are leaking. I had a bunch of it installed on the wife’s rav4, door handles so nails don’t scratch the paint there o_O.. I also do the headlights of every vehicle I own. I pressure wash all the time, just blast in the opposite direction of the seam, not at it or straight down on it.
  12. Jan 28, 2023 at 10:06 AM
    Sunman54
    Sunman54 New Member
    I have it on my 2015 Tundra Crew Max and it looks like crap. Mildew under all the edges and probably looks worse as my truck is white. It came with the truck when I purchased it new. I would never recommend it whatsoever. Likewise, I have to take it off.
  13. Feb 3, 2023 at 5:48 PM
    AAA96
    I took mine off. Looks way better natural.
  14. Feb 10, 2023 at 12:55 PM
    Powerboy
    Powerboy New Member
    Scott
    Alabama Gulf Coast
    2020 TSS SR5
    Leveling kit
    My last Tundra was a '00 it had those in front of the rear wheel well. Over time it turned to cement almost. Saw a Tacoma with them too and had done the same thing. When I got my current Tundra, I peeled them off immediately. Did the same to my daughters car too. Over time they just wind up looking termming.
    Mwilliams11315 likes this.
  15. Feb 10, 2023 at 1:38 PM
    SPOirish28
    Ontario, Canada
    2014 SSM SR5 DC
    I’ve removed it everywhere on my truck except for the headlights. As mentioned every vehicle I (will) own gets clear ppf on the headlights. Clear pff has come a long way tech wise, much more UV resistant and will last you a lot longer. If you’re using a modern, quality product and your installer knows what they’re doing, clear ppf is a wise investment imo. My friend wraps entire cars with clear ppf, lambos and such.
  16. Feb 16, 2023 at 1:30 AM
    Bigmax
    Bigmax New Member
    Wilmington, NC
    2017 Sr5 Tundra crew max 5.7L
    Toytec coilovers with Bilsteins, 20x10 Fuel Assualts, 33x12.50 Toyo RT.
    Soap and water and little elbow greese my butt. Lol I had to use goo gone and some 3m adhesive remover took about 30hrs total. Oh and some plastic scrape blades. It sucked my truck is a 2017 it only last 5 to 7 years.
    batman900 likes this.
  17. Feb 16, 2023 at 1:54 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    For removal, try using a hair dryer or heat gun on low setting. Start pulling it up and keep it warm to hot as you pull it. This will probably get the remaining adhesive after removal of the film very sticky.
    As Bigmax mentioned you’ll need adhesive removal to get remaining adhesive off your paint. Iv also used Zippo lighter fluid to break down adhesive, WD-40 works too and won’t damage your paint.
    If you use a heat gun be careful around plastic pieces, trim and headlights.
  18. Mar 1, 2023 at 3:30 AM
    JsjTundra2
    JsjTundra2 Long Time Toyota
    Maine
    My 2007 had this product down low in front of the rear wheels. Stayed attached and looked fine for 15 years...
  19. Mar 1, 2023 at 5:23 AM
    Kung
    KG, VA
    Same with my 2020; I'm already eyeing it, just waiting for it to turn to crap. LOL
  20. Nov 30, 2023 at 12:02 PM
    Mwilliams11315
    Mwilliams11315 New Member
    2015 Tundra SR5 CM
    I’m lot sure who installed mine but I have it on the front and bottom sides on my ‘15 SR5 Crewmax, my buddy who installs this stuff said it lasts about 5 years and then it’s a bitch to take off. So far, mine is looking good but time will tell, I’ll just take it to his shop and have him remove it and do any paint correction necessary after removal. Probably worth the $200 to have a pro do it . I sure do love this truck though!
    BTW, #powerboy, WAR DAMN EAGLE! I was born and raised in Geneva, Alabama, now I live in the great white north . Sure do miss Panama City and destin!
  21. Nov 30, 2023 at 2:20 PM
    Drootz
    Drootz Beer me!
    NorCal
    2021 Tundra MGM Platinum 4x4
    TRDPro Fox Suspension, TRD Black Chrome Exhaust, TRD Pro Wheels, TRD Skid Plate, TRD Rear Sway Bar, TRD Air Filter, TRD Flow accelerator, Color matched rear view mirror caps, Xpel Ultimate Paint Protection Film, Driver's side grab handle added, TRD Shift knob, Remote Tailgate Lock, TRD Parts Added: Fox Suspension, Black Chrome Exhaust, BBS Pro Wheels, Skid Plate, Rear Sway Bar, Air Filter, Flow accelerator, & Shift Knob Other additions: Color matched rear view mirror caps, Xpel Ultimate Paint Protection Film, Driver's side grab handle added. Wanted list: Color matched exterior handles
    My '21 came with some PPF over the common scratch/ding areas. However, in speaking with relative who also install wraps and films, he recommended to have it removed and redone with a better quality brand PPF wrap like xpel. So, that's what I had him do. No complaints so far and no yellowing as of yet.
  22. Nov 30, 2023 at 2:37 PM
    Bigmax
    Bigmax New Member
    Wilmington, NC
  23. Nov 30, 2023 at 2:41 PM
    Bigmax
    Bigmax New Member
    Wilmington, NC
    Dude youll be lucky to have someone remove it for $200. Depends on the time it takes same with paint correction. Probably charge $100 per hour. Im no professional but to remove the film and half a$$ed paint correction took me around 30 hours. Its not going to be 3k but 600 to 800 easy.
  24. Nov 30, 2023 at 4:51 PM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    @Drootz
    I see your in NorCal. do you mind mentioning where your relative does this. I am need of getting mine replaced. It is starting to yellow.
    Thanks, Mike
    Drootz[QUOTED] likes this.
  25. Nov 30, 2023 at 5:08 PM
    Drootz
    Drootz Beer me!
    NorCal
    Leo's first likes this.
  26. Nov 30, 2023 at 5:27 PM
    Scud
    Scud New Member
    Working on it :-)
    Thanks for the information. Is Albert at the Monterey location. Fremont is closest to me but a trip to Monterey would be nice.
    Thanks
  27. Nov 30, 2023 at 5:33 PM
    Drootz
    Drootz Beer me!
    NorCal
    Albert only works at the Monterey location and he would be the one who's work I can speak to.
    Scud[QUOTED] likes this.
  28. Nov 30, 2023 at 5:48 PM
    Scud
    Scud New Member
    Working on it :-)
    Thanks. Do I ask for Albert if I want to get a quote and make a trip down?
  29. Nov 30, 2023 at 6:48 PM
    Drootz
    Drootz Beer me!
    NorCal
    Ask for Mary, she is the one who will provide the quote and Albert is the installer there at the Monterey location. They are an amazing team.
  30. Dec 1, 2023 at 7:27 AM
    Scud
    Scud New Member
    Working on it :-)
    Thanks Drootz, will do
